Junk Halo 4" LED retrofit trims - Electrician Talk - Professional Electrical Contractors Forum
Like Tree7Likes
  • 5 Post By 99cents
  • 2 Post By Semi-Ret Electrician
Old 02-17-2017, 11:47 PM   #1
ppsh's Avatar
Rewards Points: 126
Default Junk Halo 4" LED retrofit trims
Picked up 24 Halo 4" LED retrofit trims for a job this week, 3 were DOA.
Two wouldn't light up, one started doing a 1hz flash after powered up for a few seconds. Wasn't even on a dimmer, just a new single pole switch.
The things just seem cheaper than chit, the driver to led wire connection hangs on the outside with crimp caps.
Put over 150 off brand 4" trims in a house last July and had no failures, just two or so that didn't like being dimmed. Anybody have a similar experience?
ppsh is offline   Reply With Quote
Old 02-18-2017, 09:07 AM   #2
Speedy Petey's Avatar
Rewards Points: 604
I got ten on sale for $15/ea recently. Half the regular price. Not a problem in several weeks. I guess we'll see......
Old 02-18-2017, 09:11 AM   #3
Rewards Points: 14,269
Halo has always been junk.
Old 02-18-2017, 10:09 AM   #4
Senior Moment
drsparky's Avatar
Rewards Points: 136
Who the heck is Tom Ford?
Old 02-18-2017, 10:25 AM   #5
He's an ultra-Liberal American fashion designer. I use it to send Mech and RePhase into orbit .
Old 02-18-2017, 10:37 AM   #6
Southeast Power's Avatar
Rewards Points: 8,718
Compatible dimmer?
Old 02-18-2017, 12:00 PM   #7
Rewards Points: 1,830
I have been using Halo for over 30 years and I have had to replace one or two sockets from before I started installing.
I had an issue years ago with 4" cans and afci which was quickly rectified. I have not had the issue the op stated and I have installed hundreds of the LED trims but only 12 or so 4" Leds.. May be a manufacturers screw up. It happens
Old 02-18-2017, 02:50 PM   #8
Semi-Ret Electrician's Avatar
Rewards Points: 486
Who are you and what have you done to the old Perky?
The_Modifier and 99cents like this.
4" Halo Led New Construction Access zac General Electrical Discussion 3 12-16-2016 09:42 PM
