Lightning strikes - Electrician Talk - Professional Electrical Contractors Forum
Like Tree7Likes
  • 1 Post By RePhase277
  • 1 Post By Cl906um
  • 1 Post By MechanicalDVR
  • 2 Post By Cl906um
  • 1 Post By John Valdes
Old 06-04-2016, 11:22 AM   #1
Cl906um's Avatar
Rewards Points: 1,206
Default Lightning strikes
Local ski/golf course completely relies on a thirty horse well pump for watering and snow making. The problem is lightning keeps hitting well casing. They recently put a vfd on motor and the first storm that came through took it out. It needs suppression on both sides of the drive. Any ideas? I was thinking of tvss before it and lightning arresters on load side. Any ideas?
Old 06-04-2016, 11:30 AM   #2
Rewards Points: 1,360
Man lightning loves well cases because they are just such damn good grounds. TVSS and arrestors might help but a direct strike is hard to handle. You may have to make something else into a target. Two or three antenna towers around the well, grounded running away from the well and tied together may be a more long term fix.
John Valdes likes this.
Old 06-04-2016, 11:38 AM   #3
Cl906um's Avatar
I recommended them call a lightning specialist like sleeping bear.we have sub contracted them for other installs. Customer says even when nearby tree gets hit, it gets redirected to casing at ground level as it is down 400'. Not sure a halo would even work. 200' pines nearby.
Old 06-04-2016, 11:41 AM   #4
Rewards Points: 23,350
Agreed, let a guy look at it that does this stuff all the time.
Old 06-04-2016, 11:54 AM   #5
Cl906um's Avatar
Yeah, whoever did the original install did a crummy job. Used three wire Urd. No ground wire on a y system, and just bonded the disconnect and vfd enclosure to the casing. Run is 800 feet roughly. Not good
Old 06-04-2016, 11:57 AM   #6
I'd bet that was done by the lowest bidder, you get what you pay for at times.
Now paying to get it right will cost them more than the right way the first time around.
transient likes this.
Old 06-04-2016, 12:20 PM   #7
Cl906um's Avatar
This resort is under newer ownership. I feel bad that they didn't know what they were getting into. Manager said that this is the first resort he seen rely solely on a well. The ponds that the well fills is unlined as well. Leaches 100 gpm into the ground. They don't give bentonite away either. Corners were cut everywhere you look.
MechanicalDVR and Big John like this.
Old 06-04-2016, 12:36 PM   #8
Rewards Points: 458
Seems a bad place to put a drive in. Couldn't they mechanically change motor output speed? Is the motor taking the hit as well?
Wirenuting likes this.
Old 06-04-2016, 12:46 PM   #9
Cl906um's Avatar
The start up on the submersible pump is really hard on it. Not so much trying to vary the speed. Just ramp it up more or less. Pump is 230' down. Filling ponds needs no regulation. Snow guns run pump nonstop in winter.
The Following User Says Thank You to Cl906um For This Useful Post:
John Valdes (06-06-2016)
Are strikes affecting you guys in Toronto Canada? fos General Electrical Discussion 14 06-03-2016 11:30 PM
Single Point Ground Question DannyB General Electrical Discussion 28 01-13-2016 11:33 PM
