LED slims in existing ceiling do you install a boot - Electrician Talk - Professional Electrical Contractors Forum
Like Tree22Likes
  • 3 Post By drspec
  • 1 Post By HackWork
  • 1 Post By 99cents
  • 1 Post By NDC
  • 1 Post By shocksystems
  • 2 Post By PlugsAndLights
  • 2 Post By HackWork
  • 2 Post By 99cents
  • 2 Post By 99cents
  • 2 Post By 99cents
  • 2 Post By five.five-six
  • 1 Post By Majewski
  • 1 Post By 99cents
Old 09-21-2016, 04:44 PM   #1
NDC
NDC's Avatar
Rewards Points: 2,400
Default LED slims in existing ceiling do you install a boot
Walked into a home today and had to change one of these slim led panels. I pull it down and get covered in blown in insulation. When I quote for these in an attic I always install a vapor barrier. I can see someone getting away with no boot for an ic retrofit potlight can but seriously an led panel?
I know led panels are ic rated but what about caring about the next guy who has to replace one.
Old 09-21-2016, 04:49 PM   #2
Big nosed attic troll
Majewski's Avatar
Rewards Points: 2,774
That installer had no care! Even if they don't know about doing it, they didn't care enough to figure something diy out for the next person.
What kind was it?
Old 09-21-2016, 05:08 PM   #3
drspec's Avatar
Rewards Points: 1,116
F the next guy
electricguy, Majewski and NDC like this.
Old 09-21-2016, 05:16 PM   #4
Rewards Points: 1,085
Originally Posted by drspec View Post
F the next guy
Words to live by!
Majewski likes this.
drspec (09-21-2016)
Old 09-21-2016, 07:48 PM   #5
Rewards Points: 14,015
I don't use them in insulated ceilings. I did one Lotus job where I Tuck Taped the vapour barrier and slid the driver between the drywall and VB. It's easier to use normal cans in an insulated ceiling.
Old 09-21-2016, 08:02 PM   #6
NDC
NDC's Avatar
This sounds like it would work too. What would you do if you had to install under a joist though?
746 Watts likes this.
Old 09-21-2016, 08:21 PM   #7
Rewards Points: 334
I have never installed a vapor barrier for recessed lighting. Enough other things to worry about. If it is IC rated, in she goes!
shocksystems is offline   Reply With Quote
Old 09-21-2016, 08:23 PM   #8
Safety Pin Member
PlugsAndLights's Avatar
Rewards Points: 2,880
I put them in without a boot. Last one I did there was no real VB, just
paper wrapped fiberglass batts.
Did you manage to pull down the slim led's without taking chunks
out of the drywall? Once those springs snap on the back of the drywall
they don't want to let go. In fact, I usually*go into the attic, move the
insulation, and release the springs from up there.
* OK, only had to do this once.
P&L
Majewski and 746 Watts like this.
Old 09-21-2016, 08:24 PM   #9
IC and AT.
P&L
That's the way it is down here. Most "vapor barriers" are just craft paper that is attached to the fiberglass insulation and stapled to the studs or joists. It's not air sealed.
shocksystems and Majewski like this.
Old 09-21-2016, 08:29 PM   #10
P&L
Your hole should be a little oversized so you have some wiggle room.
Old 09-21-2016, 08:31 PM   #11
Local code here for cans.
Old 09-21-2016, 08:32 PM   #12
It was a little tight in some locations. I wouldn't do it again.
Old 09-21-2016, 08:58 PM   #13
five.five-six's Avatar
Rewards Points: 10,016
The Following User Says Thank You to five.five-six For This Useful Post:
drspec (09-22-2016)
Old 09-21-2016, 09:01 PM   #14
Majewski's Avatar
Originally Posted by five.five-six View Post
Never leave home without em!
five.five-six likes this.
Old 09-22-2016, 01:18 AM   #15
Rewards Points: 2,982
Nice!
Old 09-22-2016, 07:32 AM   #16
drspec's Avatar
Love my 18v vac......use it almost daily
The van my guys drive has the 18v/120v DeWalt and it can't compare to the Milwaukee
The Following User Says Thank You to drspec For This Useful Post:
MechanicalDVR (09-22-2016)
Old 09-22-2016, 09:15 AM   #17
I thought people didn't like the battery vacuum?
If you are happy with it, the 9.0 battery would probably be great for you.
Old 09-22-2016, 09:35 AM   #18
Cords aren't a crime.
Old 09-22-2016, 09:42 AM   #19
Back to the original post - Lotus would hit a home run if they had a remote driver that would do multiple fixtures. LVT poked through the vapour barrier would be no big deal.
Arc-Faults, Extending existing non-arc circuits. quick_2 Canadian Electrical Forum 3 05-12-2016 08:38 PM
