How close Is to close ? - Electrician Talk - Professional Electrical Contractors Forum
Like Tree14Likes
  • 1 Post By numbers
  • 1 Post By wcord
  • 2 Post By Speedy Petey
  • 1 Post By Jhellwig
  • 3 Post By B-Nabs
  • 1 Post By Southeast Power
  • 2 Post By numbers
  • 1 Post By numbers
  • 2 Post By MechanicalDVR
Old 09-08-2016, 07:21 PM   #1
Rewards Points: 88
Default How close Is to close ?
What is the minimum distance an electric radio can be to an edge of a pool or lazy river. The radio is plugged into an GFI outlet.
Jhellwig likes this.
numbers is offline   Reply With Quote
The Following User Says Thank You to numbers For This Useful Post:
Jhellwig (09-09-2016)
Old 09-08-2016, 07:41 PM   #2
Speedy Petey's Avatar
Rewards Points: 610
The radio is irrelevant. It's the receptacle that matters.
What is a lazy river? What is the setting?
Old 09-08-2016, 07:58 PM   #3
wcord's Avatar
Rewards Points: 1,836
fail
Majewski likes this.
Old 09-08-2016, 08:57 PM   #4
Rewards Points: 88
It's a public pool. The lazy river is separate from the main pool. It is used for walking and riding on inner tubes. It has moving water which propels the inner tubes. The receptable is mounted on the side of the building. The radio was plugged into an extension cord and it was placed on the concrete near the water.
Old 09-08-2016, 09:06 PM   #5
Rewards Points: 610
That is the issue.
As far as we are concerned, the placement of the receptacle is what needs to meet code. If some idiot wants to plug in and leave an x-cord around a setting like that he should be removed from the job and the area.
360max and freefreeqaz like this.
The Following 4 Users Say Thank You to Speedy Petey For This Useful Post:
360max (09-08-2016), freefreeqaz (09-08-2016), frenchelectrican (09-09-2016), Signal1 (09-09-2016)
Old 09-08-2016, 09:11 PM   #6
Rewards Points: 88
Thanks Speedy Petey, I didn't know if it was covered by the code. I guess you can't account for stupidty. I told the person in charge to remove it. I will check on it tomorrow if I get a chance.
Old 09-08-2016, 09:17 PM   #7
Sparks fly from my finger
Jhellwig's Avatar
Rewards Points: 4,559
Being that it is a public place it would fall under whatever governing body regulates its operation. The extension cord will be no where to be found on inspection day. If their insurance underwriter happened to be there on a nice outing with the family it could get interesting.
Do the construction electrician thing when they have a cord where it doesn't belong and chop the end off.
360max likes this.
Old 09-08-2016, 10:21 PM   #8
Watt Pusher
B-Nabs's Avatar
Rewards Points: 480
The male end of course
Old 09-09-2016, 07:05 AM   #9
Southeast Power's Avatar
Rewards Points: 8,906
The NEC assumes a 6' cord. Once an extension cord in introduced into the question, no one can help you.
A GFCI receptacle 10' away from the edge of the water with something with a '6 cord would leave enough space that the average person would be out of reach of it.
Old 09-09-2016, 09:40 AM   #10
Rewards Points: 88
I will bring my wire cutter with me.
MechanicalDVR and Jhellwig like this.
Old 09-09-2016, 12:50 PM   #11
Rewards Points: 88
Suncoast, do you have a code reference?
Old 09-09-2016, 05:11 PM   #12
Rewards Points: 434
The "Code" is not going to address things like extension cords in that way, the NEC is about safe CONSTRUCTION and DESIGN practices. What idiots do after it is designed and installed is not something that can be addressed in the NEC. So the NEC will address placements of receptacles so as to limit the use of extension cords (i.e. 6ft along a wall), and can say things like "no permanent use of extension cords". It appears this is somewhat addressed though in Article 680:
680.7 Cord-and-Plug-Connected Equipment. Fixed or stationary equipment, other than underwater luminaires, for a
permanently installed pool shall be permitted to be connected
with a flexible cord and plug to facilitate the removal or disconnection
for maintenance or repair.
(A) Length. For other than storable pools, the flexible cord
shall not exceed 900 mm (3 ft) in length
People think that just because it is a GFCI, it is "safe". It is safER, but nothing is 100%.
I would imagine there might be other health and safety regulations that will forbid it.
Old 09-10-2016, 11:48 AM   #13
Rewards Points: 88
Just wanted to give everyone an update. When I went to the pool Yesterday the radio was replaced by a battery powered one. I guess they listened to me.
frenchelectrican likes this.
Old 09-10-2016, 11:52 AM   #14
Rewards Points: 23,618
Every now and then some common sense goes a long way. Peopel tend to just ignore safety choices more often than not.
frenchelectrican and Bird dog like this.
We had a close one! Cow Workplace Safety 44 08-28-2016 01:33 PM
Jobsite fire, as close as your going to get. Wirenuting Off Topic (Non Trade) 24 08-21-2016 01:28 AM
2" Non-metallic Flex to Subpanel 15' Away green4now Residential Electrical Forum 94 08-08-2016 04:42 PM
Close to the Vest derit Tools, Equipment and New Products 18 05-09-2016 11:11 AM
