Mc cable on sheet metal covered wall - Electrician Talk - Professional Electrical Contractors Forum
Like Tree2Likes
  • 2 Post By splatz
Old 09-09-2017, 11:37 PM   #1
rrolleston's Avatar
Rewards Points: 1,134
Default Mc cable on sheet metal covered wall
Mounting a few disconnects on a sheet metal wall and running some Mc cable do I have to switch to emt on the wall? the Mc will be about 6' up. Using one 20 amp circuit for per two pump motors less than 5 amps each. Feed two disconnects and fuse down for each motor. Won't be any water in this room just piping across the floor to pumps
Sent from my SM-S975L using Tapatalk
Old 09-10-2017, 01:02 AM   #2
Rewards Points: 3,006
It depends if you feel the MC needs protection from damage.
You can always sleeve it in EMT if you feel it needs protection.
Old 09-10-2017, 04:15 AM   #3
Rewards Points: 26,502
In the few instances like this... I'd spread out the fastening load by way of shallow strut.
I don't trust sheet metal to really hold that many pounds per fastener.
Old 09-10-2017, 08:22 AM   #4
Southeast Power's Avatar
Rewards Points: 8,678
What wiring method will you be using from the disconnect to the motors?
Old 09-10-2017, 08:29 AM   #5
I think that's why he is asking.
I try to think what I would use romex for in a residential application and if didn't think that was safe or nice looking, I would use that same application for MC.
For me, I dont think MC is something I like to see exposed below ceiling level.
If the OP is using carflex or greenfield to connect the motors, I would suggest he use it for the line side and terminating that in a 1900 box higher up above the sheet metal.
$20 worth of material would look 20 times better.
Old 09-10-2017, 08:39 AM   #6
If that is his question we need way more details.
Old 09-10-2017, 09:05 AM   #7
Rewards Points: 1,176
The sheet metal is on something, furring strips or studs or whatever, it might be easier and quicker to just find the studs, slap a piece of strut on vertical, and do it in conduit, rather than try to make the MC come out decent.
frenchelectrican and telsa like this.
Sheet metal screws used on grounding bars? pullnawg New Member Introductions 23 07-21-2017 05:24 PM
Vapor seal for EZ box on outside wall? meggerman Canadian Electrical Forum 4 09-30-2016 12:09 AM
Ground/Shield VFD cable termination Kris Wu General Electrical Discussion 8 07-07-2016 01:58 PM
Venting, not HVAC 220/221 General Electrical Discussion 6 07-07-2016 11:09 AM
locating conduit or LV cable behind wall or missing conduit end? lortech Structured Wiring 3 01-18-2016 01:35 PM
