Led Acid/ Lead Calcium - Electrician Talk - Professional Electrical Contractors Forum
Like Tree1Likes
  • 1 Post By micromind
Old 11-10-2017, 05:11 PM   #1
German Spy
Helmut's Avatar
Rewards Points: 4,439
Default Led Acid/ Lead Calcium
Interchangeable?
Do they utilize the same charging boards in E-lite packs?
Old 11-10-2017, 07:54 PM   #2
Rewards Points: 21,896
Originally Posted by Helmut View Post
Interchangeable?
It depending on the charging rates and the type of battery it will be changed over.
if going to get sealed unit you really have to watch the voltage setting on that. it should have manufacter specs on charging voltage and floating voltage.
Old 11-10-2017, 08:27 PM   #3
Rewards Points: 3,112
A lead-acid wet cell needs an equalize charge once in a while, lead-calcium does not.
Lead-calcium needs a slightly higher float-charge voltage then lead-acid.
Generally speaking though, they are interchangeable but if the charger in not adjusted, the lead-calcium will not last very long.
frenchelectrican likes this.
Helmut (11-11-2017)
Diet Dr. Pepper Commercial Chris1971 Off Topic (Non Trade) 22 08-14-2017 08:44 PM
Recommend me a quality test lead set TheLivingBubba Tools, Equipment and New Products 4 07-12-2017 02:37 PM
Wiring 6 lead single phase motor with forward and reverse starters DoktorSleepless General Electrical Discussion 1 07-16-2016 05:03 PM
