Ideas? Feeding soffit lights from existing wall mount location... - Page 2 - Electrician Talk - Professional Electrical Contractors Forum
Like Tree20Likes
Old 07-23-2016, 09:34 PM   #21
Big nosed attic troll
Majewski's Avatar
Rewards Points: 2,774
These things are life savers sometimes!
Old 07-23-2016, 11:29 PM   #22
A Little Short's Avatar
Rewards Points: 966
I actually have that issue right now. A good customer of mine wants to add a 3 way switch system to a stairwell, currently there is only a switch at the top of the stairs. It will be a lot of work to hardwire it and I don't feel like doing it.
Tell me what I need!
First go here
and get the Lutron RF switch. It's the same thing as the Caseta only cheaper. Also doesn't need a neutral. You can get it at Amazon but this place is cheaper.
Then go to Amazon and get the Pico remote
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Then the wall bracket
And if you want the Claro wall plate they have it as an "add on item" which is usually cheaper than buying it locally
Take the RF switch and replace the existing SP switch
Mount the wall bracket where you want the second switch
Insert the Pico and put on the wall plate
Looks just like a wired switch, only Decora
Look at the install sheet for programming the Pico.
But I think you first go to the RF switch and hold down the "off" button for about 6 secs until the LED blinks
Then go to the Pico and hold down the "off" button until the light fixture blinks three times
Done!
I may have the buttons mixed up that you program with but it's either the "up" or "down" button.
HackWork, splatz and Majewski like this.
The Following 2 Users Say Thank You to A Little Short For This Useful Post:
Majewski (07-23-2016), splatz (07-24-2016)
Old 07-24-2016, 02:08 AM   #23
Trained Monkey
TheLivingBubba's Avatar
Rewards Points: 652
Originally Posted by A Little Short View Post
First go here
Done!
Tip, program the pico before you install it in the new location. ESPECIALLY when setting the switch in an attic to mount the pico on a shallow location like a pocket door.
TheLivingBubba is offline   Reply With Quote
Old 07-24-2016, 08:06 AM   #24
neutral member
readydave8's Avatar
Rewards Points: 98
whoa, back up
if that vinyl siding is long horizontal that has nail flange at top and snaps together at bottom, it is extremely easy to remove and reinstall (as someone else mentioned)
so I would not make job more complicated than it needs to be, simple switch is better unless customer is the type that wants complicated stuff to play with (and cuss it or the electrician when it fails)
Dave Ruth
Old 07-24-2016, 08:50 AM   #25
MikeFL's Avatar
Rewards Points: 506
Originally Posted by readydave8 View Post
whoa, back up
Make sure you don't drive the nails back in tight. The siding needs to be able to slide back and forth for expansion and contraction; that's why the nail holes are slotted. Drive them hard and the siding buckles when the temperature changes.
readydave8 likes this.
Michael Gookin, President
GPS Timers
(833) GPS-TIME
readydave8 (07-24-2016)
Old 07-24-2016, 08:57 AM   #26
Rewards Points: 2,924
whoa, back up
All but the odd shaped panels that resemble cedar shakes are easy to remove and reapply. The imitation shingle panels just take a little practice.
Old 07-24-2016, 08:57 AM   #27
Rewards Points: 13,647
whoa, back up
Thanks. Never really tried it. Might be easy enough to peel back the vinyl and trench through the styrofoam.
Old 07-24-2016, 05:00 PM   #28
220/221's Avatar
Rewards Points: 4,090
If you can do shingles/roofing, remove some shingles, cut an opening in the roof deck and you will have access to the soffit and the wall.
readydave8 and Majewski like this.
Venting, not HVAC 220/221 General Electrical Discussion 6 07-07-2016 11:09 AM
Hanging heavy lights on a furred wall. Year_Zero General Electrical Discussion 16 02-25-2016 07:38 PM
