Lightning or surge damage? - Electrician Talk - Professional Electrical Contractors Forum
Like Tree8Likes
  • 2 Post By ralpha494
  • 1 Post By brian john
  • 1 Post By MikeFL
  • 4 Post By scotch
Old 03-08-2017, 05:43 PM   #1
Rewards Points: 698
Default Lightning or surge damage?
Would anyone know if this was caused by an over voltage or by lightning? There were three contractors in one enclosure that all look like this. There was lightning the evening this happened but there was also over and under voltage events from the power company I believe.
Lightning or surge damage?-img_4577.jpg   Lightning or surge damage?-img_4576.jpg   Lightning or surge damage?-img_4575.jpg
garfield is offline   Reply With Quote
Old 03-08-2017, 06:35 PM   #2
Rewards Points: 1,558
If you picked it up from across the room, and you put it together for the pictures, it was a direct lightning strike. The lightning could have hit the lines downstream causing a surge, which is what I think happened.
Whatizzit that we're looking at?
circuitman1 and emtnut like this.
ralpha494 is offline   Reply With Quote
The Following User Says Thank You to ralpha494 For This Useful Post:
Ty the electric guy (03-09-2017)
Old 03-08-2017, 06:37 PM   #3
*Contactors
Old 03-08-2017, 08:27 PM   #4
sbrn33's Avatar
Rewards Points: 3,510
Looks more like under voltage to me.
Old 03-08-2017, 09:43 PM   #5
Rewards Points: 1,972
UMMMMM, Lightning is overvoltage.
MikeFL likes this.
Old 03-08-2017, 09:51 PM   #6
Band Member
emtnut's Avatar
Rewards Points: 1,974
That coil looks burned from overcurrent ... ie, voltage dip.
Often happens after lightning takes a transformer out.
Old 03-08-2017, 09:55 PM   #7
Rewards Points: 3,006
Yup a nice slow burn.
Old 03-08-2017, 10:25 PM   #8
Rewards Points: 698
It's one of 3 definite purpose contactor coils that burned up. The overload was also tripped on a control transformer separately.
Old 03-08-2017, 11:14 PM   #9
Cow
Rewards Points: 4,904
I've replaced several coils after lightning storms. It's not uncommon over here.
Old 03-08-2017, 11:29 PM   #10
Rewards Points: 26,512
More business for you.
Old 03-09-2017, 02:10 AM   #11
MikeFL's Avatar
Rewards Points: 598
Under voltage could do that only if there is a load on it.
Over voltage is probably more likely. The sustainable voltage is a function of the insulation and spacing of the windings and will cause failure even with no load as the voltage escapes the insulation from one winding to another.
My best guess is over voltage = lightning.
emtnut likes this.
Michael Gookin, President
GPS Timers
(833) GPS-TIME
Old 03-09-2017, 02:35 PM   #12
Semi-Ret Electrician's Avatar
Rewards Points: 486
Dirty contactor might be the problem.
If a contactor doesn't fully pull in the magnetic circuit won't close and the coil will burn up.
Old 03-09-2017, 06:36 PM   #13
Rewards Points: 790
A Hotel Resort I do work at always had these problems ...when they had mainline power failures due to trees down across the lines ...24 to 30 lighting contractors burnt at a time ! I installed a $120.00 power conditioner for each of the controls voltage feed ....so sags or peaks were taken care of . Never had to replace a contractor in 4 years ....kinda shot myself in the foot !
Old 03-09-2017, 11:20 PM   #14
We had the same problem with a customer was losing contactors left and right during storms we installed UV/OV, Phase Failure Relays. Not one problem since then
Old 03-09-2017, 11:37 PM   #15
Rewards Points: 698
So those relays turn off control power if activated correct?
Old 03-09-2017, 11:40 PM   #16
Correct with no time delay
Whole House Surge Protection splatz General Electrical Discussion 41 02-07-2017 11:55 PM
Surge Protection for SCADA and control circuits Southworth PLCs, VFDs, Motors and Controls 6 01-25-2017 12:41 AM
Storm Damage backstay General Electrical Discussion 32 06-27-2016 12:31 AM
Lightning strikes Cl906um General Electrical Discussion 8 06-04-2016 01:46 PM
lost neutral and surge protection. te12co2w General Electrical Discussion 10 05-26-2016 10:44 AM
