LED fixtures for church - Electrician Talk - Professional Electrical Contractors Forum
Like Tree7Likes
  • 1 Post By 99cents
  • 1 Post By John Valdes
  • 1 Post By MechanicalDVR
  • 4 Post By Southeast Power
Old 04-01-2017, 06:47 PM   #1
Rewards Points: 554
Default LED fixtures for church
I need to put LED fixtures in a church building. The print specs call for troffers, but this is going to be a drywalled ceiling. I want them to be recessed in the framing....then flush with the drywall when finished. Are troffers the thing to use here or is there some other fixture for this?
John M. is offline   Reply With Quote
Old 04-01-2017, 06:58 PM   #2
Rewards Points: 14,127
Plaster frame. Should be on the fixture schedule.
sbrn33 likes this.
John M. (04-01-2017)
Old 04-01-2017, 11:01 PM   #3
Rewards Points: 226
Be careful. To good of lighting may uncover the unwary!
Old 04-01-2017, 11:48 PM   #4
Rewards Points: 630
Potlights
Should be able to get a drywall kit to install a troffer in that type of ceiling.
darren79 is offline   Reply With Quote
Old 04-02-2017, 01:46 AM   #5
Rewards Points: 44
Frame kit
FF301 is offline   Reply With Quote
Old 04-02-2017, 08:44 AM   #6
Rewards Points: 3,006
A troffers and plaster frames are far less expensive than fixtures with integral rims for sheetrock.
Old 04-02-2017, 10:13 AM   #7
Southeast Power's Avatar
Rewards Points: 8,694
Ceiling grid tees make perfect frames and give it a decent finish.
Old 04-02-2017, 10:17 AM   #8
But you have to frame the opening yourself for them to work?
I've never seen rough framing all that good.
Old 04-02-2017, 01:08 PM   #9
They would need to box it out to make it work or, clean it up after I finished butchering it.
Old 04-02-2017, 03:21 PM   #10
Most job sites I've been on one would have to be fluent in Spanish to get a properly sized opening in the framing.
telsa likes this.
Old 04-02-2017, 07:49 PM   #11
I would give them a plywood template and tell them "el cuto likeo thiso ."
Old 04-02-2017, 08:22 PM   #12
Churches are slow payers. Bill them fast and often.
Jlarson (04-04-2017)
Old 04-02-2017, 10:18 PM   #13
Switched's Avatar
Rewards Points: 9,230
The Spanish speaking guys I have had the pleasure of working with must be better, all I would have to do is supply the materials....
Old 04-02-2017, 10:20 PM   #14
Sometimes that works.
Old 04-02-2017, 10:21 PM   #15
It varies from church to church. Some hand you a check when done.
Old 04-03-2017, 09:40 PM   #16
Cl906um's Avatar
Rewards Points: 1,206
Just be careful that the carpenter frames it in for the light correct. Some of the plaster frames have wings that flip out only high enough for 2". 4" is too thick and you have to butcher the crap out of them to flipper the wings out.
LED Retrofit vs. Fixtures Mr.Awesome Lighting Design 10 04-01-2017 09:22 PM
LED fluorescent replacement T8, VS. LED fixtures CNC Lighting Design 2 08-18-2016 10:54 AM
Chain Hung Fixtures, Bx or Flexible whip quick_2 Canadian Electrical Forum 5 05-31-2016 02:05 AM
Can more than one light sensor turn on multiple fixtures? ErnieG Lighting Design 8 03-12-2016 02:43 PM
Varaluz Recalls Longfellow Light Fixtures Due to Fire Hazard guest Recalls, Safety Notices and References 3 01-31-2016 02:26 PM
