Manufactured Home Codes - Electrician Talk - Professional Electrical Contractors Forum
Like Tree18Likes
Old 06-24-2016, 11:35 PM   #1
smorkle's Avatar
Rewards Points: 150
Default Manufactured Home Codes
I had a customer this week that I set up the service for a 2016 model mobile home. These things have come a long way since the little single wide my uncle lived in when I was a kid. Anyhow, I noticed a few things that stuck out in my head. There was not one arc-fault device in the whole house. There was not one tamper proof receptacle anywhere. How come if I wire a house I get gigged by the inspector if I dont have a GFI in some goofy place (like the garage door opener) but these homes are exempt from the same rules? It seems to me if codes are written to keep people safe then are people who buy mobile homes not important enough to be safe like site built home people? It's like some huge double standard.
smorkle is offline   Reply With Quote
Old 06-24-2016, 11:45 PM   #2
Rewards Points: 26,920
When you're right, you're right.
It's a double standard... a double-wide standard.
Last I looked, these installs are under the standards authority of HUD.
Yes, the Feds have over-jumped all local AHJ.
Old 06-24-2016, 11:45 PM   #3
MHElectric's Avatar
Rewards Points: 2,426
That manufactured home was wired in some factory far far away where it isn't required. The only wiring that gets inspected with any REAL inspections is when they set it on someone's property, and you hook up the service to it.
MHElectric is online now   Reply With Quote
Old 06-25-2016, 12:07 AM   #4
smorkle's Avatar
Rewards Points: 150
I know it's manufactured in a plant somewhere, but it is STILL under the jurisdiction of the National Electrical Code. I understand HUD has a hand in the whole process but it seems like there would still be some continuity in wiring codes. Last I checked, the NEC covered everyone in the US.
Old 06-25-2016, 05:28 AM   #5
Rewards Points: 52
Some places don't operate under the current NEC. I wonder if that plays into it
TRurak is offline   Reply With Quote
Old 06-25-2016, 06:26 AM   #6
Retired Account
Rewards Points: 14,650
First off art 550 & 551 are a departure from normal nec standards , heavily lobbied over time to assume the need for meg tests ,due to inferior materials (that are then transported over miles of frost heaves ,etc)
Secondly would be where they 'set up shop' , usually in unlicensed states , the lowest possible denominator oversight following suit.
Third would be their target market, usually states which have or require no single family inspections .
Last but not least are those middlemen shops who purchase/set up what are commonly coined 'zipper homes' . They usually employ bottom of barrel 'carpenters' ,usually with conditions of parole, bottle in the lunch bucket etc. No tradesman in their right mind makes a career out of stitching a hack together
Having been involved in litigant shenanigans pursuant to a certain manufacturer summarily kicked out of my state ,i can only say if you're an EC document the daylights out of any 'manufactured job' you're handed
CT Tom and emtnut like this.
Old 06-25-2016, 06:56 AM   #7
Rewards Points: 24,234
Let's not forget that an 'engineer' has stamped the electrical and plumbing design of said mobile home and any variances in code have been left in the dust on that sealed document.
Old 06-25-2016, 07:19 AM   #8
NOPE.
and
NOPE.
Old 06-25-2016, 09:02 AM   #9
Safety Pin Member
PlugsAndLights's Avatar
Rewards Points: 2,880
MDVR has a good point. It's certainly the case up here that a
"professional engineer" has the final say. Not the AHJ. Not the
(OESC) code.
P&L
Old 06-25-2016, 09:07 AM   #10
(OESC) code.
P&L
I've looked at some of the completely bogus ways things are done in prefab (mobile) homes that would never fly under normal codes and inspections, very poor designs.
chicken steve likes this.
Old 06-25-2016, 12:45 PM   #11
Retired Account
These really get my goat>
a little research lent to their usage being 'pass thru' , the (usually 14-2) is stripped ,not cut , and pressed in via the back plate.
So anytime you see three 14-2's , it's a cob job
readydave8 likes this.
The Following 2 Users Say Thank You to chicken steve For This Useful Post:
Bird dog (06-25-2016), readydave8 (06-25-2016)
Old 06-25-2016, 12:48 PM   #12
Oh now that is some quality right there.
Old 06-25-2016, 12:56 PM   #13
Retired Account
Yuppy,
these are even better>
In the larger units, one piece makes into the panel , all other home runs are these 'snap together' deals ,which carry the full circuit load through a press in connection.
I 'got into it' with one local shop ,because they were going to bury them all , and i just don't like buried splices
They fired me....
A year later , they hauled the company PE into court , that was one of a multitude of construction related issues
The lawyers solicited me as 'expert witness' against him
Poetic justice, eh?
MechanicalDVR and readydave8 like this.
Old 06-25-2016, 12:58 PM   #14
Retired Account
Forgot to add, the local shop was sued out of biz, and the pos that fired me works at HD now .....never asks me if he can help me find anything thou... ~CS~
Old 06-25-2016, 01:00 PM   #15
If he did offer help I hope you'd advise him he is the last person you'd ask a about anything more than the direction to the men's room.
Old 06-25-2016, 01:44 PM   #16
Rewards Points: 1,208
I suspect that mobile homes being a manufactured product fall under the same category as a troffer with 22 ga. leads. I follow the advice of an old Chicago electrician cerca 1975:
1). Disconnect all 120-volt trailer wiring.
2). Run new surface EMT wiring.
Tiger is offline   Reply With Quote
Old 06-25-2016, 02:54 PM   #17
neutral member
readydave8's Avatar
Rewards Points: 344
I see worse in stick built than trailers very often, DIYers of course, but we still have counties without inspections, so often wiring in recently built houses is sometimes horrible.
But I absolutely hate those devices and connectors CS posted, not only prone to fail but often hard to find due to the way circuits skip around
Dave Ruth
Old 06-26-2016, 08:26 AM   #18
smorkle's Avatar
Rewards Points: 150
This house I was working in doesn't have those "press-in" receptacles. Every box in the house is a cut-in box with a standard 15A device. Even the light fixtures are cut-in boxes. The guy was wanting to put a couple of ceiling fans up in place of a light and I looked into it and just said no.
Old 06-26-2016, 09:21 AM   #19
Can't Remember
Rewards Points: 1,536
Have seen some very nice looking panels in them. Have also seen the old work boxes, the thin outside walls, and the plastic connectors. Most of the time, the connectors were in the attic or basement, so you could replace them with nail ons or four squares. I asked a state inspector about it, why no AFCI or TR receptacles, and he said they had no jurisdiction over them. Tiny panels full of twins with no room for AFCI if modifications or receptacle replacement were done.
Old 06-26-2016, 09:24 AM   #20
Only decent modulars I've seen was a company out of north Jersey that makes modular diners and that type of building. Some of their kitchen electrical work is top of the line but they are basically a custom builder.
New home today's price Northern Girl Business, Marketing, and Sales 45 06-30-2016 09:34 PM
Manufactured home Silver Label electricguy Canadian Electrical Forum 4 06-18-2016 04:43 PM
Home automation vera edge freefreeqaz General Electrical Discussion 3 06-07-2016 05:15 PM
Wink relay home controller mark35 Electrician Swap 4 04-23-2016 07:44 PM
Mobile Home SparkyJ Residential Electrical Forum 10 04-08-2016 07:21 AM
