Lights not Working - Page 3 - Electrician Talk - Professional Electrical Contractors Forum
Like Tree94Likes
Old 12-13-2016, 10:08 AM   #41
Rewards Points: 24
Yeah, once I checked hot to neutral and had the same issue I knew it was a bad hot. I took an extension cord from an outlet I knew was good and 'plugged' each switched fixture up and they all worked fine. This told me that the break/loose connection was in the main run back to the panel. Next spring, when it isn't -31 outside, I will have a builder buddy of mine rip off some siding and we will cut a chase in the outside sheeting and run a new line back to the panel. At least everything is on the same outside wall. I have the lights temp hooked up to the countertop receptacle circuit till then.
Thanks for the help guys.
Daniel J Urban is offline   Reply With Quote
Old 12-13-2016, 08:53 PM   #42
Semi-Ret Electrician's Avatar
Rewards Points: 486
One good use for a tic is tracing a circuit in an attic full of romex.
Just have a helper switch the breaker off and on as you drag the tic along the wire.
zac likes this.
Old 12-14-2016, 12:05 AM   #43
zac
Rewards Points: 826
Another way is by using a toner on the wire when there is no power (or it will fry the toner). This has been an awesome new tool in my armory! And I learned it from the homies at electrician talk. Thanks Telsa!
telsa likes this.
Old 12-14-2016, 02:19 AM   #44
Rewards Points: 26,512
Years ago, I brought my toner and wand to a commercial construction site run by my buddy. ( a 60,000 sf grocer, new build )
After 35 years in the trade -- his eyes bugged out.
He'd seen them before. It just never occurred to him that the kit used by the low voltage boys -- the telecom crews -- would be applicable to his circuits.
The next time I dropped in, he had two brand new sets. He put them on the boss's tab. Heh.
[ He had blanket authority at the supply house, but of course. ]
A toner and wand set up means that you can solve most circuits at low, low power.
You can work 100% faster around harmless conductors.
And you never 'let the smoke out', either.
Old 12-14-2016, 02:30 AM   #45
zac
Rewards Points: 826
Unless you accidentally energize the circuit like I did! None the less it's (the transmitter) been gladly replaced.
telsa and splatz like this.
Old 12-14-2016, 09:47 AM   #46
Rewards Points: 1,194
The Triplett 3388 one costs more but it can be used on 120/240 circuits live, and as a breaker finder.
http://www.triplett.com/shop/fox-hound-hotwire/
zac likes this.
telsa (12-14-2016)
Old 12-14-2016, 09:19 PM   #47
Trained Monkey
TheLivingBubba's Avatar
Rewards Points: 680
I have one, it works, but often times I pick up a lot of Indian music or other radio stations.
HackWork for Moderator
~ I believe in Hax ~
TheLivingBubba is online now   Reply With Quote
Old 12-14-2016, 11:26 PM   #48
Sparks fly from my finger
Jhellwig's Avatar
Rewards Points: 4,529
From the sounds of the way you are testing it you are seeing ghost voltage. It looks like 120 volt but isn't. You need to get a wiggy or a good solid state version of one. It sounds like the hot is open somewhere.
We'll never mind. I see you found it. You would have found it sooner with a wiggy though
Daniel J Urban (12-16-2016)
Old 12-16-2016, 09:57 AM   #49
Rewards Points: 24
Yeah I know. I have only been an electrician since 2006 and only in 2014 did I go out on my own. There are plenty of tools that I still need to buy with limited funds. I am still working out a priority list. And of course the tools that I put off I need on the next job while the tools I just bought sit on the shelf...
Old 12-16-2016, 10:19 AM   #50
Rewards Points: 18,181
To set the record straight. We had lots of toner and wand threads here long before we had any tesla threads . People come , people go.
B-Nabs likes this.
JOBS GROWTH SOARS
RECORD WORKING
UNEMPLOYMENT 50-YEAR LOW
Drudge Report
led tape lights dimming. Ctsparky93 Lighting Design 10 03-01-2017 01:37 AM
Recessed LED lights Flicker wncgnet Residential Electrical Forum 9 05-16-2016 10:41 PM
Removing unwanted recessed lights. Woodman General Electrical Discussion 4 05-03-2016 04:56 PM
Dimming LED Lights power General Electrical Discussion 8 04-01-2016 08:06 PM
Hanging heavy lights on a furred wall. Year_Zero General Electrical Discussion 16 02-25-2016 07:38 PM
