LED dimmers - Electrician Talk - Professional Electrical Contractors Forum
Like Tree2Likes
  • 2 Post By Chris1971
Old 06-21-2017, 09:45 PM   #1
Can't sign em..forget em
lighterup's Avatar
Rewards Points: 10,200
Default LED dimmers
Does anyone use the Lutron Adriana LED / CFL / Incandescent dimmers
for Halo's LED retrofit trims? or do you buy the more pricey $60-$70
electronic dimmers for these?
I have had many discussions with varying opinions on this .
Old 06-21-2017, 09:56 PM   #2
drspec's Avatar
Rewards Points: 1,120
Ill occasionally use the Ariadni with no issue but I generally stock the Eaton dimmers and they work for about 90% of what I install
Old 06-21-2017, 09:57 PM   #3
Rewards Points: 804
The Lurton LED/CFL dimmers work well with the Halo LED Trims.
sbrn33 and socket2ya like this.
Old 06-21-2017, 10:01 PM   #4
Dash Dingo's Avatar
Rewards Points: 318
Default LED dimmers
Yes I just did recently. They seem to work okay. I had 4 of them on one switch.
I had a situation where I was trying to dim one halo 4" Led trim and the Lutron Ariadni CFL LED really struggled to dim that without flickering when the switch was turned on and the dimmer was preset to low.
I tried the Diva style and that worked a little better.
I think those Eaton all load dimmers suck for dimming Halo LED trims. I tried those first but if the switch was off for a long period of time and you turned it on it would not fire up the lights, they would just flicker at a very low light level.
I'm finding out that different brands of LED lighting work better with different brands of switches.
LED Dimmers seem to do better when there is more load on them.
I've come to hate LED stuff now because everybody wants them dimmed and it's such a PITA.
I miss the days of BR30's where you could just throw a dimmer in and not worry about it.
I also miss those same days of no arc faults either when you could throw in a regular breaker and drive away and not worry if it's going to hold.
Dash Dingo is offline   Reply With Quote
Old 06-22-2017, 03:56 AM   #5
Rewards Points: 24,234
Amen!
Old 06-22-2017, 07:47 AM   #6
lighterup's Avatar
Okay thanx.
The supply house counter guy told me (yesterday) that "some" guys are
saying they get "flickering" if the use those Lutron Adrianas and some say
they work just fine.
He also quoted me electronic dimmers @ the 60-70 dollar range each
and since I need (10) dimmers I thought I'd ask this on this forum.
I would be in the camp that say they work . I have not had any complaints yet about them and I can say that one of the past
customers I had would most definitely be calling with a complaint if
he had any flickering at his home.
Thanx. Gotta go.
Wire for 0-10v dimmers boots 211 General Electrical Discussion 16 06-14-2017 01:11 AM
LED Dimmers cec625 Lighting Design 5 04-24-2017 09:44 PM
LED dimmers that dont buzz NDC General Electrical Discussion 13 01-31-2017 10:53 PM
Flickering lights with dimmers set at certain points mike9666 General Electrical Discussion 7 01-09-2017 03:15 AM
Problem...Dimmers in 2 rooms bcsparks4 NEC Code Forum 6 04-13-2016 05:58 AM
