Kubota welder machine - Electrician Talk - Professional Electrical Contractors Forum
Like Tree1Likes
Old 12-17-2016, 12:09 PM   #1
Rewards Points: 12
Default Kubota welder machine
Anyone familiar with Kubota welder machine?
The problem is, no matter how i tried, the voltage stays at 102Volt on RN/SN/TN, 175Volt RS/RT/ST
I tried to adjust voltage at the AVR, but soon these things started to smoke
The engine is 3TNE68 UDW1
Thank you
JBoen is offline   Reply With Quote
Old 12-17-2016, 12:39 PM   #2
Rewards Points: 21,669
The rust on the frame looks pretty bad. You really need a new machine.
I stand with Tucker Carlson
Old 12-17-2016, 02:39 PM   #3
Rewards Points: 26,880
It looks wet.
You should take it to a motor rewind shop. Perhaps they'll have the diagnostic tools to figure this puppy out.
BTW, what was the voltage delivered to the arc ?
Old 12-17-2016, 07:43 PM   #4
Sparks fly from my finger
Jhellwig's Avatar
Rewards Points: 4,663
So... does it work?
Old 12-18-2016, 01:31 AM   #5
Rewards Points: 12
I know, if it cant be fixed, that ll be the only way out.
Old 12-18-2016, 01:34 AM   #6
Rewards Points: 12
It looks wet.
I havent measure the arc, but i dont really know how welding machine work, i know a bit of genset. It has voltage on the output terminal RSTN, but it supposed to be 220v right?
Old 12-18-2016, 09:25 AM   #7
The speed of the motor has an impact on the Hertz and the Volts.
You sound like you're lost.
Bring in talent or take this puppy to an electric motor shop.
Old 12-18-2016, 09:54 AM   #8
Rewards Points: 12
Thats why i discuss it in here, i just want to know if anyone familiar with this welding machine. Someone who can share some info.
Old 12-18-2016, 10:36 AM   #9
Cl906um's Avatar
Rewards Points: 1,206
I had something similar with an old Koehler gen. Put out 150 to grounded. It was a matter of adjusting one screw for the governor. I called L&S. They were a huge help at telling me info on this . They rewind motors and are a pretty big outfit. The original company is Z&R. Location, iron mountain, mi. Try giving them a call. Do it quick. A lot of the older guys that were good mechanics as well as electricians are retiring. We are becoming a throw away nation. Everything is at our disposal.
Old 12-18-2016, 10:39 AM   #10
Cl906um's Avatar
Run it for some time with a light load may help some of the moisture issues.
Old 12-18-2016, 08:42 PM   #11
Rewards Points: 12
I live in small city of Indonesia, it will be hard to find someone who can really fix this and of course they will over charge sometimes.
Old 12-18-2016, 08:43 PM   #12
Rewards Points: 12
Do you mean running light load will help this generator to stabilize the output voltage?
Old 12-18-2016, 11:11 PM   #13
Jhellwig's Avatar
Does it weld?
Don't screw with the governor. That is a sure way to mess it up in a hurry.
Old 12-19-2016, 01:00 AM   #14
Rewards Points: 12
It did weld, and the weird thing is drilling machine was working as well. I measured the output voltage, it was 110V, and drilling machine specs stated that it is 220v.
Sent from my MI 5 using Tapatalk
Old 12-19-2016, 01:02 AM   #15
Rewards Points: 12
What do those WC-10C and WC-10E do actually? Are those for welding?
Old 12-19-2016, 01:03 AM   #16
Rewards Points: 12
It was the solenoid, i think its like jammed or old, i had to move it with my hand, the voltage goes higher.
Old 12-19-2016, 01:08 AM   #17
Rewards Points: 12
This AVR is working when i adjust, it responds.
But these two, it didnt respond, nothing changed at all.
Old 12-19-2016, 02:08 AM   #18
Rewards Points: 1,558
Have you done an online search for a service manual or circuit diagram ?
Would help a lot !
Old 12-19-2016, 02:14 AM   #19
Rewards Points: 21,898
Originally Posted by Jhellwig View Post
Does it weld?
That useally true in majorty of diesel generators.,,
to OP .,,
did you verify the engine speed by the X of RPM ? if you are in 50 Hz Area the generator should be in 1500 or 3000 rpm depending on the poles on the generators 1500 should be correct for 4 pole verison while 2 pole you should be spinning at 3000 rpm.
But if you are on 60 HZ you should be at 1800 or 3600 RPM.
you should get the frequecy meter to read the numbers of HZ to get the correct speed then adjust the voltage to correct number.
telsa likes this.
Old 12-19-2016, 06:48 PM   #20
Rewards Points: 12
Would help a lot !
Yea i have tried, but couldn't find any.
Coffee bike. Electric / Gas Espresso Machine. Kasperbb68 General Electrical Discussion 2 09-17-2016 10:12 AM
Machine shop question. TRurak General Electrical Discussion 19 07-15-2016 01:15 PM
Welder that says max 30 amps Arcflasher Residential Electrical Forum 4 06-15-2016 08:19 PM
CNC machine power wiring. High leg delta system - HELP PLEASE! Polynomial General Electrical Discussion 5 05-15-2016 12:46 AM
Sizing Conductors for machine feeder. nables30 NEC Code Forum 11 03-28-2016 10:45 PM
