Long distance run - Electrician Talk - Professional Electrical Contractors Forum
Like Tree51Likes
Closed Thread
Old 05-14-2020, 04:55 PM   #1
Rewards Points: 42
Default Long distance run
I have a client with a panel inside his pantry in the house. I want to run emt from the panel on the wall for about eight feet and then through the wall to the outside of the house and put in a four circuit subpanel. From there I'm going to run 12/3 romex in 3/4 inch pvc in ground for 150 feet to an out shed. This will give him two twenty amp circuits at the shed. One for now and one for future use. I know romex isn't used for underground but it will be in pvc for the entire distance. Any problems with this scenario?
lmgoldstein is offline
Old 05-14-2020, 05:03 PM   #2
Plumber (for electrons)
Rewards Points: 72
Yes, the main issue I see is that you're considering knowingly violating both the listing of NM cable and the code sections that govern its installation. If you're taking the time to trench in 3/4" PVC, I can't seem to figure out why any sensible electrician would even fool around with pulling NM in such a crappy situation. Most guys would put in a bigger conduit and allow for either the installation of more circuits in the future, or pull larger conductors to begin with and add another subpanel.
There's a pretty common statement when it comes to outbuildings: Wire and pipe are cheap, digging is not. That statement holds almost universally true and I highly recommend that you reconsider your plan here. There are a lot of issues: improper use of NM cable, voltage drop (nearly 6% at 120V/15A), the difficulty of pulling NM in conduit, and the inherent limitations of only having two 120V/20A circuits available.
If I were on the job, I'd throw a 2" conduit in the ground, pull 2AWG aluminum, and put it all on a 90A breaker with a 20 to 30 circuit panel on the other end. Quick, easy, and you'll never have a callback because there's not enough power. You're already digging the trench and the width isn't what's hard, it's the depth. If you're there already, why skimp?
Not to be that jerk, but are you a licensed and qualified electrician? Most electricians wouldn't even consider doing something like this for a new install...
EDIT: Also, your profile doesn't appear to be filled out. The rules of this site require that all users must complete these fields and some users can be less than friendly if it's not completed.
GatorIE is offline
Old 05-14-2020, 05:08 PM   #3
Bird dog's Avatar
Rewards Points: 2,476
Please fill out your profile. Your post sounds like you're a handyman/trunkslammer. Tnx
I have to go the "handyman" route. Verifiable experience. Many years.
https://www.electriciantalk.com/f29/...8/#post5271574
Bird dog is online now
The_Modifier (05-15-2020)
Old 05-14-2020, 05:09 PM   #4
Rewards Points: 878
What you're describing might not cause any immediate issues, however it just doesn't make sense to me and (likely) is a violation in just about any municipality. I'd much sooner run NMWU/UF underground, simply sleeving the cable where mechanical-protection is required. Better yet, if that conduit spans the entire run, use single-conductors.
Max C. is offline
Old 05-14-2020, 05:13 PM   #5
Liberal Lesbian
Rewards Points: 28
Yup:
I have a pretty broad question. I would like to obtain my C-10 License. My experience consists of over thirty years in residential, commercial and industrial wiring. The problem is I have been in education for the past twenty years. I still do alot of residential work, and have taught several classes in the basics of residential wiring. Does anybody have a thought on how I would go about earning this license. I have a 2017 copy of the NEC and am quite familiar with it. All work I do is per code and I cover everything including 220 work and c.b. replacements. Being a math teacher the math, formulas, and equations are fairly easy. I would just like to get the license. Any advice would be greatly appreciated. Thanks - Larry
John Valdes and Bird dog like this.
HackWork is online now
Bird dog (05-14-2020)
Old 05-14-2020, 05:13 PM   #6
Beam Me Up Scotty
Kevin_Essiambre's Avatar
Rewards Points: 470
Please see the link below. A profile is required here at Electrician Talk. Please make sure to include occupation and general location.
https://www.electriciantalk.com/f3/a.../topics/258186
Max C. likes this.
Vote Kevin for Moderator!
Kevin_Essiambre is online now
Old 05-14-2020, 05:14 PM   #7
Rewards Points: 72
Yup:
This should be a pretty easy job for him then, right? If he can do "c.b. replacement and 220 work," then throwing a little romex in an underground run of pipe is hands-tied-behind-your-back work
GatorIE is offline
Old 05-14-2020, 05:18 PM   #8
Bird dog's Avatar
Hi Hacky...I guess it was my turn to put out the trolls & pull up the drawbridge.
HackWork likes this.
Old 05-14-2020, 05:19 PM   #9
Rewards Points: 878
You know, if you're a handyman, why not just run a 16/3 extension cord out to the shed? You know, the kind with two male-ends?
Max C. is offline
Old 05-14-2020, 05:20 PM   #10
Bird dog's Avatar
Originally Posted by Max C. View Post
You know, if you're a handyman, why not just run a 16/3 extension cord out to the shed? You know, the end with two male-ends?
He didn't worry about vd before, so, why now?
Old 05-14-2020, 05:21 PM   #11
Rewards Points: 72
I don't know about you guys, but I'm ALWAYS worried about VD...you never know what you'll catch
Max C. likes this.
GatorIE is offline
Old 05-14-2020, 05:27 PM   #12
Rewards Points: 42
Yep. That's what I told the client. I think 2.0 is a bit much. He only wants a couple of outlets for his "man-cave". Also, I have seen many jobs where romex was used in pvc used just for a couple of lighting circuits.
Old 05-14-2020, 05:29 PM   #13
Liberal Lesbian
Rewards Points: 28
You’re not supposed to be doing electrical work for clients.
Southeast Power (05-14-2020)
Old 05-14-2020, 05:29 PM   #14
Bird dog's Avatar
Oh yeah...they call those suicide cords.
Old 05-14-2020, 05:32 PM   #15
Bird dog's Avatar
You mean like USB 2.0 or Firewire or maybe a thunderbolt connection? This isn't a tech site.
Old 05-14-2020, 05:37 PM   #16
Rewards Points: 72
Just cause you see it, doesn't mean it's right. There a whole lot of chop-shop, hack job crap out there in service and a whole lot of it has been installed by trunk-slamming handymen. This concept is no different.
Forge Boyz likes this.
GatorIE is offline
Old 05-14-2020, 05:39 PM   #17
Rewards Points: 72
A.K.A. a "gay widowmaker" around here. Vivid but accurate description right there.
GatorIE is offline
Old 05-14-2020, 06:31 PM   #18
Rewards Points: 1,044
Please take a few minutes and fill out your profile. It is required.
Follow the link below for forum profile instructions and requirements.
https://www.electriciantalk.com/f3/a...fields-258186/
John Valdes is online now
Old 05-14-2020, 07:04 PM   #19
Rewards Points: 42
Since the structure is a tool shed not a man-cave that only needs a couple outlets and lights it doesn't require a 90a panel. Voltage drop is negligible. So, my question is, if I run the wire in pvc, whether it's 3/4 inch or 1 inch or 2 inch the only question here is why can't I use romex instead of UF if it is going to be run in pvc anyways? I know the clients needs and I can't see running 2 awg that distance.
Old 05-14-2020, 07:11 PM   #20
Rewards Points: 2,965
What does your code book say?
Max C. and Superman like this.
99cents is online now
Closed Thread
