Infrared temp sensors - Electrician Talk - Professional Electrical Contractors Forum
Old 10-12-2018, 05:55 PM   #1
Beavis's Avatar
Rewards Points: 18
Default Infrared temp sensors
Can anyone recommend a great infrared temp sensor? I am reading shredded tire that also will have tire wire in it. I know the 2 materials are pretty far apart on the emissivity chart
Beavis is offline   Reply With Quote
Old 10-12-2018, 06:33 PM   #2
Rewards Points: 1,818
Is the wire dull or shinny after it has been shredded
Old 10-12-2018, 09:35 PM   #3
Beavis's Avatar
Rewards Points: 18
The shredded tire wire is fairly shiny. It comes out mixed with fiber and rubber. The temp circuit monitors the rubber and the plc turns the water on to regulate the temps. So add water to the mixture.
Old 10-12-2018, 10:03 PM   #4
Beavis's Avatar
Rewards Points: 18
There are a couple issues that I haven't been able to adjust out.
#1 I occasionally get a momentary signal overload which I believe is a more concentrated ball of the tire wire which has clumped together. I put a 2 second delay in the plc which has taken care of this... Mostly
#2 I have a constant +-15° variance in read temps. I need a little closer to +-5°. The target spot at the distance they are mounted is 4". This is after I adjusted the filter setting in the controller/panel meter.
Old 10-12-2018, 10:43 PM   #5
Does the accuracy improve if the lens is cleaned. I have seen 2 of these systems removed due to moisture on the lens
Old 10-15-2018, 08:25 AM   #6
Beavis's Avatar
Rewards Points: 18
That is a good question. I actually have 2 sensors installed about an 1 1/2" apart. They are both very new. Even so, the dusty environment is a concern so they are cleaned regularly. The 1st sensor is tied into the plc as described & the 2nd sensor is interlocked through aux contacts to shut down the infeed conveyor at 1 setpoint & turn on 'flood' at the 2nd setpoint. This is our "backup/failsafe sensor"
The 2 sensors together have the safe accuracy and have also been +- 10° of each other.
The questions you are asking are definitely giving me hope
Old 10-15-2018, 02:32 PM   #7
Rewards Points: 6,421
Are there self cleaning models available, much like the self cleaning pH probes?
Old 10-15-2018, 02:35 PM   #8
Beavis's Avatar
Rewards Points: 18
I have seen housings designed with an air purge on them.
Old 10-15-2018, 02:39 PM   #9
Yeah, my concern at this point is the supervision of the failsafe sensor that turns on flood coolant. It appears that it has none. Is there a fire system on this shredder, besides?
Old 10-15-2018, 02:47 PM   #10
Beavis's Avatar
Rewards Points: 18
Yes. There is also a separate fire suppression system on each shredder.
What I'm hoping for is a recommendation for an accurate IR sensor. I have omega, have heard similar reports about 'banner'. In the past have used exergen with an isolated transmitter, but I liked the idea of a analog cable that went straight from the sensor to the controller
Analog field sensors. Shielded field cables? Breakfasteatre Industrial Electrical Forum 6 06-14-2018 08:56 PM
Cove Heaters and Infrared Heaters splatz General Electrical Discussion 9 09-11-2017 09:37 AM
parallel motion sensors John M. General Electrical Discussion 4 04-21-2017 11:02 PM
Class II div II location, photo eyes and prox sensors Breakfasteatre Canadian Electrical Forum 8 10-13-2016 04:52 PM
Fluorescent Lights on GFCI Receptacle Temp power box TheLivingBubba General Electrical Discussion 13 03-22-2016 11:21 PM
