How old is this wire? - Electrician Talk - Professional Electrical Contractors Forum
Like Tree3Likes
  • 1 Post By Islander
  • 1 Post By Flyingsod
  • 1 Post By Signal1
Old 11-09-2016, 08:49 PM   #1
Islander's Avatar
Rewards Points: 630
Default How old is this wire?
Sorry, no pics, but I came across some old 12 / 2 wire today, and I haven't seen anything quite like it. The hot and neutral conductors had some form of plastic insulation (similar to NMD). Those, along with a stranded bond conductor, were wrapped with strands of thin paper or cloth. All of that was contained within a dark coloured heavier cloth that seemed rather sticky.
I'm guessing it is from the 50's or 60's, but I am not sure.
Oh, this is in western Canada, should that make a difference.
Wattson likes this.
Islander is offline   Reply With Quote
Old 11-09-2016, 09:01 PM   #2
Rewards Points: 14,255
I have seen it before but not often. I'm thinking 60's because it does have a bond wire.
Old 11-09-2016, 09:17 PM   #3
Rewards Points: 114
Sounds like it might be MI mineral insulated. That stuff is great. Rodents don't like it the way they like Romex.
Old 11-10-2016, 12:50 PM   #4
Rewards Points: 416
Late sixties, early seventies had a braided outer cover that seemed impregnated with tar and paper inner.
some green, orange, grey
mitch65 is offline   Reply With Quote
Old 11-10-2016, 02:17 PM   #5
Gold Pliers Champion
Signal1's Avatar
Rewards Points: 2,366
MI Cable looks like copper tubing (photo from Mike Holt)
What the OP has sounds like an earlier version of NM before they started using a thermoplastic sheath. It was a woven/braided cloth coated with a waxy substance to make it moisture resistant.
50's or 60's sounds about right.
Flyingsod likes this.
Signal1 is online now   Reply With Quote
The Following User Says Thank You to Signal1 For This Useful Post:
Flyingsod (11-11-2016)
Old 11-10-2016, 02:31 PM   #6
Islander's Avatar
Rewards Points: 630
It was the stranded bond wire that had me wondering. I've seen other variations of cloth covered NM, but every one of them had solid bond wires.
Thanks, everyone!
Old 11-10-2016, 02:55 PM   #7
canbug's Avatar
Rewards Points: 1,874
I'm guessing 40s to 50s, maybe a bit earlier. I've seen and worked with it quit a bit. Reno's in older homes. Your hands end up pretty dirty and you need a sharp knife to cut that outer jacket.
Tim
canbug is online now   Reply With Quote
Old 11-10-2016, 03:09 PM   #8
MikeFL's Avatar
Rewards Points: 622
My house was built in '46 and was full of it until I gutted the whole building. It's good stuff. If it weren't for that federal pacific panel on fire it'd probably still be in there.
Michael Gookin, President
GPS Timers
(833) GPS-TIME
Old 11-10-2016, 05:37 PM   #9
Rewards Points: 416
missed the stranded bond wire part
Old 11-11-2016, 11:17 AM   #10
Rewards Points: 52
That pic is called MI cable. Mineral Insulated. I've never worked with it. Never even seen it.
TRurak is offline   Reply With Quote
Old 11-11-2016, 11:23 AM   #11
Used as heat tracing, primarily industrial temperature maintenance. Also used as wiring in plenums but rarely.
Old 11-11-2016, 02:55 PM   #12
Signal1's Avatar
It is used when a very high fire rating and survivability to attack by fire is required.
Some examples of where I have used it is to feed elevator machine rooms in several skyscrapers, generator feeds to the transfer switch at Boston's Children's Hospital, fire pumps etc.
What you see in that pic is three 3-phase 4w feeders, probably from an emergency distribution panel.
It is not too hard to work with if you invest in the right tools, mainly the sheath removal tool. Kind of works like a can opener.
Old 11-11-2016, 11:00 PM   #13
wcord's Avatar
Rewards Points: 1,666
And you have to make sure absolutely no moisture gets into the magnesium oxide
Old 11-11-2016, 11:04 PM   #14
wcord's Avatar
The tar and paper stranded ground started to show up in Manitoba around 55 or so.
And since grounded receptacles were not common, most electricians would bond the ground and cut off the tail ( some just cut the ground right where it came into the box, forget bonding it)
Old 11-11-2016, 11:38 PM   #15
CADPoint's Avatar
Rewards Points: 1,838
Tim
I'm in a house built in 44', that's all the house was wired with, neutral and hot
in rubber with tar paper. But the copper was brazed/ dipped over aluminum.
never had any electrical problems just had no three prong plugs in the house...
Guess I should fix the rest of the situations to pass a home inspection...
If you are even thirsty, you are two quarts low.
Old 11-12-2016, 09:29 AM   #16
Service Call's Avatar
Rewards Points: 32
We used MI on launch towers, where as said before, has a high heat/flame tolerance.
Old 11-12-2016, 01:40 PM   #17
Rewards Points: 3,044
I recall using that type cable as a kid. It would stick together from the tar in the jacket when you tried to reel it out. Left your hands black and sticky as well. Never realized it went back into the 1940s.
Old 11-14-2016, 03:52 PM   #18
Rewards Points: 334
Some of that old cloth looking stuff had asbestos in it, so be careful.
This is a decent guide to knowing what you are working with when you come across old wiring.
http://inspectapedia.com/electric/Ol...#Asbestos_Wire
16 AWG wire ampacity at higher temperatures Paul Kraemer General Electrical Discussion 5 10-13-2016 06:41 PM
is it OK to use the wire connector to connect the ground wire inside the drop ceiling mike883 General Electrical Discussion 29 07-20-2016 01:37 PM
Branch circuit wire for a 12v dc off grid solar cabin Off Grid Alternative Energy Forum 14 05-12-2016 09:13 AM
Wire Strippers for #18 stranded 2 conductor !Tom Tools, Equipment and New Products 22 05-04-2016 09:22 PM
8ga Aluminum Oven Wire vs 8ga Copper Wire? savatreatabvr General Electrical Discussion 17 01-13-2016 08:57 AM
