Jig for Testing Equipment - Electrician Talk - Professional Electrical Contractors Forum
Old 08-06-2014, 12:26 AM   #1
A Little Short's Avatar
Rewards Points: 1,150
Default Jig for Testing Equipment
I looked at a job that the customer wants a way to plug in a number of pieces of equipment to test them to see if they are operational. They want to be able to have single phase and 3 power available on their testing station.
What they would like is some type of box or panel large enough to accommodate several receptacle configurations, both single and 3. They also want this to be portable or a way to disconnect it and move it when not in use.
Basically they want a cord & plug that would supply 3 power to the box and distribute the power to each receptacle according to the receptacle requirements, some single and some 3.
They will only be using one receptacle at a time. The reason they want this is they buy used equipment and need to verify that it works before reselling it.
Is there a compliant way to do this?
How would you know how to fuse this not knowing the loads that will be plugged in?
The feed to this would have to come from the overhead bus. So I would need to use the correct size fuses in the bus disconnect. Would the portable box/panel also need OCPD?
Old 08-06-2014, 12:34 AM   #2
Cow
Rewards Points: 5,108
I'd mount a small 3 phase panelboard to a piece of plywood. Then nipple out of the panel into a bunch of 4 square boxes with all the different receps in them.
John Valdes (08-06-2014)
Old 08-06-2014, 12:51 AM   #3
Just use either 3 or single breakers, 15 or 20A?
They said they weren't going to run the equipment very long, just to make sure it functions.
What about feeding the panel? Maybe an inlet on the panel and matching plug on the feed cord?
Old 08-06-2014, 01:04 AM   #4
Cow
An inlet would work. I might also just use a cord of the proper length ran right into the panel using a cord grip with integral strain relief. If the cord is to long or to heavy to move with the panel/plywood, I'd consider just making a short pigtail out of the panel with a cord end on it. Then plug a longer separate extension cord into it you would use to reach the buss duct.
Then I would fill the panel with 1, 2, or 3 pole breakers, whatever it took to feed each receptacle.
Old 08-06-2014, 02:34 AM   #5
Rewards Points: 194
We have jackson box's over here which are basically that. Top notch quality too.
http://jackson.co.nz/product/lifeguard-7/
Nuzzie is offline   Reply With Quote
Old 08-08-2014, 10:55 PM   #6
Coffee drinking member
Wirenuting's Avatar
Rewards Points: 7,374
We had a cart with a panel on it. It was cord connected for shop,or field work with different receptacles along the sides..
Most of our systems are 120/208 so it was easy.
Old 08-09-2014, 08:28 AM   #7
martindag's Avatar
Rewards Points: 215
i made something similar at my job to test my equipment after a big repair
we got like 3 panel, a 600v 3ph , 208 3ph , and one 120/208
we made receptacle of all power iin a wall with a bunch of twist lock plug and all type to be able to connect all of them.
martindag is offline   Reply With Quote
Breaker testing equipment BuzzKill General Electrical Discussion 18 02-09-2013 01:22 AM
Avionics Testing equipment. Wiring sub panel. aftershockews General Electrical Discussion 8 02-06-2013 05:36 PM
equipment scott1 General Electrical Discussion 7 10-28-2012 09:09 AM
For Sale: Used equipment oldtimer Electrician Swap 4 03-12-2011 08:16 PM
Electrical Power Equipment Maintenance and Testing, 2nd Edition garfield General Electrical Discussion 5 01-28-2011 03:44 PM
