How Did They Du Dis? - Electrician Talk - Professional Electrical Contractors Forum
Like Tree5Likes
  • 3 Post By MechanicalDVR
  • 2 Post By Jlarson
Old 01-05-2017, 11:04 PM   #1
ppsh's Avatar
Rewards Points: 124
Default How Did They Du Dis?
Putting in a subpanel for a well pump, some outdoor lighting, etc.. Plugged in my pvc heater at the nearby GFCI, wrapped it on a pipe, and waited, and waited, 5 minutes on a piece of 1" sch 40 and still hadn't softened. A minute later I smell burning windings. Find the source of the smoke, its a 24vac multi tap transformer in a weatherproof enclosure, smoking and sparking. Kill the breaker and start opening all of the enclosures.
It was a 24vac, 40va transformer with a multi tap primary, 120, 208, 240v. Power going to the well equipment was 12/2 uf, powered forma a 2 pole 20. Transformer fed a water softener controller. Primary was wired using the 240 tap and common, as it should.
However, there was another wire pigtailed to the common on the primary side, and a wire hooked to the 120v tap, went underground thru sealtight, and fed the GFCI I plugged my PVC heater into.
It appears that they wanted 120v, and had no neutral, so Cletis discovered he could get 120v from attaching to the 120v primary tap on 240v fed transformer.
How did this even "work"?
ppsh is offline   Reply With Quote
Old 01-05-2017, 11:54 PM   #2
Fishbulb's Avatar
Rewards Points: 110
The primary winding was functioning both as a standard primary winding of the power transformer and as an autotransformer itself. You could safely supply a whopping 80 VA to the GFCI receptacle until the water softener switched on. I suspect your heating blanket was slightly over that?
Fishbulb is offline   Reply With Quote
Old 01-06-2017, 12:31 AM   #3
Rewards Points: 1,508
Why would it not work ?
it is simply an auto-transfomer.
Not exactly best practice,
but it works.
not dangerous if not over loading the tranny.
Old 01-06-2017, 02:29 AM   #4
Watt Pusher
B-Nabs's Avatar
Rewards Points: 472
but it works.
But there's yer problem right there.
Old 01-06-2017, 03:22 AM   #5
What was the load ?
Old 01-06-2017, 09:17 AM   #6
Rewards Points: 3,006
Worked fine for years.....
I can hear the home owner now!
circuitman1, V-Dough and telsa like this.
The Following 2 Users Say Thank You to MechanicalDVR For This Useful Post:
Jlarson (01-06-2017), John Valdes (01-06-2017)
Old 01-06-2017, 09:58 AM   #7
Watt Pusher
B-Nabs's Avatar
Rewards Points: 472
What was the load ?
He said it was a PVC bending blanket, so at least 200W, which is already 250% over what that setup could handle. And those blankets can draw as much as 1500W depending on size.
Old 01-06-2017, 12:18 PM   #8
Jlarson's Avatar
Rewards Points: 4,074
What the hell are you doing blowing up such a fine piece of craftsmanship?
Someone worked really hard on that kludge.
MechanicalDVR and circuitman1 like this.
Old 01-06-2017, 05:49 PM   #9
Cletis wus ere !
