Induction motor wound rotor - Electrician Talk - Professional Electrical Contractors Forum
Old 01-27-2015, 03:30 AM   #1
Rewards Points: 72
Default Induction motor wound rotor
I have a quick question regarding the wound rotor configuration in an induction motor.
Is it short-circuited during operation? If so why? I kinda know a bit of the answer but just doesn't make any sense for me please give me a good explanation(short and to the point if possible). Thank you!
Cantafford is offline   Reply With Quote
Old 01-27-2015, 09:01 AM   #2
Rewards Points: 686
Short answer: it depends...
Applying different amounts of resistance to the rotor circuit changes the magnetics in the rotor, which changes the torque output of the motor. There are two ways of designing a WRIM control system, either for just soft starting or for continuous use under rotor resistance control.
If the design is intended to only be for soft starting and when done, the motor will run at full speed/torque, the resistors and components that change values are often not designed to be in the circuit continuously. If so, you MUST short out the rotor once it is finished accelerating or you will burn them out.
But in other designs, the ability to alter torque is used as an indirect speed control system. If that is the case, the components in the controller will be designed to handle continuous operation, so the only reason to short the rotor is if you want full torque and thus full speed out of the motor. You will not get that if there is any external resistance in the circuit.
guest (01-27-2015)
Wound rotor induction motors Vintage Sounds General Electrical Discussion 17 02-09-2015 05:08 PM
ac synchronous servo motor, magnet rotor industrial951 PLCs, VFDs, Motors and Controls 6 06-08-2013 12:50 PM
AC induction motor badjri General Electrical Discussion 5 07-20-2012 11:50 PM
Locked Rotor motor question John Kelly NEC Code Forum 3 06-14-2011 11:51 PM
motor drive control conical-rotor brake motors --help sparkie UK Electrical Forum 5 02-13-2009 05:57 PM
