I'm a roller, A high roller baby. - Electrician Talk - Professional Electrical Contractors Forum
Old 05-23-2014, 04:20 PM   #1
Sideways Sparky
farlsincharge's Avatar
Rewards Points: 1,168
Default I'm a roller, A high roller baby.
This is the third time I have rolled phases to balance a motor
Brand new Baldor 480v 60 hp, driving a centrifugal pump. FLA 72 SF 1.15. Tripping the conservative 75a O/L's. I bumped em to 80.
When I got there 78, 78, 66
First roll 72, 72, 81
Second and final roll 74.5, 75, 75.5
farlsincharge is offline   Reply With Quote
The Following 2 Users Say Thank You to farlsincharge For This Useful Post:
ampman (05-25-2014), Moonshot180 (05-24-2014)
Old 05-23-2014, 06:18 PM   #2
EBFD6's Avatar
Rewards Points: 1,014
I can honestly say I have no idea what you are talking about.
What is "rolling phases"? I have never heard this term.
Also, if your motor FLA is 72, and you are drawing 75+, you have a problem. You didn't fix it by "rolling phases" (whatever that means). Time to do a little more digging. Maybe the motor is too small for the application, or there is some other kind of mechanical issue with the system, but you shouldn't be drawing FLA under normal circumstances.
EBFD6 is offline   Reply With Quote
Old 05-23-2014, 06:33 PM   #3
Spaghetti Cleaner
Rewards Points: 540
Rolling is moving A to B, B to C, C to A, etc
Thread shorter.
sarness is offline   Reply With Quote
The Following User Says Thank You to sarness For This Useful Post:
Old 05-23-2014, 07:42 PM   #4
Rewards Points: 77
This may be a stupid question, but doesn't that reverse the direction of the motor?
Andy17 is offline   Reply With Quote
Old 05-23-2014, 07:50 PM   #5
Legacyelectric's Avatar
A-B or B-C would. I'm hoping to learn something in this thread very soon
Legacyelectric is offline   Reply With Quote
Old 05-23-2014, 07:55 PM   #6
Rewards Points: 1,224
The motor rotation is not changed.
ABC=BCA=CAB as far as rotation goes.
Old 05-23-2014, 08:05 PM   #7
Rewards Points: 77
Cool, thanks! I didn't know that. Learned something new today! It's a good day with a 3 day weekend ta boot!
Old 05-23-2014, 08:19 PM   #8
Donuts > Fried Eggs
Big John's Avatar
Rewards Points: 300
Interesting. Jraef mentioned using the same solution when getting intermittent overcurrents on Y/Δ starters. If your voltages are the same, I'd be hard pressed to explain what was going on to balance current like that, but I'll keep that trick in my hat.
Always wear your gloves.
ampman (05-25-2014)
Old 05-23-2014, 08:34 PM   #9
Retired Account
Rewards Points: 14,650
here's a paper on dealing with motor current imbalance, referencing rolling phases...
Legacyelectric (05-23-2014)
Old 05-23-2014, 08:37 PM   #10
Rewards Points: 1,464
Current looks good,What is the voltage reading. i think the o/l s too low.
Old 05-23-2014, 08:38 PM   #11
Rewards Points: 256
It's because there are always imperfections in the motor, and there are always differences in phase voltages. So "rolling" helps to line up the two sets of conditions to hopefully compliment each other to achieve better current balance (i.e. motor nirvana...). You have 3 chances, hooking it up once and getting it right is, statistically, unlikely.
Doesn't always work, but it's free (other than time).
The Following 2 Users Say Thank You to JRaef For This Useful Post:
ampman (05-25-2014), Pete m. (05-23-2014)
Old 05-23-2014, 08:52 PM   #12
acro's Avatar
Rewards Points: 1,006
The imperfections in the motor are likely constant, but are the differences in the phase voltages? I would think not.
So the "fix" would be temporary, no?
acro is offline   Reply With Quote
Old 05-23-2014, 09:25 PM   #13
Rewards Points: 3,032
Submersible pump motors and hermetically sealed refrigeration compressors are notorious for needing to be rolled. It almost always helps, at least to some degree.
I've come back to some of these months or years later, rolled them again, and the original roll was still best.
In my experience, motors supplied by wye connected systems will benefit more from rolling that ∆ systems. It doesn't seem to matter much what internal connection the motor is.
meadow (05-25-2014)
Old 05-23-2014, 09:40 PM   #14
Donuts > Fried Eggs
Big John's Avatar
Rewards Points: 300
Originally Posted by JRaef View Post
It's because there are always imperfections in the motor, and there are always differences in phase voltages...
We don't test impedance, but there are tests we do that are directly dependent on impedance, and the expected deviation between phases we see is usually less than 1% for large (100HP+) motors. Most system voltages seem to be balanced within about the same range of 1%.
I don't doubt that it works, but I just can't figure how that solves current imbalances of 18%, which seems wicked high.
Farls, is there a chance you can get actual voltage measurements to go with those currents?
Old 05-23-2014, 09:48 PM   #15
Could it also be freq/waveform slight imperfections? I'm really struggling with this concept.
Old 05-23-2014, 09:49 PM   #16
Not doubting. Just trying to wrap my mind around it.
Old 05-23-2014, 11:44 PM   #17
Sideways Sparky
Voltage was perfectly stable at about 476 - 478. The impeller is improperly desiged and needs to be modified or changed. The people who built it have been made aware and agree.
In the mean time I have shut the pump in as much as I dare to get the current that low and I am comfortable with it.
When I first got there it was actually 94 94 78.
A little unrelated to this story but, I have found rolling can make a HUGE difference when using a rotophase.
Old 05-24-2014, 07:50 AM   #18
Hmacanada's Avatar
I never heard of rolling phases before.
I just assumed by moving phases you would reverse motor.
But it makes sense now by moving all 3.
Thanks for the info,
Have to put that in the vault could come in handy latter.
Sent from my iPhone using electriciantalk.com
Hmacanada is offline   Reply With Quote
Old 05-24-2014, 08:31 AM   #19
Rewards Points: 804
Rolling rolling rolling keep that phase rotation going.
OMG I've become Chicken Steve.
The Following User Says Thank You to Chris1971 For This Useful Post:
Classic_Toby (05-24-2014)
Old 05-24-2014, 09:17 AM   #20
LawnGuyLandSparky's Avatar
Rewards Points: 172
No you didn't, I didn't have to look up anything you wrote in the dictionary, or google it.
LB Roller Roger123 Tools, Equipment and New Products 7 01-26-2014 03:42 PM
Been to the Roller Rink lately? SVT CAMR Off Topic (Non Trade) 3 03-05-2013 12:11 AM
Roller Derby! MollyHatchet29 Off Topic (Non Trade) 51 09-14-2012 03:11 AM
Wanted: 555 bender roller unit cheezhd2008 Electrician Swap 0 05-14-2011 01:04 PM
roller switch? mattsilkwood General Electrical Discussion 7 05-15-2009 07:17 AM
