How to wire a timeclock and relay? - Electrician Talk - Professional Electrical Contractors Forum
Like Tree1Likes
  • 1 Post By telsa
Old 10-17-2016, 08:53 PM   #1
Rewards Points: 1,116
Default How to wire a timeclock and relay?
How would I wire a timeclock and relay under these circumstances?
So on the time clock diagram, 1 is the 120volts and 2 is the neutral? 4 on the timeclock would be hooked up to either 2 or 7 on the relay? and 3 and 6 on the relay would be the 240 volt load going out to the lights? Am I right on all this?
The answer would be 1 and 2? I'm really bad at this stuff, I really want to understand it though. Thanks for your help!
Edit: Okay, **** it one more example. Just so I can better understand. I'm not looking for answers, I truly just want to understand. Encase anyone thinks I'm doing this JUST for my homework. I want to be a good electrician!
Answer is 4 only right? I could explain why I came up with that but I don't want to turn this into an essay! Just want to make sure I understand it! thanks for your help
Old 10-17-2016, 08:56 PM   #2
Rewards Points: 52
If I understand it correctly ..... Its been a long day...... It would be #4 only
TRurak is offline   Reply With Quote
Old 10-17-2016, 08:59 PM   #3
Rewards Points: 52
On the first one I think L1 would connect to 1 and 4 and L2 would connect to 2.
Don't ever feel bad or ashamed to ask questions even if you think they are simple. Everyone on the this forum started out at some point with no experience. We've all asked questions. I think it's refreshing to see someone like yourself that really wants to understand the why and how of everything we do in this trade.
The Following User Says Thank You to TRurak For This Useful Post:
JasonCo (10-17-2016)
Old 10-17-2016, 09:02 PM   #4
Watt Pusher
B-Nabs's Avatar
Rewards Points: 474
Either that or L1 to 1 and 3 and L2 to 2. Both would work.
Old 10-17-2016, 09:07 PM   #5
Appreciate it man, I look up to the people on here who spend their time helping others on pretty much a daily basis. Not only does it help people like me, but it keeps yourself super sharp. The best way to stay sharp is to teach. My goal is to really understand the theory behind everything, so it'll make answering questions and troubleshooting much easier. By the way, I'm going to update the first image with the answer choices. There is no 1,2 and 4. I haven't given myself enough time to analyze your answer, I just want to update it real fast so you know!
Edit: updated
Old 10-17-2016, 09:19 PM   #6
Rewards Points: 52
I'm assuming the control circuit is the same circuit as the power for the clock
Old 10-17-2016, 09:27 PM   #7
So L1 to 1 and 3. Meaning L1 would go to 1 on the timeclock and 3 would go to 3 on the relay? and L2 is 2 on the timeclock?
Also, how would it work on the other way... If he puts the load on the normally closed (4) on the relay, then the lights would have constant power when the timeclock is off. Am I wrong or just misunderstanding his answer?
Old 10-17-2016, 09:32 PM   #8
Watt Pusher
B-Nabs's Avatar
Rewards Points: 474
No, I mean L1 (hot) would go to both 1 and 3 on the time clock. L2 (neutral) would go to 2 on the time clock, and also to either 2 or 7 on the relay coil. Then you would connect from terminal 4 on the time clock to either 7 or 2 on the relay (whichever you didn't connect to neutral). Then the 240 power goes on 1 and 8 of the relay, and the 240 load goes on 3 and 6.
The Following User Says Thank You to B-Nabs For This Useful Post:
Old 10-17-2016, 09:36 PM   #9
Okay awesome, I understand now what you are saying and how it all fits together to make it work. Only problem is, there is no answer choice for that..
Answer choices are:
a. 3 & 4
b. 1 & 3
c. 1 & 4
d. 2 & 3
e. 1 & 2
Old 10-17-2016, 09:37 PM   #10
Watt Pusher
B-Nabs's Avatar
Rewards Points: 474
Yes, I noticed that.
Old 10-17-2016, 09:39 PM   #11
Old 10-17-2016, 09:48 PM   #12
Rewards Points: 1,369
Yea, nice try Al Qaeda
Just kidding
Old 10-17-2016, 09:50 PM   #13
Alright i understand now, the answer is 1 and 2. Just used simple process of elimination, none of the other answer choices make sense. Thanks for all the help! Fully understand how to wire relays and time-clocks now. Thanks a bunch guys
Old 10-17-2016, 10:00 PM   #14
Band Member
emtnut's Avatar
Rewards Points: 2,020
1 and 2 on the first one, 4 only on the second
Old 10-17-2016, 10:09 PM   #15
Thanks, yep I turned it in just a bit ago and both were correct. Appreciate the help!
Old 10-17-2016, 10:16 PM   #16
Band Member
emtnut's Avatar
You're answering the question, and designing the rest of the circuit
Old 10-17-2016, 10:29 PM   #17
Watt Pusher
B-Nabs's Avatar
Rewards Points: 474
Yeah, I got carried away.
Old 10-17-2016, 10:30 PM   #18
Watt Pusher
B-Nabs's Avatar
Rewards Points: 474
He said he wanted to understand... 🤗
Old 10-17-2016, 10:40 PM   #19
Rewards Points: 26,610
I hate homework.
Especially someone else's.
John Valdes likes this.
