Infrared inspection - Page 2 - Electrician Talk - Professional Electrical Contractors Forum
Like Tree11Likes
Old 07-24-2016, 06:54 PM   #21
Rewards Points: 131
I agree, IR testing services provided superb analysis for heat loss analysis, etc. but don't really belong in electrical equipment testing environments. We have done repairs based on tests done by these companies (they hired an electrician to open the panels, etc.) and purchased a mid-priced Testo unit to confirm analysis/repair. We mostly found no problems with the identified concern areas, but did identify other potential problem areas.
IR testing is good when a knowledgable electrician does the tests because he can more readily evaluate readings, perform additional tests, and make minor repairs, etc. at the same time.
One problem associated with IR testing is that most of the time, the (fixed) electrical load is too low to give an adequate IR reading on a bad connection, and a good visual inspection along with a physical check of wire connections, etc. is more useful.
khfiei is offline   Reply With Quote
Old 07-24-2016, 07:09 PM   #22
Rewards Points: 366
Thats why a repair should be completed by a firm that has experience dealing with this type of work that utilizes several methods to verify repairs.
1. FOP prior to and after repair.
2. Utilize a DLRO/Ductor/MIcro-ohm meter prior to and after repair.
3. Regular IR inspections
Brain John is offline   Reply With Quote
Old 07-24-2016, 07:12 PM   #23
Donuts > Fried Eggs
Big John's Avatar
Rewards Points: 300
One problem associated with IR testing is that most of the time, the (fixed) electrical load is too low to give an adequate IR reading on a bad connection....
I once had a customer seriously misunderstand what IR was all about and they scheduled a damn complete plant outage for me to show up and do my survey. Place usually drew about 30 megawatts, and I show up to discover they're running on minimal standby of a couple hundred kW.
IR is absolutely a valuable tool. Literally almost every survey I do, I find deficiencies. But I agree, someone has to know what they're looking at. I've seen fly-by-night outfits flag their own reflection as an electrical problem.
LuckyLuke likes this.
Always wear your gloves.
Brain John (07-24-2016)
Old 07-24-2016, 08:15 PM   #24
Rewards Points: 366
Read a Spec that required an IR at no load and full load. I tried to explain that at no load there is no temperature differential and all you get one color. It was spec'd so we got paid to do the IR twice.
Big John likes this.
Old 07-24-2016, 08:21 PM   #25
Trained Monkey
TheLivingBubba's Avatar
Rewards Points: 680
Could it have been to build a baseline for qualitative data? Track the loss of efficiency in equipment and try to establish a timeline for repairs and replacement?
Just throwing stuff at the wall wondering why.
TheLivingBubba is online now   Reply With Quote
Old 07-24-2016, 08:46 PM   #26
Donuts > Fried Eggs
Big John's Avatar
Rewards Points: 300
Originally Posted by TheLivingBubba View Post
Could it have been to build a baseline for qualitative data...?
It doesn't show anything. Surveying an energized piece of switchgear at no load might as well be like surveying a piece of sheetrock: There's no thermal gradient to see, barring small emissivity differences, it all looks like one color.
Just a case of folks writing boilerplate scopes.
The only time we see a couple surveys requested like that is one on the day of startup to find critical problems, and one several weeks later for more minor issues.
Old 07-26-2016, 01:05 AM   #27
Rewards Points: 698
Thank you for all the advice. I suppose I will proceed and see if I get the job. I can do the infrared scan and document the heat signatures of the components. If anything seems suspect we will do an fop test if appropriate. If the fop test varies by more than 50% we will recommend repair or replacement. I was looking at a dlor meter but I really don't know that I would use it enough to justify.
garfield is offline   Reply With Quote
Old 07-26-2016, 01:48 AM   #28
Rewards Points: 28
Default 2 things to remember..
You can gather all the know-how on doing a scan and how to convey what's there to your customer, but I think it's really important to have a fair amount of legalese in the report. CYA. Talk to your attorney about what to say.
Figure out how to roll the cost(s) of certifying your techs into the first job(s).
~48~ is offline   Reply With Quote
Old 07-26-2016, 03:09 AM   #29
Rewards Points: 3,006
Great advice.
Working under a homeowners permit? TechieBecky General Electrical Discussion 16 03-16-2016 01:26 AM
Infrared tube heater acro Off Topic (Non Trade) 9 02-24-2016 06:39 AM
