Hiding splice boxes, Part 2 - Page 2 - Electrician Talk - Professional Electrical Contractors Forum
Like Tree20Likes
Old 04-04-2019, 01:27 PM   #21
Rewards Points: 4,052
Originally Posted by daveEM View Post
I'm fortunate in that I've not used this teck stuff. Only BX when I didn't want to thread rigid. What amperage are the conductors rated for? Must be derated no?
Can i have a foot for my desk?
AFAIK same rules apply to derating. I've worked on it from Cat 5 to 1C500 15kv and tons of sizes in between.
With enough money, they'll build what ever configuration you want for custom jobs.. We did one with a 5C8(?), 15C14 with the #1 conductor orange for a bunch of DC valves on a job. One buddy had an engineer spec 1Pr12 twisted shielded cable for a long run to a transmitter. It was something like 18 weeks out and the minimum order was 9,000 meters. They didn't end up going that route. lol..
daveEM likes this.
Old 04-04-2019, 01:28 PM   #22
Can't sign em..forget em
lighterup's Avatar
Rewards Points: 10,198
This is one of those things I need interpreted.
I'm looking at the 2017 code book ..Chapter 3 ...
don't see anything called "teck", so I assume this is a Canadian
thing ...thus interpret please. I don't understand French either.
Old 04-04-2019, 01:29 PM   #23
lighterup's Avatar
What is teck cable?
so its just not me then
Old 04-04-2019, 01:29 PM   #24
Originally Posted by trentonmakes View Post
You guys need MC cable
Bend it in 1/2 til it splits, turn it, then snip the metal strand holding it together.
Easy peesy
We've got BX (AC90) for that.. Teck can be ran anywhere, and isn't usually a pain to strip. We had a bad run on one job and it took two guys to strip every cable and the longest you could get was in 12-18" lengths of the armour. Best we can figure, they messed up building it and coiled it too tight. That was a good arm workout on the job for sure.
99cents likes this.
Old 04-04-2019, 02:04 PM   #25
Rewards Points: 14,759
Crash course on Teck - it was originally designed for mining, then petrochemical started using it. It has become so common that we use it in commercial and even residential now. I assume the suppliers make good money off all us little guys buying cut-to-order.
It can be used and abused almost anywhere. Multiconductor of same size is easy to get and it’s rated 600V. Outdoor and boom proof you need the proper connectors but indoors you just strip back the outer jacket and use an ordinary flex connector.
I can’t believe it hasn’t made its way down south.
glen1971 likes this.
lighterup (04-04-2019)
Old 04-04-2019, 03:13 PM   #26
lighterup's Avatar
It can be used and abused almost anywhere. Multiconductor of same size is easy to get and itís rated 600V. Outdoor and boom proof you need the proper connectors but indoors you just strip back the outer jacket and use an ordinary flex connector.
I canít believe it hasnít made its way down south.
thanx. you cab be very nice dude when you try
99cents likes this.
Old 04-04-2019, 03:19 PM   #27
trentonmakes's Avatar
Rewards Points: 138
Oh, he can be a bit of a prick when he tries too
99cents likes this.
Old 04-04-2019, 03:23 PM   #28
lighterup's Avatar
I've noticed...he's a ...he's grouchy
Old 04-04-2019, 04:01 PM   #29
Pfffft!
Old 04-04-2019, 04:04 PM   #30
Sure. I have a piece of 2C6 in the supervan .
Derated like any other cable.
Old 04-04-2019, 04:12 PM   #31
Interesting trivia - it was first used in Teck Township, Ontario, hence the name.
Old 04-04-2019, 04:24 PM   #32
daveEM's Avatar
Rewards Points: 2,382
I want the multiest number of cables ya got.
Actually I do remember using some kind of multi-cable in 1971 or 72. Installing the 1st set of traffic lights in Sherwood park. I did a few of sets there. It was like NMW and we pulled it 2" poly pipe. Only ran a few light bulbs tho.
^^ Used directional drilling then. Nice, attached poly tube and the guy pulled it back.
One set overhead... I actually used spurs for that guy.
1969 not so lucky. Vegerville traffic lights Lots of hand trenching. As a 2nd year I had to wear my tool belt while digging. Their first lights too so on Main and Main. I didn't want the town girls to think I was labor only guy. We always looked like electricians back then. We pulled in multiple #12's or 10's for that one.
99cents likes this.
I like perfect.
Old 04-04-2019, 04:31 PM   #33
daveEM's Avatar
You're trying to get the American guys to like you are't you? I think you should troll Hack now.
99cents likes this.
I like perfect.
Old 04-04-2019, 04:34 PM   #34
Rewards Points: 725
You guys should be nice to sweet, innocent ol' Hax.
daveEM likes this.
Old 04-04-2019, 04:35 PM   #35
daveEM's Avatar
Back to the original post. I think the ceiling. Maybe a a map as to which tile. Easer to get at than getting a gorilla helper to move the loaded cooler.
Tile is not that heavy. You are running flexi stuff. Let the tin man finish 1st. Plumber too.
If you do put it on the ceiling bracket it down. I got a 12x12 j-box on one job site on the ceiling where the cover drops down. Looking up at that crap for an hour sure is hard on the neck.
Just my opinion.
HackWork likes this.
I like perfect.
Old 04-04-2019, 05:52 PM   #36
Just my opinion.
Now Iím going to feel bad when I do it.
But Iíll get over it.
Old 04-04-2019, 06:16 PM   #37
Watt Pusher
B-Nabs's Avatar
Rewards Points: 478
Now called Kirkland Lake, Teck Township was so named because of the Teck-Hughes mine that was located there. Teck joined with Cominco in 2001 to become Teck Cominco, now called Teck Resources, headquartered in Vancouver.
99cents and glen1971 like this.
Old 04-04-2019, 08:34 PM   #38
MTW
Rewards Points: 10,510
What is teck cable?
A wiring method they use in communist countries.
Old 04-04-2019, 10:18 PM   #39
CoolWill's Avatar
Rewards Points: 5,072
It's like PVC coated MC, but there's another PVC layer under the metal sheath too.
Zone 1 splice MDave Canadian Electrical Forum 6 03-15-2019 06:41 PM
Ground splice in pull boxes or pass thru boxes ? Matthew90 General Electrical Discussion 16 12-20-2018 10:29 PM
Splice in Panel NDC Canadian Electrical Forum 20 08-24-2018 09:17 AM
Boxes part way in block wall psd7.3 Commercial Electrical Forum 28 02-06-2016 11:54 PM
