Man Vs. Steel - Page 2 - Electrician Talk - Professional Electrical Contractors Forum
Old 03-08-2014, 12:24 PM   #21
LawnGuyLandSparky's Avatar
Rewards Points: 172
Sorry, but when I did resi all the grounds were done 1st, spin 'em all up into one tight twisty cable and put them under one big screw in the neutral bar. Landing each one individually well... that's just not productive. And when you think about it, when you're working on anything are you really thinking about taking more time because a faster method might negatively impact some future electrician? C'mon...
The Following User Says Thank You to LawnGuyLandSparky For This Useful Post:
MHElectric (03-08-2014)
Old 03-08-2014, 01:29 PM   #22
Can't Remember
Rewards Points: 1,438
I might actually be the one that comes back to work on it so I do it as such. I have seen some beautifully done panels with the twisty method, but just choose not to do it that way.
Old 03-08-2014, 01:36 PM   #23
360max's Avatar
Rewards Points: 1,234
I wish Mayor Bloomberg would bankroll Obama, so we can get the law changed, so Obama can run for a third term.
Old 03-08-2014, 01:57 PM   #24
MHElectric's Avatar
Rewards Points: 5,596
While I understand and agree with your opinion here, I need to point out that most jobs of this nature, you will never come back to work on them again. Seriously. Most services will outlive you.
I understand your point quite well, and its a very good point I might add, but how many services have you replaced that you originally installed?
Old 03-08-2014, 02:03 PM   #25
Can't Remember
In all honesty, some of it comes down to how we were taught and dammit, that's the only way it should be done. Poking some fun at myself.
Old 03-08-2014, 02:36 PM   #26
Jesus Scott
electricmanscott's Avatar
Rewards Points: 232
Following the code is for sissies.
Life is hard
Old 03-08-2014, 02:37 PM   #27
Jesus Scott
Rewards Points: 232
Somebody like you would.
Life is hard
Old 03-08-2014, 02:40 PM   #28
MHElectric's Avatar
Nothing wrong with that man. Im not busting chops, I understand where your coming from. I had a very similar outlook on things for quite a while, but competing against so many cut-throat jack-legs has turned my motives now to the bottom dollar and cost effective installation methods instead of worrying about the next guy.
Old 03-08-2014, 04:33 PM   #29
MTW
Rewards Points: 11,454
It should be noted that twisting all the grounds together and putting them under one terminal is likely a listing violation of the terminal. I've never seen one rated for more than 3 EGC's under one terminal. Oh, and it's hack work too.
Old 03-08-2014, 04:38 PM   #30
Can't Remember
I could see why it was done in some of the older panels where the amount of neutral bar space wasn't exactly generous.
Old 03-08-2014, 04:42 PM   #31
erics37's Avatar
Rewards Points: 642
Just cut that EGC candy cane off short and pigtail a #10 or 8 or whatever out of it with a big blue wire nut
The Following 2 Users Say Thank You to erics37 For This Useful Post:
MHElectric (03-08-2014), MTW (03-08-2014)
Old 03-09-2014, 08:14 AM   #32
Sentimental Mental
CTshockhazard's Avatar
Rewards Points: 1,688
That'd work.....
......be a real beotch swapping the can though.
I hate to see her go, but I sure love watching her walk away.
Old 03-09-2014, 08:35 AM   #33
Rewards Points: 172
Didn't matter. It's just the way grounds were treated, and it was acceptable. Same thing in a 3-gang switch - twist all the grounds, chop all but one off, and loop all the switches. No wirenut necessary. Nobody died. Gotta dig that 3-gang out to install a 4 gang? Not my problem.
Old 03-09-2014, 09:12 AM   #34
Southeast Power's Avatar
Rewards Points: 9,082
You mentioned that the old panel was shot on the wall and you had to fight it to remove it.
I can usually pop them off with a hammer and chisel but if they give me any trouble at all, I get my .27 cal Hilti gun out and shoot them all the way through.
I love tap cons...
I need help with a bid, steel building. five.five-six Commercial Electrical Forum 20 01-12-2014 06:31 PM
EMT to Steel Flex? Voltech NEC Code Forum 8 02-19-2011 10:15 AM
Is it building steel or not? Gaffer15 General Electrical Discussion 2 01-20-2011 05:39 PM
PVC v.s. Steel BobBob General Electrical Discussion 9 01-11-2011 10:26 PM
steel bonding? calimurray NEC Code Forum 8 05-21-2008 12:42 PM
