Maximum run timer - Electrician Talk - Professional Electrical Contractors Forum
Like Tree8Likes
  • 1 Post By telsa
  • 1 Post By splatz
  • 2 Post By Wirenuting
  • 4 Post By splatz
Old 12-27-2018, 08:03 PM   #1
Rewards Points: 574
Default Maximum run timer
I have a customer who wants to put a timer (30 minutes) on his air compressor so if a hose blows it wont just keep running. I'm thinking maybe an off delay timer, but I dont do this kind of thing very often. Is there something better out there?
John M. is offline   Reply With Quote
Old 12-27-2018, 08:08 PM   #2
Rewards Points: 26,836
Good grief. Pneumatic hoses are not supposed to be left in a pressured condition in off-hours.
In ordinary use, the system is to be shut down every night and drained.
Otherwise the water build-up will rust out the tank.
Are you sure this dude knows what's up?
electricguy likes this.
Old 12-27-2018, 08:26 PM   #3
Rewards Points: 2,408
Use an on-delay relay set for 30 minutes.
Put the coil in parallel with the power for the compressor starter.
Put the NC contacts in series with the power for the compressor starter, ahead of the starter.
When the power for the compressor comes on, the timer will start.
If it is on for 30 minutes, the NC contacts will open, turning of the compressor.
When power for the compressor starter goes off, it will reset the timer, the NC contacts will close but the compressor will still be off.
Gnome likes this.
This too shall pass.
Old 12-27-2018, 09:39 PM   #4
Coffee drinking member
Wirenuting's Avatar
Rewards Points: 7,372
Until the pressure drops below kick on them it runs for 30 minutes again.
Itís harder on the compressor and motor to cycle then it is to just run.
We get run-a-ways often enough that we donít worry about it. The units need to be checked often enough anyway.
He should just turn it off when not needed.
emtnut and telsa like this.
Old 12-27-2018, 10:53 PM   #5
ppsh's Avatar
Rewards Points: 166
The common setup I have seen is a 2-12hr preset countdown timer controlling a relay interrupting the contactor coil power. Or said timer controlling a 3p contactor on the compressor feed if the compressor is out in its own shed or something.
Come into work for the day, start the timer, set and forget.
ppsh is online now   Reply With Quote
Old 12-28-2018, 03:28 PM   #6
Band Member
emtnut's Avatar
Rewards Points: 2,510
Agreed Wirenuts !
Having the timer hit an 86 relay or a shunt breaker could work.
ppsh's idea is probably the easiest thou.
Old 12-28-2018, 03:32 PM   #7
Rewards Points: 908
Wire the coil with the shop lighting circuit. change the coil to 120 volts and direct wire the coil from the lights, or use a small current sensing relay, or use a dp switch, or use a control relay. etc.
Old 12-28-2018, 03:39 PM   #8
I thought the OP's idea was, if it's running forever and not getting up to pressure, shut it off - there's a hose open or something.
I made a ladder diagram of what I had in mind. After half an hour on the ODR, it closes the NO contacts / opens the NC contacts.
If the pressure goes low and stays low, after half an hour the ODR interrupts power to the compressor off and lights an alarm light.
You'd hit reset, see what's open, and you have half an hour to find what's hissing and fix it.
(BTW, you can make ladder diagrams in <5 minutes with this draw.io thing that @macmikeman showed )
telsa (12-28-2018)
Old 12-29-2018, 06:21 PM   #9
Wirenuting's Avatar
Ok now I see what you mean..
I forgot about the drawing app.. Been a few years since I've used it.
Help Wiring a 7 day digital timer david999 General Electrical Discussion 11 11-23-2018 02:23 PM
Normally Closed Timer Switch sabre170 General Electrical Discussion 4 01-26-2018 10:06 PM
timer hardworkingstiff Tools, Equipment and New Products 28 04-20-2017 08:17 PM
Switch Time clock to Orbit Sprinkler Timer The_notorious_Rookie Residential Electrical Forum 21 08-23-2016 10:33 AM
Simple timer with two functions farlsincharge PLCs, VFDs, Motors and Controls 12 02-23-2016 08:04 AM
