How do PLCs work? - Electrician Talk - Professional Electrical Contractors Forum
Like Tree1Likes
  • 1 Post By macmikeman
Old 11-08-2016, 08:18 AM   #1
Rewards Points: 50
Default How do PLCs work?
"...we can describe the function of a PLC in simple terms. The PLC takes inputs, performs logic on the inputs in the CPU and then turns on or off outputs based on that logic. We will get into more detail later but for now, think of it like this:
1. The CPU monitors the status of the inputs (ex. switch on, proximity sensor off, valve 40% open, etc.)
2. The CPU takes the information that it gets from the inputs, performs logic on the inputs
3. The CPU operates the outputs logic (ex. turn off motor, open valve, etc.)..."
Check out the rest of the post:
http://www.myplctraining.com/beginne...ction-to-plcs/
sdgates is offline   Reply With Quote
Old 11-08-2016, 09:58 AM   #2
MikeFL's Avatar
Rewards Points: 760
Are you asking a question?
Michael Gookin, President
GPS Timers
(833) GPS-TIME
Old 11-08-2016, 10:04 AM   #3
Rewards Points: 50
Hi Mike, no it wasn't intended to be a question. More of conversation starter and to share my thoughts
The Following User Says Thank You to sdgates For This Useful Post:
MikeFL (11-09-2016)
Old 11-08-2016, 10:05 AM   #4
Rewards Points: 50
But I'd love to hear your thoughts if you'd like to add your expertise to the mix?
Old 11-08-2016, 10:36 AM   #5
Rewards Points: 19,039
The plc is a box full of if, then, else, arrays,variables, and timers. It puts 1's and Zero's into variables at the request of the human coder.
MikeFL likes this.
If you start feeling the effects of a possible Corona infection, do not take Ibuprofen (ADVIL) to relieve pain, it increases the ability of the virus to replicate itself.
Old 11-08-2016, 12:25 PM   #6
Rewards Points: 2,088
a plc is just a computer with inputs outputs
Old 11-08-2016, 12:58 PM   #7
Rewards Points: 1,626
I agree this may be the simplest explanation. Continuing with the computer example, the keyboard keys are the inputs and the printer is the output.
In the middle is the program.
Old 11-08-2016, 05:26 PM   #8
backstay's Avatar
Rewards Points: 296
Actually, the PLC reads it's inputs, runs through the logic program(s) and writes to its outputs, basically. If you're going to be programming, I think it's important to understand how a PLC works, step by step.
So you want to become an apprentice in Canada... Vintage Sounds Electrician Apprentice Forum 52 08-07-2017 03:59 PM
Work in SW Virginia andytheham Looking For Work 0 03-19-2016 04:43 PM
Looking for Entry Level Electrical work in Blacksburg Roanoke VA area. andytheham Looking For Work 1 03-09-2016 06:59 PM
Getting my first car, advice to keep it clean when used for work commute ? David C Tools, Equipment and New Products 27 01-24-2016 10:39 PM
