How else can you correct this ? - Electrician Talk - Professional Electrical Contractors Forum
Old 06-06-2013, 09:00 PM   #1
felonious smile.
Shockdoc's Avatar
Rewards Points: 572
Default How else can you correct this ?
Ran into this during a rewire, my only goof is I ran one 20 amp ckt from panel for whirlpool, I added a cable from the vanity GFCI ckt for the heater, it was too late to run another HR for the heater
How else can you correct this ?-imagejpeg_3-3-.jpg   How else can you correct this ?-imagejpeg_4-3-.jpg
Old 06-06-2013, 09:04 PM   #2
AlbertaBeef's Avatar
Rewards Points: 554
Firstly by not admitting to it on a forum.
AlbertaBeef is offline   Reply With Quote
Old 06-06-2013, 09:08 PM   #3
I_get_shocked's Avatar
Rewards Points: 516
(2) 12-2s in a handybox??
last shocked on 6/24
I_get_shocked is offline   Reply With Quote
Old 06-06-2013, 09:09 PM   #4
felonious smile.
Shockdoc's Avatar
Rewards Points: 572
It's not like he'll be blowdrying his hair and taking a heated bath at the same time..
Old 06-06-2013, 09:11 PM   #5
felonious smile.
Shockdoc's Avatar
Rewards Points: 572
Unfortunately, I had to remove the access cover in order to retract the existing octagon box, the handy box was the smallest of smalls that would fit in there easily.
Old 06-06-2013, 09:14 PM   #6
drspec's Avatar
Rewards Points: 1,116
I would have screwed a box with a bracket to the inside lip of the access door.
Where's the GFCI protection? I know it's not a mwbc, but did you use handle ties at the panel? May not be required, but I think I would do it.
Old 06-06-2013, 09:19 PM   #7
felonious smile.
Shockdoc's Avatar
Rewards Points: 572
I took the existing opening a foot away from the tub and turned it into a HR and deadfront for the motor, I have two GE slims next to each other with tie.
Old 06-06-2013, 09:33 PM   #8
Florida resident
ampman's Avatar
Location: Florida , if your not here you're somewhere else
Rewards Points: 1,604
i would have screwed a box with a bracket to the inside lip of the access door.
Where's the gfci protection? I know it's not a mwbc, but did you use handle ties at the panel? May not be required, but i think i would do it.
210.7
for lunch I had three cans of alphabet soup then afterwards I had a huge vowel movement
ampman is offline   Reply With Quote
Old 06-06-2013, 09:49 PM   #9
NJ-IEC
Magnettica's Avatar
Rewards Points: 424
Tie the GFCI circuit into the main breaker lugs (100 amp or more) so the blow dryer and jacuzzi heater will never trip. Finished. Cash the check asap just in case. Do not sign anything either.
Old 06-06-2013, 09:52 PM   #10
drspec's Avatar
Originally Posted by ampman View Post
210.7
I thought it was required but wasn't 100% sure.
Thanks.
Old 06-06-2013, 10:00 PM   #11
felonious smile.
Shockdoc's Avatar
Rewards Points: 572
That's pretty much what the last guy did except for using a 30 amp breaker on 12/2 BX and a GFCI at the panel for protection.
Old 06-06-2013, 10:02 PM   #12
Florida resident
ampman's Avatar
and they can cook their hotdogs to
The Following User Says Thank You to ampman For This Useful Post:
Magnettica (06-06-2013)
Old 06-06-2013, 10:04 PM   #13
RGH
RGH's Avatar
Rewards Points: 2,044
gotta love pool/spa guys....
I rather be fishing......
RGH is offline   Reply With Quote
Old 06-06-2013, 10:08 PM   #14
felonious smile.
Shockdoc's Avatar
Rewards Points: 572
This is Long Island style remodeling where the contractor hires a $200 a day laid off union employee as his electrician, How do I know this ? Schotchlok wirenuts, 5" boxes with mud rings , 12/2 BX and romex . Minimum code is 14 romex and plastic boxes in that jurisdiction, only ignorance would drive someone to use all that stuff.
The Following User Says Thank You to Shockdoc For This Useful Post:
RGH (06-06-2013)
Correct Fuse rcd General Electrical Discussion 6 11-28-2011 03:05 PM
This can't be correct zwodubber Off Topic (Non Trade) 16 05-12-2011 06:11 PM
correct ups install? garfield General Electrical Discussion 27 02-26-2011 02:10 AM
i am needing to know if i got the following correct new guy General Electrical Discussion 59 10-01-2010 03:07 PM
