Knee pads - Electrician Talk - Professional Electrical Contractors Forum
Like Tree3Likes
Old 05-14-2010, 08:39 PM
Default Knee pads
I've gone a long time without using knee pads, but that time is over. I need a good pair, but there are many designs. I see floor guys using a design that only attaches to the lower leg and floats at the top, then I see other guys using the type that attaches at both the top and bottom. I need to be able to walk, kneel, and sometimes crawl with them on.
Anyone have any experience with knee pads and have a certain type that they would recommend? Something I could get at Lowes or Home Depot would be best, if possible.
MTorres likes this.
Fission is offline
Old 05-14-2010, 08:41 PM
Chairman of the Bored
BuzzKill's Avatar
Rewards Points: 2,540
oh that's a loaded question.
I'd rather be sleeping.
BuzzKill is offline
Old 05-14-2010, 08:47 PM
Yeah, I figured I'd get a little ribbing, but I honestly need the knee pads and would rather not go thru 2-3 pairs before finding the type that works the best.
Fission is offline
Old 05-14-2010, 09:09 PM
Rewards Points: 5,198
Okay, sorry about that. What in the world do you guys do these that requires knee pads? I worked 15 years in construction and never needed them.
RIVETER is offline
Old 05-14-2010, 09:29 PM
not THAT old!
Electric Al's Avatar
Rewards Points: 250
The day will come when you realise, YOU SHOULD HAVE WORN KNEEPADS.
MTorres likes this.
Electric Al is offline
The Following User Says Thank You to Electric Al For This Useful Post:
The_Modifier (07-25-2012)
Old 05-14-2010, 09:32 PM
Originally Posted by Fission View Post
Seriously, you drive me nuts sometimes, why do you always act so naive? Who in their right mind couldn't figure out why an electrician would need kneepads? Everything from trimming out receptacles to crawling around attics involves kneeling. In my particular instance, I will be doing work under a low area in which I will have to crawl on gravel. Small rocks pushing into my knees does not sound fun, does it?
Believe me I am not naive and I guess I can see why you need them if you do it that way. I just carried a five gallon bucket with me and I don't remember ever crawling through rocks. I sometimes wish I had knee pads when doing personal work like laying tile, otherwise no.
RIVETER is offline
Old 05-14-2010, 09:34 PM
mattsilkwood's Avatar
Rewards Points: 2,006
Wouldn't it be easierto jusk ASK the boss for a raise?
A man that will not read has no advantage over a man that can not read.-Mark Twain
mattsilkwood is offline
Old 05-14-2010, 09:35 PM
Rewards Points: 1,000
I use AWP I got at Lowes. I like them okay.
waco is offline
Old 05-14-2010, 09:39 PM
Great, ONE on topic reply and the guy just "likes them okay">
Fission is offline
Old 05-14-2010, 10:16 PM
Rewards Points: 2,000
I've been wearing kneed pads for a while, and I catch jokes no matter what.
However, I've seen how some of these old guys move and I have no interest in being as blind, as deaf, and as sore as they are, (though my back has already begun to act up). I can't tell you how many times I've spent working a few inches above the floor, or crawling up upon duct work and chiller pipes. Those are the times having knee pads are great. Even running pipe I'll take a knee to grab the EMT instead of bending over to lift at the expense of my back.
I simply bought the cushions incased in nylon/polyester. They're CLC's rebranded as Home Depot's Husky. I don't like the "fancy" ones that have hard flat surfaces because they kinda shift so that the hard flat surface is always on the ground sometimes twisting them in weird ways. It's hard to explain.
Just think, softer, and simpler is better.
MTorres likes this.
Frasbee is offline
The Following User Says Thank You to Frasbee For This Useful Post:
slickvic277 (05-15-2010)
Old 05-14-2010, 10:45 PM
Duluth Trading Company has work pants with built in knee pads. Best work pants I've ever owned, and you can buy them online. Some are even made in the USA.
MNDan is offline
Old 05-14-2010, 11:02 PM
My problem is they always fall down. I hear that happens even with the combat ones our guys are wearing in Iraq. I need some that you rivet snaps to your pants and snap in.
nitro71 is offline
Old 05-14-2010, 11:57 PM
pjg
Rewards Points: 99
I don't have these, but they are on my wish list. US made too. http://www.bestbelt.com/product/belt...-kneepads.html
pjg is offline
Old 05-14-2010, 11:58 PM
JohnR's Avatar
All jokes aside, Not having had any good luck with them myself, I would guess that the ones that tile guys wear would be the best. The DO spend a lot of time on them.
The ones that have a hard surface should do better on gravel I would think.
Every time I try a pair, I find them either about where a ladder rung hits or pulling down my pants.
So I don't bother with the stupid things. I just use a piece of Blue rigid Insulation about 1-2 inches works great.
Signed out.
JohnR is offline
Old 05-15-2010, 01:24 AM
I have a black cat.
Rudeboy's Avatar
I have a pair that I bought off the aisle from hd and they work. Seriously, 15-20 bucks can save your knees. I wear them when crawling attics and under the house, trimming out, cutting in boxes etc.
Very good idea and investment.
I don't like to Save time and money.
Rudeboy is offline
Old 05-15-2010, 01:51 PM
Buzzy304E
ibuzzard's Avatar
I'm 50 years old,having started in this trade in my mid-20's.Try to ignore all those with that Macho attitude about safety and taking care of your body.As an apprentice,I used to use the palm of my hand to hit things, instead of a proper Electricans' Hammer(linesmans'),this in spite of my old journeyman's warnings.Now,I've got perpetually sore hands.Within a few years of starting out,I could hear my knee joints crackling like an arcing switch.About a year after turning out from my apprenticeship,I had Carpal Tunnel surgery on both hands.I've had tendinitis in one of my elbows, a finger that occasionally locks up,and suffered a couple of back injuries as a young journeyman.I used to let the big iron-pumping guys bully me into lifting more than I could safely do,instead of getting some help from the other close-by electricians.Needless to say,those guys didn't pay me for the days I spent flat on my back.Used to have a hip and back problem from wearing every last tool in my arsenal, in my tool bags.Now, I'm a "minimalist".I have a small amount of hearing loss,as most longer term electricians do.
Take care of your body.I still feel I can go another 15 years,because I changed (most) of my ways.I've no problem keeping up with all but the most driven young guys,mainly from working "smarter,not harder",instead of bulling my way through things.Don't listen to those who don't have your best interests at heart.It's a marathon,not a sprint.Wear the knee pads.
(End of Sermon)
The Right-Reverend Ibuzzard
Welcome to ET., where the clowns....
should of......could of....would of.....might of?
ibuzzard is offline
The Following 3 Users Say Thank You to ibuzzard For This Useful Post:
adam4all (05-15-2010), Frasbee (05-15-2010), yucan2 (05-16-2010)
Old 05-15-2010, 03:06 PM
I use something similar to this. Unless you spend a large part of your day on your knees these should help.
I have also owned regular knee pads but rarely used them because they are inconvenient and uncomfortable for most sparky tasks.
Buy the type that you can insert into your Carhartts.
http://www.softknees.com/softknees.html
adam4all is offline
Old 05-15-2010, 04:24 PM
I use the hard plastic kind that snap above and below the knee for when I have to crawl around on outdoor advertising billboard catwalks. Kind of like baseball catchers use without the shin guard. If I wore pants, I probably wouldn't even bother, but that hot, sharp, rusted steel on bare knees hurts after a while.
knowshorts is offline
Old 05-15-2010, 04:33 PM
Toronto Sparky's Avatar
Rewards Points: 1,008
Isolation and duct tape.
Don't fight .. Play nice!
Toronto Sparky is offline
Old 05-15-2010, 04:37 PM
Is that one of them Canadian pronunciations?
Accepted into Local 3 - pending knee surgery - what to do! OaTiS Union Topics 27 09-23-2018 05:43 AM
