Installing 4" octagons in brick - Electrician Talk - Professional Electrical Contractors Forum
Old 09-19-2013, 06:12 PM   #1
felonious smile.
Shockdoc's Avatar
Rewards Points: 572
Default Installing 4" octagons in brick
I used 1 4" carbide holesaw and could'nt believe it drilled 2 out of 3 perfect holes in soft brick for octagon boxes, the last one was hard brick so it ended up getting pilot drilled and chipped. What are other methods used to recess a octy box in existing brick.
Old 09-19-2013, 06:18 PM   #2
animal lover /rat bastard
wildleg's Avatar
Rewards Points: 1,038
dynamite
The Following 2 Users Say Thank You to wildleg For This Useful Post:
Celtic (09-19-2013), daveEM (09-20-2013)
Old 09-19-2013, 06:18 PM   #3
Rest In Peace
aftershockews's Avatar
Rewards Points: 7,003
I will use a 1/4" bit to outline the hole and then use the chisel bit to break out the hole.
hammer and hand chisel to finish up.
Official troll magnet.
aftershockews is offline   Reply With Quote
Old 09-19-2013, 06:23 PM   #4
Hey how much that 4" carbide bit cost you?
TQuade is offline   Reply With Quote
Old 09-19-2013, 06:25 PM   #5
felonious smile.
Shockdoc's Avatar
Rewards Points: 572
bout $40 , it's still good for plaster .
Old 09-19-2013, 06:52 PM   #6
denny3992's Avatar
Rewards Points: 2,014
Why not use masonary box or a 3 1/4 octogon?
denny3992 is offline   Reply With Quote
Old 09-19-2013, 07:09 PM   #7
felonious smile.
Shockdoc's Avatar
Rewards Points: 572
cause when I show up at the job, that's whats on the truck, it's compliant and cheap .
Guys out here cut the nail ears off a 2x4 nail on and let the masons embed it in new brick. The old school did Gem boxes.
I always prefer a 4" fixture box for light fixtures.
Old 09-19-2013, 07:46 PM   #8
If it's new construction and it's just brick siding. I drill a hole at the exact centre of where I want the box. Then stub a wire outside 6 inches, flex it into an octagon box, then explain to the brickies exactly where the light is supposed to go. They brick it in the exact spot.
HadItUpToHere is offline   Reply With Quote
Old 09-19-2013, 07:53 PM   #9
I use a dry core bit on an 1 1/2 rotary hammer and seal around the box with mortar mix.
Linhawk is offline   Reply With Quote
The Following User Says Thank You to Linhawk For This Useful Post:
sbrn33 (09-20-2013)
Old 09-19-2013, 08:27 PM   #10
Rewards Points: 1,062
I never drill in block. I outline the box with a pencil and use a ball pean hammer to make an almost perfect hole.
It really is easy if you are not afraid to really nail it until you get a small hole broke through. And you must be in the web.
Then I chip away until the box fits in nice and neat.
Old 09-19-2013, 08:29 PM   #11
ponyboy's Avatar
Rewards Points: 709
Is it compliant to mount a fixture with 6-32 screws?
Old 09-19-2013, 09:37 PM   #12
Rewards Points: 25
If light fixture is less than 6 lbs
Nebelectrician is offline   Reply With Quote
Old 09-19-2013, 10:30 PM   #13
Maple_Syrup25's Avatar
Rewards Points: 782
i had to do that on a renovation for coach lights and used a 4" sds bit perfect fit. Drilled 1/4" holes into side of brick and used rawl plugs to fasten.
Maple_Syrup25 is offline   Reply With Quote
Old 09-20-2013, 06:22 AM   #14
felonious smile.
Shockdoc's Avatar
Rewards Points: 572
I'm not one of those guys, I'm the guy who ends up performing surgery on the old gem boxes embedded in brick to remove the rusted 6/32 screws.
Old 09-20-2013, 07:57 AM   #15
Rewards Points: 2,318
Here is the other issue about that. If you have new construction how many masons will be happy to install a 4" octagon masonry box in the brick. It would not be easy to install and make it look good.
I can't help it if I'm lucky
Old 09-20-2013, 09:30 AM   #16
BBQ
Salty Member
BBQ's Avatar
He said brick not block.
Old 09-20-2013, 12:14 PM   #17
Thanks Bob. I was going to correct my mistake, but you beat me to it.
Old 09-20-2013, 02:36 PM   #18
Rewards Points: 49
whats a gem box?
electricdrummer is offline   Reply With Quote
Old 09-20-2013, 07:24 PM   #19
Rewards Points: 455
I would use an octagon bit.
Nom Deplume is offline   Reply With Quote
license & exams: "residential/single-phase" v "journeyman" mikewillnot General Electrical Discussion 8 01-21-2015 07:43 PM
"electricians" advertising "recession pricing" "super low prices to fit your budget" lovethetrade General Electrical Discussion 17 11-30-2011 11:44 PM
SEC through brick wall alann53 Services and Service Equipment 24 12-10-2010 06:22 PM
Installing 6" RMC romexican General Electrical Discussion 38 08-12-2010 07:48 AM
Installing a security light to brick chestman General Electrical Discussion 8 12-05-2009 07:33 PM
