Hot neutral? - Page 2 - Electrician Talk - Professional Electrical Contractors Forum
Like Tree9Likes
Closed Thread
Old 03-11-2018, 01:40 PM   #21
German Spy
Helmut's Avatar
Rewards Points: 4,435
As for the "how does this work? Is this normal? How comes?"
You really need to familiarize yourself with being able to read and understand a transformer diagram.
Do you know how to read and understand one of those?
And, I suppose knowing how a simple circuit works would help.
Helmut is online now
Old 03-11-2018, 02:17 PM   #22
Rewards Points: 41
You guys got me thinking. I'm going to check a few things out and post back in a few days. Thanks for your help and patience!
The day I stop learning is the day I die
bogart219 is offline
Old 03-11-2018, 04:00 PM   #23
WPNortheast's Avatar
Rewards Points: 184
Why isn't this locked yet
readydave8 likes this.
WPNortheast is offline
Old 03-11-2018, 04:19 PM   #24
Hi. Here’s my solution for you bud. For the 12/3,use red for your D/W, and black for your puck lights (low voltage)or under the cabinet lightings (sharing neutral for the 2 circuit)and run a dedicated circuit meant for your GFCI receptacle. If you have 2 GFCI receptacles on your counter, just connect the 2nd receptacle (20 amp regular receptacle) from the load side of the GFCI. It might be messy and hard for you as for those finished wall but you’ll know for sure you’re not burning down your house or frying up your high end bosch D/W. Just trying not to make it too complicated for you. If you still find it hard to do, call an electrician.
Hope it will help you bud.
Expy2007 is offline
Old 03-11-2018, 06:24 PM   #25
Band Member
emtnut's Avatar
Rewards Points: 1,978
I have no idea
emtnut is offline
Old 03-12-2018, 06:43 AM   #26
Rewards Points: 41
[QUOTE=Expy2007;4847241]Hi. Here’s my solution for you bud. For the 12/3,use red for your D/W, and black for your puck lights (low voltage)or under the cabinet lightings (sharing neutral for the 2 circuit)and run a dedicated circuit meant for your GFCI receptacle. If you have 2 GFCI receptacles on your counter, just connect the 2nd receptacle (20 amp regular receptacle) from the load side of the GFCI. It might be messy and hard for you as for those finished wall but you’ll know for sure you’re not burning down your house or frying up your high end bosch D/W. Just trying not to make it too complicated for you. If you still find it hard to do, call an electrician.
A so called electrician is the one who hooked this mess up in the first place. That is why I came here looking for help.
" run a dedicated circuit "
Yeah this is an option that I thought about,but running wires from these outlet boxes back to the panel box on a finished back splash would be a big pain in the ass.
I wish the "expert" poster's that replied to this thread who didn't know the answer to my questions, troll someone else's post to show how smart they are.
To ask why this post isn't locked demonstrates the arrogance and self importance some of you "electricians" have.
The bottom line is when someone post a question that you don't know the answer to or you just don't like the question or your one of those tradesmen that think when you need a light bulb changed to call an electrician, stay away and mind your own business.
Lock it now.
Old 03-12-2018, 07:18 AM   #27
Rewards Points: 1,261
No, the arrogance is from you, who thinks you are above the rules. When you signed up you read the clear warning that this forum is for electrical professionals only. What makes you think that you are so much more special than everyone else that you can breaks the rules and get away with it?
HackWork is online now
Old 03-12-2018, 08:00 AM   #28
Rewards Points: 21,896
That is enough.
I going to lock this thread now.
To OP I did look up what your profile stated saying " service technician "
I do not know how far your area cover for repairs.
If you going help your buddy with electrical work IMO the best answer is just leave it and let experinced electrician deal with branch circuit because the experinced electrician can able see what excatally what is going on with the circuit.
I have a feeling someone did miswired the GFCI on MWBC that is part of the issue.
Now the thread is closed.
frenchelectrican is offline
Closed Thread
Fronius Symo 20.0-3 480 (Delta - Wye Transformer), Neutral Wire jay_the_gemini Commercial Electrical Forum 2 02-13-2018 08:27 AM
200amp underground service in Alberta, reduced neutral jingles4214 Residential Electrical Forum 10 11-05-2016 08:09 AM
Conductor Electek inc General Electrical Discussion 25 05-05-2016 12:02 AM
Neutral required to be ran to generator? lynes.nathan Canadian Electrical Forum 7 03-01-2016 10:10 PM
115 VAC disconnect - should I break both hot & neutral? Paul Kraemer General Electrical Discussion 11 01-22-2016 11:21 PM
