How severe is a neutral shock? - Page 6 - Electrician Talk - Professional Electrical Contractors Forum
Like Tree94Likes
Old 12-07-2016, 11:47 PM   #101
Semi-Ret Electrician's Avatar
Rewards Points: 486
Originally Posted by Essex View Post
There are many variables but the fundamental fact is that the intensity is linked to the amperage. Not the voltage.
Essex, that is true if you're talking about static electricity or 20KV from a CRT power supply etc. where there is not enough energy (current) to cause electrocution.
But as a practical matter in electrical work there is always plenty of current available and the higher the voltage the worse the danger.
Consider a 200AHR car battery, there is plenty of current available but at 12V you won't get shocked or electrocuted.
Old 12-08-2016, 03:14 AM   #102
Retired Account
Rewards Points: 14,650
Our skin R prevents us from feeling low V, ...... V and R being two legs of a three legged stool.
Old 12-08-2016, 08:13 PM   #103
Rewards Points: 1,972
The issue with this thread has become that Essex does not understand this, as he is NO ELECTRICIAN.
HackWork (12-08-2016)
Old 12-08-2016, 08:34 PM   #104
Essex's Avatar
Rewards Points: 466
Default How severe is a neutral shock?
I am so honoured that I am always on your mind.
It kinda turns me on too. Keep it up
Life is too short to get angry.
Essex is offline   Reply With Quote
Old 12-08-2016, 11:16 PM   #105
Going_Commando's Avatar
Rewards Points: 1,542
Maybe the thoughts of a male responding to you were where the little tingles came from. Sure as hell aint from a water heater like you said it was.
Old 12-09-2016, 12:29 AM   #106
corn-fused
papaotis's Avatar
Rewards Points: 620
wow, just wow. and all this time i thought he knew SOMETHING other than trolling. i could be WRONG.
The Following 2 Users Say Thank You to papaotis For This Useful Post:
Going_Commando (12-09-2016), HackWork (12-09-2016)
Old 12-09-2016, 04:41 AM   #107
Rewards Points: 102
Electrical shock is painful and deadly under all conditions and should only be performed under carefully controlled official business.
Oh man. You've just been waiting for a chance to come out with that one, haven't you?
green4now is offline   Reply With Quote
Old 12-09-2016, 12:07 PM   #108
Rewards Points: 18,213
Heckler! Every comedian has them,,,,,,,,,,,,,
JOBS GROWTH SOARS
RECORD WORKING
UNEMPLOYMENT 50-YEAR LOW
Drudge Report
Old 12-09-2016, 03:20 PM   #109
Rewards Points: 486
True CS ..Some electricians are too thin skinned and get "shocked" much too easily
chicken steve likes this.
Old 12-09-2016, 07:51 PM   #110
Band Member
emtnut's Avatar
Rewards Points: 2,004
I agree with you on that ... there are many variables ...
Like, Voltage and resistance.
I agree, it's hard to keep track of them all
Maybe we should take this further .. Maybe Ohms law is just a theorem
Old 12-09-2016, 08:46 PM   #111
Retired Account
1/2 century ago the medical community responded with 5ma as a detriment to adult heart rhythm
Before that 30ma was agreed on for the RCD
In either case, distinctly separate voltages that applied went unmentioned
emtnut likes this.
Old 12-09-2016, 09:14 PM   #112
Rewards Points: 36
No, what we think of as Ohm's Law is just the definition of resistance.
What Ohm really noticed experimentally was that for most materials under most conditions R was constant, independent of applied voltage.
Sent from my XT1585 using Tapatalk
inetdog is offline   Reply With Quote
Old 12-09-2016, 09:22 PM   #113
Band Member
emtnut's Avatar
And at a defined temperature
Old 12-09-2016, 09:23 PM   #114
Band Member
emtnut's Avatar
I thought there was a rule against gaying up a thread ???
brian john likes this.
Tags
neutral, pain, severe, shock
4 Wire bus duct used without neutral thermoelectric Code Violation Discussion 15 12-18-2016 10:30 AM
200amp underground service in Alberta, reduced neutral jingles4214 Residential Electrical Forum 10 11-05-2016 08:09 AM
Conductor Electek inc General Electrical Discussion 25 05-05-2016 12:02 AM
Neutral required to be ran to generator? lynes.nathan Canadian Electrical Forum 7 03-01-2016 10:10 PM
115 VAC disconnect - should I break both hot & neutral? Paul Kraemer General Electrical Discussion 11 01-22-2016 11:21 PM
