Hiding splice boxes, Part 2 - Electrician Talk - Professional Electrical Contractors Forum
Like Tree20Likes
Old 04-04-2019, 08:40 AM   #1
Rewards Points: 2,979
Default Hiding splice boxes, Part 2
Lets say you want to run 12C12 Teck to an 884 JB and branch out from there. You don’t want a complicated JB above a T bar ceiling. Would you hide it behind a pop cooler?
Hack or not hack?
lighterup likes this.
Old 04-04-2019, 08:45 AM   #2
Can't sign em..forget em
lighterup's Avatar
Rewards Points: 10,200
(A)...part 2? Did we really need a "Part 2"?
(B)...sprekenz zee Americansk...I don't understand this language
(C) where's C.S. when you need an interpreter
The Following User Says Thank You to lighterup For This Useful Post:
99cents (04-04-2019)
Old 04-04-2019, 08:46 AM   #3
Liberal Lesbian
Rewards Points: 136
Why wouldn't you want a junction box above a drop ceiling?
Old 04-04-2019, 08:56 AM   #4
I want to get in ahead of the tinbasher. He’s going to fill the ceiling with duct and the JB no doubt will end up in an awkward place.
The tiles will be painted drywall and are a sonomobitch to lift after the fact.
And just some other trade scheduling things that make it easier to put the JB in the wall.
Old 04-04-2019, 09:00 AM   #5
Liberal Lesbian
Rewards Points: 136
I'd still put it on a wall down low near the top of the grid.
Coil all the cables up with an extra 5 foot or so, then install the junction box later after the duct is up.
Old 04-04-2019, 09:07 AM   #6
Knotted Ropes Skeery
CoolWill's Avatar
Rewards Points: 1,972
Yes. Hide you box anywhere... As long as it's not behind a non-removable building finish.
Old 04-04-2019, 09:09 AM   #7
What do you need interpreted? Seems simple enough to me.
Old 04-04-2019, 09:12 AM   #8
Thatís the answer I need. Itís always good to get validation from another elite tradesman.
CoolWill likes this.
Old 04-04-2019, 09:25 AM   #9
sbrn33's Avatar
Rewards Points: 3,616
What is teck cable?
Old 04-04-2019, 09:41 AM   #10
What is teck cable?
This idea only I’m using 12 conductor. It’s the Canadian answer to everything.
Old 04-04-2019, 10:10 AM   #11
Rewards Points: 20
A J box behind an easily moveable appliance has always been my practice. Out of site, out of mind, yet accessable if needed without any damage to the room.
99cents likes this.
Wiredindallas is offline   Reply With Quote
Old 04-04-2019, 11:35 AM   #12
Watt Pusher
B-Nabs's Avatar
Rewards Points: 484
Is said pop cooler on wheels?
Old 04-04-2019, 11:55 AM   #13
No, itís a good point. I can put it behind a freezer on castors, which is a better idea.
Old 04-04-2019, 12:08 PM   #14
Rewards Points: 21,731
This idea only Iím using 12 conductor. Itís the Canadian answer to everything.
Holy crap that looks hard to open up. Enlighten me. Shurly not a mere razor knife? Is there a quick strip tool invented like the one I have for me 14-2?
I stand with Tucker Carlson
Old 04-04-2019, 12:17 PM   #15
Liberal Lesbian
Rewards Points: 136
Yeah, this really matters. At first I thought he meant one of those large rows of coolers similar to what you see in the frozen food aisles. A lot of delis and bagel stores around here have those and they are essentially fixed equipment that would be extremely hard to get behind.
But if itís just a small one or two door refrigerator that can be moved, thereís no reason not to put boxes behind it. Itís going to have an outlet box anyway.
But I still believe a junction box up above the drop ceiling is the best option.
Old 04-04-2019, 12:17 PM   #16
Strip off the outer jacket. Score the armour (carefully) with a Hackzall. Take off the armour, strip off the inner jacket. Easy once you do it enough times.
electricguy and glen1971 like this.
Old 04-04-2019, 12:22 PM   #17
I bet if your country had a serious sized population, Ideal would make a quickie one hand movement tool to remove all that nonsense wrapped around the conductors. As it stands though, what? 100 of you guys all total? Not enough to be bothered.............
splatz and Takideezy like this.
Old 04-04-2019, 12:23 PM   #18
trentonmakes's Avatar
Rewards Points: 138
You guys need MC cable
Bend it in 1/2 til it splits, turn it, then snip the metal strand holding it together.
Easy peesy
Old 04-04-2019, 12:36 PM   #19
Easy peesy
In 12 conductor? This stuff is bulletproof. I can throw it in the slab. Iím using 12C12, 3C10 and 6C10 on a small job. The wire houses sell me cuts. A real time saver and I can allow for a few spares here and there. Think big noodles rather than spaghetti .
glen1971 likes this.
Old 04-04-2019, 01:04 PM   #20
daveEM's Avatar
Rewards Points: 2,382
I'm fortunate in that I've not used this teck stuff. Only BX when I didn't want to thread rigid. What amperage are the conductors rated for? Must be derated no?
Can i have a foot for my desk?
I like perfect.
Zone 1 splice MDave Canadian Electrical Forum 6 03-15-2019 06:41 PM
Ground splice in pull boxes or pass thru boxes ? Matthew90 General Electrical Discussion 16 12-20-2018 10:29 PM
Splice in Panel NDC Canadian Electrical Forum 20 08-24-2018 09:17 AM
Boxes part way in block wall psd7.3 Commercial Electrical Forum 28 02-06-2016 11:54 PM
