Light bruns out quickly, appliances gone bad - Electrician Talk - Professional Electrical Contractors Forum
Like Tree9Likes
  • 4 Post By hardworkingstiff
  • 1 Post By Switched
  • 2 Post By circuitman1
  • 1 Post By MikeFL
  • 1 Post By MechanicalDVR
Old 02-19-2017, 03:55 PM   #1
Rewards Points: 18
Default Light bruns out quickly, appliances gone bad
Hi all
I have a customer that his appliances went dead ( green board) and his lamps needs to be changed frequently,
He has a warranty on the appliances but they say it's not covered due to an electric problem, I check voltage line 2 line which 240. Line -Neutral 120v . All connections looks good what could be the problem, any suggestions help is appreciated
Thanks
Sent from my SM-G935V using Tapatalk
freefreeqaz is offline   Reply With Quote
Old 02-19-2017, 03:59 PM   #2
Rewards Points: 14,714
You need to check the voltages with a load (like a hair dryer or heat gun) on just one leg and see what the voltages do. If the one with the load on it goes down in relation to the neutral and the other leg goes up in relation to neutral, and the L to L voltage remains the same, you have a deteriorating neutral connection.
The Following User Says Thank You to hardworkingstiff For This Useful Post:
220/221 (02-19-2017)
Old 02-19-2017, 04:23 PM   #3
Switched's Avatar
Rewards Points: 9,260
Also, tell them to call the POCO. Around here they can typically get there the same day to check the connections on their end.
The Following User Says Thank You to Switched For This Useful Post:
Old 02-19-2017, 05:11 PM   #4
Rewards Points: 21,898
That is a classic sign of loose or bad netural connection.
Do a quick load test as hardworkingstiff mention about that and watch the line to netural voltage change on that.
Of course get a hold the POCO same time they will check their side after you get your side done and watch them to make sure they verify it.
typically bad netural connection on their side can show up a bit so expect that after you check all the connection at breaker box.
Old 02-19-2017, 10:56 PM   #5
Rewards Points: 664
i would check & clean all neutral connections. had a friend that had the same problem. he got home one night & looked like someone had turned a spot light on. shut off main called power company, they cleaned & checked all neutrals. all was ok till next night , back again, this time they found they had a bad neutral at the transformer. only it was on the inside not outside. had them stumped too. changed it at two in the morning. no more problems since then.
MechanicalDVR and freefreeqaz like this.
circuitman1 is offline   Reply With Quote
The Following User Says Thank You to circuitman1 For This Useful Post:
hardworkingstiff (02-20-2017)
Old 02-20-2017, 12:20 AM   #6
Rewards Points: 18
Thanks all for your help. Will check on that and keep you posted
Old 02-20-2017, 02:24 AM   #7
MikeFL's Avatar
Rewards Points: 630
Meter can is a famous place for bad noodles.
Michael Gookin, President
GPS Timers
(833) GPS-TIME
Old 02-20-2017, 12:47 PM   #8
Rewards Points: 3,062
Don't leave out cheap Chinese buffets!
MikeFL likes this.
Help plz.. Can't get 3way light working awabizzle General Electrical Discussion 1 11-21-2016 12:35 AM
3 way light trouble awabizzle Residential Electrical Forum 2 11-21-2016 12:33 AM
Outdoor Light Works Intermittently BowtoEd General Electrical Discussion 2 11-18-2016 07:36 AM
Light dimming squiresj1 General Electrical Discussion 4 03-15-2016 02:01 PM
