Isolation Transformers/ Auto-Transformers - Electrician Talk - Professional Electrical Contractors Forum
Like Tree12Likes
  • 2 Post By PlugsAndLights
  • 2 Post By telsa
  • 2 Post By brian john
  • 2 Post By dmxtothemax
  • 1 Post By brian john
  • 1 Post By Cl906um
  • 1 Post By Frank Mc
  • 1 Post By inetdog
Old 12-19-2016, 12:41 PM   #1
Rewards Points: 26
Default Isolation Transformers/ Auto-Transformers
Hey everybody, I had an interesting discussion about transformers over the weekend. Particularly the difference between Auto-Transformers and Isolation Transformers. I realize Isolation Transformers have no electrical connection between the primary and secondary windings, and are also bigger in size, but what other characteristics make it easy to identify an isolation transformer over an auto-transformer.
DerekS is offline   Reply With Quote
Old 12-19-2016, 02:10 PM   #2
Safety Pin Member
PlugsAndLights's Avatar
Rewards Points: 2,880
I'd look at the diagram on the nameplate first. Other info on the nameplate
would also give it away.
Wondering if I missed the point of the question.............
P&L
circuitman1 and DerekS like this.
Old 12-19-2016, 02:37 PM   #3
Rewards Points: 26,600
The connection diagram ?
Old 12-19-2016, 04:17 PM   #4
Rewards Points: 1,972
Most to Autotransformers are isolation transformers, just the connection is such that the secondary is connected to the primary and is used to boost (increaser) or buck (decrease) voltage typically in small steps. 120 to 24 isolation can be buck or boost depending as noted on the connections made in the field.
Boosting or bucking from 120 to 277 or 208 to 480 would require additional steel and copper or aluminum and therefore is not practical, as there is little to know cost savings,
micromind and DerekS like this.
Old 12-19-2016, 05:46 PM   #5
Cl906um's Avatar
Rewards Points: 1,206
Isolation transformer for surgery that monitor loss to ground or any loss for that matter?
Old 12-19-2016, 08:23 PM   #6
Rewards Points: 1,512
with an ohm meter you test for any continuity between promary and secondary windings, with isolation there should be none, but with auto-trasfomer there will be.
in other words auto = no isolation.
splatz and DerekS like this.
The Following User Says Thank You to dmxtothemax For This Useful Post:
DerekS (12-20-2016)
Old 12-19-2016, 11:26 PM   #7
While you are correct the question is broader than just an ungrounded isolation transformer used in operating rooms.
DerekS likes this.
Old 12-19-2016, 11:27 PM   #8
Yes but I can take an isolation and make it a Auto transformer. .
Old 12-20-2016, 07:00 PM   #9
Cl906um's Avatar
Was just wondering where his question was derived from. Kinda wondering why so vague.just thought I would put out one of its benefits used in the field.
brian john likes this.
Old 12-21-2016, 05:31 AM   #10
Frank Mc's Avatar
Rewards Points: 860
Not sure if i got this right , but i recall that an isolation transformer has a physical mechanical barrier between primary and secondary...??
DerekS likes this.
Fág an Bealach
Frank Mc is offline   Reply With Quote
Old 12-21-2016, 04:37 PM   #11
Rewards Points: 36
That would be a "high isolation" transformer. Typically including a grounded electrostatic shield between the windings. Minimizes capacitive coupling between windings but does nothing do anything for magnetic coupling (Duh!)
To get rid of differential mode noise you would have to add tuned filtering.
Sent from my XT1585 using Tapatalk
Frank Mc likes this.
inetdog is offline   Reply With Quote
vfd starting auto with no start signal fayc11 PLCs, VFDs, Motors and Controls 6 09-13-2016 03:02 PM
are the new transformer's wire lug come with the transformers? mike883 General Electrical Discussion 15 05-08-2016 08:20 PM
Three Phase Transformers - Primary/Secondary Calculations JasonCo General Electrical Discussion 33 03-08-2016 10:55 PM
PCB Transformers under bedroom Mac44 Services and Service Equipment 8 03-07-2016 10:42 PM
Electrical Transformers Under Bedroom Mac44 General Electrical Discussion 32 02-29-2016 12:12 PM
