Integral door lock on GE disconnect - Electrician Talk - Professional Electrical Contractors Forum
Like Tree1Likes
  • 1 Post By MechanicalDVR
Old 05-28-2017, 02:14 PM   #1
cool cat
Rewards Points: 317
Default Integral door lock on GE disconnect
Installed a GE TG3224R fusible disconnect and wanted to check amperage and finally noticed that there is no way open it without turning it in the off position.Am I missing something most disconnects I'm accustomed to have a mechanism that is accessible on the outside usually slotted to be turned with a screwdriver and allows access to the interior of the disconnect for troubleshooting purposes.
Anybody know why this GE model does not appear to have this,or is there something i'm missing.
dogleg is offline   Reply With Quote
Old 05-28-2017, 02:23 PM   #2
Rewards Points: 222
I'm going from memory, but don't you have to turn it off, then open it, find the lever on the handle side, push down on it and turn it back on with it still open?
I distinctly remember this style switch.
Thats how I remember this switch.
Not to be confused with Square D's design (your description) with the slotted head on the right side that is turned with a screwdriver.
Old 05-28-2017, 02:29 PM   #3
Rewards Points: 3,006
You aren't missing anything the linkage is inside the box.
Old 05-28-2017, 02:36 PM   #4
cool cat
Rewards Points: 317
Yes ,that would work but this facility really cant be having the power shut down like that ,I was hoping for a better answer.Just wanted to check out the the fuses ,take an amp reading and connect the gec.Now Ill have to schedule an outage to install the grounding electrode conductor ,what a pain.
Old 05-28-2017, 02:41 PM   #5
cool cat
Rewards Points: 317
Not to mention the 2 screws that mounted the top door latch heads broke off about the 2cnd time I opened the latch.Geese no more from GE if I can help it.
Old 05-28-2017, 02:44 PM   #6
The Devil is often in the details.
backstay likes this.
Service disconnect for Hot tub (Chicago Code) JupoiUrzici General Electrical Discussion 2 12-22-2016 11:08 PM
480VAC Coil and 250VAC Rated Contact NJWVUGrad General Electrical Discussion 5 09-19-2016 03:58 PM
Spa Disconnect and fuse question DuskIndustries General Electrical Discussion 9 06-18-2016 09:28 AM
115 VAC disconnect - should I break both hot & neutral? Paul Kraemer General Electrical Discussion 11 01-22-2016 11:21 PM
