High temperature wire connections - Electrician Talk - Professional Electrical Contractors Forum
Old 04-21-2012, 04:11 AM   #1
ilikepez's Avatar
Default High temperature wire connections
We have a lot of heated plates at work that production uses to fuse plastic pipe together. Some of them were built with boxes way too close to the heated surface so they burn up any normal connection we might use. Right now we have high temp wire that is soldered together and covered in a kind of fiberglass sheath. Obviously that isn't UL listed or even electrically insulating. I would like to replace this stuff and I'm wondering what you guys recommend.
The interior of these boxes can get up to 450 degrees Fahrenheit. Some don't get so high. All our machines automatically cut out at 490 degrees. I'd like to find a good connector and some kind of electrically insulating tape or whatever else that would be good for that.
ilikepez is offline   Reply With Quote
Old 04-21-2012, 06:00 AM   #2
Jlarson's Avatar
Rewards Points: 4,296
What voltage rating do you need, 300 or 600?
Tempco makes 300v wire nuts and 600v terminal blocks that can handle your temp requirements.
High Leg on a 3 phase 120/240 4 wire delta system az101 General Electrical Discussion 34 04-17-2013 11:53 PM
High Temp Wire / 380V Cletis General Electrical Discussion 12 06-08-2011 11:35 PM
Wire stripper for *lots* of connections Mike in Canada Tools, Equipment and New Products 20 07-27-2010 03:21 PM
high leg for 120/240 volt 3 phase 4 wire system kolbychamberlain General Electrical Discussion 2 06-21-2010 05:08 PM
