how do you find out the value of Eol resistors - Page 2 - Electrician Talk - Professional Electrical Contractors Forum
Like Tree21Likes
Old 10-10-2018, 11:50 PM   #21
cabletie's Avatar
Rewards Points: 1,274
You need a picture of the duct detector wiring diagram or make/model number.
To me it looks like that's not the end of line resistor. It looks like it's tied into the remote test switch and or remote alarm. No telling what the value is supposed to be.
It is possible they put the end of line resistor in the duct detector. Maybe if it is tied in with a supervisor contact. To let you know someone left the cover off.
The EOL should really be in a more readily accessible device. But that's just my opinion.
LARMGUY and telsa like this.
Old 10-10-2018, 11:57 PM   #22
cabletie's Avatar
Originally Posted by eddy current View Post
Here we have laws that state only someone certified in fire alarm can touch a system that is in operation. Unfortunately no one enforces it but it is there.
Yes they should have a fire alarm tech troubleshooting it. I've done a lot of fire alarm, certainly don't know it all.
I think there is a rule that says after messing with it now, it all has to be retested? Maybe that's just playing with the program? This system probably doesn't have a program with an EOL though. I guess if it has no troubles, it's good to go?
Old 10-11-2018, 12:07 AM   #23
Rewards Points: 1,231
As long as he is careful and does not screw the system up best way to learn IMO.
Thatís definitely not the best way to learn. The best way to learn is to be instructed by an expert who will pass down his wisdom. Then go out and learn more on your own.
You say ďas long as he does not screw the system upĒ, how would he even know?
LARMGUY (10-11-2018)
Old 10-11-2018, 12:13 AM   #24
Light Bender
eddy current's Avatar
Rewards Points: 7,798
Here you canít touch it unless your certified and if you do, that device, the one before it and the one after it must be tested.
Also, just because the troubles are clear, that does not mean it will work, especially a conventional system. Thatís why they have to now be tested.
Old 10-11-2018, 12:23 AM   #25
Rewards Points: 1,925
That is a system sensor DNR addressable duct detector housing, presumably with a notifier addressable head. An SLC does not use an EOL resistor for supervision. The test switch is not supervised. The relay module installed nearby for HVAC shutdown does not supervise it's outputs and the SLC again does not use an EOL for supervision.
Why do you even have a resistor in there?
GroundFighter 78 likes this.
Old 10-11-2018, 12:28 AM   #26
Rewards Points: 1,788
Originally Posted by ElectricalArtist View Post
What I meant to ask is how do I know what resistor is supposed to be used
If the resistor is a EOL then you go by what the drawing calls for. (normally printed on the panel door which i believe you have posted a picture of)
If you understand that all the switchs (pull stations etc) are n/o then you have to realize that the panel will not be able to detect a broken wire. The fix for this problem was to install a resistor between the + and input at the end of the run (or loop from the last device back to the panel which is more expensive).
If the panel sees a resistance higher than 4.7k then it knows that there is a bad connection (how much higher before it sends a warning will be somewhere in the specs). If the panel sees a low resistance then it goes into alarm (a switch closing will make the resistance drop).
The alarm panel gives you a warnings and states the channel and the type of problem. This is probably why our boss told you to check the eol resistor.
I haven't done anything complicated just basic pull stations but that resistor doesn't look like its being used as a eol.
Gnome and telsa like this.
Old 10-11-2018, 01:10 AM   #27
Rewards Points: 44
IF it’s on a digital loop ( SLC loop ) then there should not be any EOL resistor.
If it’s connected to a monitor module then it needs a 4.7k EOL.
FF301 is offline   Reply With Quote
Old 10-11-2018, 01:11 AM   #28
Rewards Points: 44
Did you reuse the smoke head or is it new also ?
Old 10-11-2018, 01:13 AM   #29
Conservitum Americum
LARMGUY's Avatar
Rewards Points: 216
That’s definitely not the best way to learn. The best way to learn is to be instructed by an expert who will pass down his wisdom. Then go out and learn more on your own.
You say “as long as he does not screw the system up”, how would he even know?
I recently did a fire alarm inspection at a bank. There were several types of smoke detectors all over the bank. The old salt I was with saved my ass by telling me beforehand which detectors not to smoke because they released Halon. We had to devise a cardboard shield to keep the smoke from reaching them.
Yeah, sure, send a newby out by himself to fix a fire alarm system.
This:
and this:
Meter it then divide and conquer.
HackWork likes this.
Cowboy words of wisdom.
Old 10-11-2018, 02:01 AM   #30
360max's Avatar
Rewards Points: 1,234
Originally Posted by 360max View Post
....meaning no disrespect, but you shouldn’t be working on fire alarm systems alone
...and how does he know if he screwed the system up? This isn’t a switch circuit where the light won’t work, it’s a life safety system that HAS to work properly when he walks away. . JMHO
Old 10-11-2018, 08:53 AM   #31
Rewards Points: 44
someone with experience should be doing this and teaching you.
HackWork and Signal1 like this.
Old 10-11-2018, 04:13 PM   #32
Rewards Points: 1,361
Old 10-11-2018, 04:53 PM   #33
MikeFL's Avatar
Rewards Points: 598
Originally Posted by drsparky View Post
4.7K is common for a EOL resistor, the one in the photos is 5600 ohms. Put the correct resistor in and all will be well. Yellow Violet Red.
This was Post #9 and OP kept going on saying he doesn't know what size resistor is supposed to be in there.
color me confused.
Michael Gookin, President
GPS Timers
(833) GPS-TIME
Old 10-11-2018, 05:27 PM   #34
Rewards Points: 1,972
48 years of doing this work and based on MY EXPERIENCE. IMO nothing beats hands on trying to troubleshoot a problem and KNOWING WHO TO CALl be it the manufacturer, or an associate. Add to that the almost unlimited knowledge available on the web and an electrician should be able to work through some of the toughest troubleshooting problems.
This site alone should be a major help to those trying to solve problems.
Old 10-11-2018, 05:34 PM   #35
I disagree. Fire alarm is life safety.
So are generators, ATS, Fire Pumps and you tell me working on a 4000 amp circuit breaker that won't close is any less a problem if an electrician screws it up and the CB blows up.
I have worked on countless systems that are critical to buildings and by reading and understanding how components work was able to fix, repair or determine if the equipment needs replacement.
Here fire alarm systems require electricians that are certified as well. A friend now retired that serviced fire alarms for years told me the certifications were put in place by manufacturers and large EC's to try and cut smaller contractors out of the FA end of the business. No idea if that is true.
Old 10-11-2018, 05:36 PM   #36
I know, Brian. That's the problem, you have this "I did it myself, so that's the best way" mentality.
Well I am telling you right now, you are wrong.
I am not saying not to try things on your own. That is great, and there is a time and place. But nothing beats gleaning the priceless information from the hundreds of other people who have been in your shoes beforehand, and passed that information along.
After that, then you can try it out yourself. But there is no reason to handicap yourself by not accepting information and training just because you want to pound your chest and tell everyone that you did it yourself.
Sure, but that doesn't mean that said electrician can't benefit from excellent training.
This site is not here to help unqualified people work on life-safety systems that they clearly do not understand, and have no way of knowing whether the system still works when they leave. Even the OP agrees to that.
Old 10-11-2018, 05:41 PM   #37
Hack Never meant to say having a good teacher is not helpful or important BUT FOR ME nothing has helped me more than having my feet to the fire and having to fix a problem.
It has been years since I worked on fire alarm systems and they have drastically changed. From what I have seen with newer FA systems you need the software to make any changes.
Old 10-11-2018, 07:01 PM   #38
Light Bender
Critical to buildings is not as important as critical to life safety of the tenants.
Yes working on electrical is dangerous as well but we are talking about a system where it's whole purpose is to save lives. The main idea is that once a fire alarm system is installed, tested and operational, NO ONE can alter it unless they are trained and certified to do so. This system must also be tested thoroughly every year to ensure it will work as intended, to get people out of a burning building.
Here the certification is put in place by the fire marshal for the province, not the manufacturers. We have two different certs that are both recognized by the fire marshal, has nothing to do with manufacturers at all.
Old 10-11-2018, 07:49 PM   #39
Brian you are use to industrial so the rules are a little more blurred due to self insurance. A lot of the stuff you work with is not off the shelf standard equipment so you have to get use to learning quickly and know how to test your own work.
In this case i have to agree that the OP is out of his depth if doesn't understand the basics. On a good note the panel is fairly smart and will show troubles and make annoying bleeping sounds until someone comes along and fixes the problems.
brian john likes this.
Old 10-13-2018, 05:56 AM   #40
Rewards Points: 446
....meaning no disrespect, but you shouldnít be working on fire alarm systems alone
exactly correct.
farmantenna is offline   Reply With Quote
Trying to find a socket glen1971 Tools, Equipment and New Products 26 09-18-2018 09:02 AM
Find me a light. MDShunk Lighting Design 40 04-13-2018 08:06 PM
CEC 2012 - How to find resistance of a particular length of solid wire snapper007 Canadian Electrical Forum 31 11-11-2017 10:16 PM
How to find pay scale??? jayceew24 Electrician Apprentice Forum 5 10-29-2017 03:25 PM
Where can I find electricians that really want to make the money? inphaze New Member Introductions 44 12-02-2016 02:33 PM
