How to determine how many divices - Electrician Talk - Professional Electrical Contractors Forum
Like Tree37Likes
Old 09-21-2016, 08:16 AM   #1
Rewards Points: 330
Default How to determine how many divices
What is the most efficient way to determine how many devices are on a circuit? For example if someone asks you to add an exterior outlet in their yard, how would you find out how many devices are on the exterior wall plug circuit to determine whether or not this circuit has room for another device?
Canaduh is offline   Reply With Quote
Old 09-21-2016, 08:24 AM   #2
Rewards Points: 24,234
Identify the circuit and map it out with a tracer or similar method and then get physical and count 1-2-3...
Majewski likes this.
Canaduh (09-21-2016)
Old 09-21-2016, 08:25 AM   #3
Rewards Points: 3,057
Kill the circuit and see what's dead.
sbrn33 and Majewski like this.
Old 09-21-2016, 08:27 AM   #4
Rewards Points: 330
I don't own a tracer, I do own a toner for low voltage, are they the same thing? I have seen expentice circuit tracers at work but they are upwards of $1000
Old 09-21-2016, 08:28 AM   #5
Rewards Points: 330
Yep this is what I would normally do. I was just wondering you guys had any tricks other than doing so.
Old 09-21-2016, 08:35 AM   #6
Big nosed attic troll
Majewski's Avatar
Rewards Points: 2,820
You can guess and hope for the best?!
But like they all say, kill the circuit, manually search and find everything, map it out.
Double check the same ones after turning back on to be sure it's same circuit and or
you'd have to ohm it all....
You did say efficient, that could mean tedious and lengthy in this scenario.
Old 09-21-2016, 08:38 AM   #7
Have your help do it while you are making money on something else.
readydave8 and Majewski like this.
Old 09-21-2016, 08:39 AM   #8
sbrn33's Avatar
Rewards Points: 3,634
Unless it is for any real load just come off the easiest circuit.
Helmut and Majewski like this.
Old 09-21-2016, 08:45 AM   #9
German Spy
Helmut's Avatar
Rewards Points: 4,719
Why? Is there a limit on how many devices you can have on a circuit when performing old work?
Old 09-21-2016, 08:51 AM   #10
We have a rule for resi that says twelve locations (receptacles/fixtures) unless it's a known load (LED's, fill your boots).
Old 09-21-2016, 08:58 AM   #11
German Spy
Helmut's Avatar
What happens up there in the tundra, when a 13th is added?
Old 09-21-2016, 09:00 AM   #12
The tundra melts .
Old 09-21-2016, 09:03 AM   #13
Majewski's Avatar
I've heard stories! Spooky stories!
readydave8 and emtnut like this.
Old 09-21-2016, 09:05 AM   #14
Band Member
emtnut's Avatar
Rewards Points: 62
We sell the house
13 is a BAD number !!!
Old 09-21-2016, 09:07 AM   #15
Majewski's Avatar
Hahahahahahah! I like 13!
Old 09-21-2016, 09:08 AM   #16
It comes down to the 1 amp per receptacle and 80% circuit loading I would believe.
Old 09-21-2016, 09:09 AM   #17
45 and 69 have always been my favorite two numbers but neither is electrically relative.
Old 09-21-2016, 09:11 AM   #18
German Spy
Helmut's Avatar
The number 69, and the word "relative" should not be used in the same sentence with this crowd.
FWIW...
Old 09-21-2016, 09:12 AM   #19
Majewski's Avatar
Yup but besides I don't know a logical reason?
I don't mind the latter.
FWIW...
Lmao!
Old 09-21-2016, 09:14 AM   #20
Got me through the most boring days of my high school years. It wa sother things that got me expelled...
Determine amp when kW is know Tripping breakers General Electrical Discussion 5 01-23-2016 07:13 PM
