How does grounding affect Wi-fi? - Electrician Talk - Professional Electrical Contractors Forum
Old 09-06-2012, 02:12 AM   #1
carryyourbooks's Avatar
Rewards Points: 1,292
Default How does grounding affect Wi-fi?
a question from a buddy of mine:
Here's a question I don't have the answer to, regarding my own house.
Most of the outlets aren't grounded, a few are, and the cheezy little things you plug into your outlets, surge protectors, etc, say that my grounded outlets are grounded, and my non grounded outlets aren't.
I have hell with wifi in this house, more than 15' away, strait shot, no walls, you barely get a signal.. I have no other electrical issues with appliances, computers, etc.. (had 10+ different devices, not a wifi device problem, and current one has a 2 prong power plug)
My outlets in the garage work fine if I plug an extension cord into them to the wifi device, I can cover the entire house. In fact, it works almost that well plugged into my generator..
Here's what's prompted me to readdress this..
I am working on a clients medium-end UPS battery backup unit. It is throwing a code for "site wiring fault' on my grounded outlets..
It works fine in the garage. The instruction manual info for this code is as follows:
Site Wiring Problem
(Alarm 194)
Continuous Alarm
An alarm triggers when the
difference between ground and
neutral voltage is >15V.
Have a qualified electrician correct the wiring
problem. If the UPS is not wired with a neutral
wire, Site Fault should be disabled in the
Settings menu (see page 36).
is it possible that at some point someone put 3prong outlets in and ran the ground to a stud, or the foundation and my cheezy ground tester is seeing a ground and this device isn't?
What other problems can I look for.
I have not tried every grounded outlet in the house with this UPS, but about 5 with the same results, the garage being the exception..
ideas?
carryyourbooks is offline   Reply With Quote
Old 09-06-2012, 08:46 AM   #2
RIP 1959-2015
HARRY304E's Avatar
Rewards Points: 1,344
Site Wiring Problem
(Alarm 194)
Continuous Alarm
ideas?
You need a good tester to pick up false grounds.
like this one.......http://www.idealindustries.com/prodD...?prodId=61-165
Old 09-06-2012, 09:02 AM   #3
DGFVT
John's Avatar
Rewards Points: 176
I will second that. Also it sounds like you need to spend some quality time on you home wiring system.
R.E.D.
Old 09-06-2012, 09:28 AM   #4
Seems to me that you have a few issues. I'm not sure the wifi is related to the electrical issue. Electrical aside I would double check that nothing else is using your router's frequency.
Cujo is offline   Reply With Quote
Old 09-06-2012, 09:32 AM   #5
Your router only has a 2 prong plug right?
The NEC is the MINIMUM standard.
Bbsound is offline   Reply With Quote
The Following User Says Thank You to Bbsound For This Useful Post:
BBQ (09-08-2012)
Old 09-06-2012, 10:20 AM   #6
its not my house. it is a friend of mine's house. he also rents and the LL probably is not gonna spend money if he doesn't have to.
Old 09-06-2012, 11:09 AM   #7
Rewards Points: 1,006
You don't need a Sure-Test to measure the voltage difference between neutral and ground at a recep. Check several receps on different circuits to see if the fault is common or isolated to one or more circuits. Proceed accordingly. I'd be suspicious of a dropped or failing service neutral.
__________
Was born in HACKensack, NJ
CraigV is offline   Reply With Quote
Old 09-06-2012, 01:07 PM   #8
Rewards Points: 268
At low radio frequencies, like in the AM broadcast band, Mother Earth is one half of the broadcast antenna system. At high radio frequencies, like Wi-fi frequencies Mother Earth is no longer a factor. So a bad or missing EGC should not affect Wi-fi reception.
Speedskater is offline   Reply With Quote
Old 09-06-2012, 01:34 PM   #9
aDudeInPhx's Avatar
Rewards Points: 268
Have you tried a different wireless router?
Edit: never mind I reread your op.
aDudeInPhx is offline   Reply With Quote
Old 09-07-2012, 09:06 PM   #10
JohnR's Avatar
I suspect the neutrals at the panel may be loose, or the grounds.
Your wifi N runs at either 2.4 ghz or 5.0 ghz, make sure that he doesn't have a cordless phone on the 2.4 band. Check for other wifi in the area as well.
Signed out.
Old 09-07-2012, 10:00 PM   #11
Coffee drinking member
Wirenuting's Avatar
Rewards Points: 7,572
Been using this for years. Even before Ideal bought them out.
Old 09-08-2012, 05:45 AM   #12
BBQ
Salty Member
BBQ's Avatar
Worth repeating.
I doubt grounding or neutrals have anything to do with it at all.
VFD Domino Affect GEORGE D PLCs, VFDs, Motors and Controls 5 05-11-2012 09:12 PM
Grounding jack756 NEC Code Forum 10 03-15-2011 11:36 PM
Replacing non-grounding receptacles with grounding Gamit General Electrical Discussion 31 01-10-2011 10:34 PM
How would this affect your bottom line. brian john Business, Marketing, and Sales 11 03-22-2009 03:20 PM
Grounding? calimurray NEC Code Forum 13 04-29-2008 02:56 AM
