Metric threads - Electrician Talk - Professional Electrical Contractors Forum
Like Tree3Likes
  • 1 Post By readydave8
  • 1 Post By bostonPedro
  • 1 Post By sbrn33
Old 10-21-2018, 08:02 PM   #1
Nolanmichaelp's Avatar
Default Metric threads
Can anyone tell me if there are any supply houses or lighting places in New Jersey that deal with metric threads. I’ve never come across this before. I’m hanging 2 chandeliers and they have a rod and hook (no chain) attachment point. But the threaded lamp pipe is a metric thread and nobody knows what I’m taking about or where to direct me. Has anyone seen this before?
Nolanmichaelp is offline   Reply With Quote
Old 10-21-2018, 08:11 PM   #2
Southeast Power's Avatar
Rewards Points: 8,728
Originally Posted by Nolanmichaelp View Post
Can anyone tell me if there are any supply houses or lighting places in New Jersey that deal with metric threads. Iíve never come across this before. Iím hanging 2 chandeliers and they have a rod and hook (no chain) attachment point. But the threaded lamp pipe is a metric thread and nobody knows what Iím taking about or where to direct me. Has anyone seen this before?
Is the fixture listed?
Old 10-21-2018, 08:16 PM   #3
I have no idea. I would imagine it’s not. It was hand made in a village in greese. However this home owner is also the mechanical contractor that keeps us busy all year long so needless to say ... it’s going up one way or another.
Old 10-21-2018, 08:19 PM   #4
neutral member
readydave8's Avatar
Rewards Points: 140
Default chandelier from greese
title was different when he asked in Residential Forum
that one was closed
I don't know the answer anyway, though
John Valdes likes this.
Dave Ruth
Old 10-21-2018, 08:32 PM   #5
Somebody decided to close it and refer me to a DIY website. I’m a career electrician, but I seldom work in houses. Normally google can clear most of this up but I can’t find anything at all
Old 10-21-2018, 08:32 PM   #6
Ctsparky93's Avatar
Rewards Points: 12
If you need metric nuts fastenal would probably have them on the shelf. if not they will get them. What size?
Ctsparky93 is offline   Reply With Quote
Old 10-21-2018, 08:38 PM   #7
Ctsparky93's Avatar
Rewards Points: 12
Can you use something similar to this? How much does this thing weigh? https://www.homedepot.com/p/Westingh...-204836038-_-N
Old 10-21-2018, 08:40 PM   #8
Rewards Points: 1,230
what exactly are you looking for?
a threaded rod?
A nut?
bolts?
What size in metric?
MikeFL likes this.
bostonPedro is offline   Reply With Quote
Old 10-21-2018, 08:50 PM   #9
It measures 12mm fixtures weigh roughly 65lbs. Somehow I don’t believe in 2 10-32’s to hold these things up even if I sandwich the plate with two 12mm nuts
Old 10-21-2018, 08:59 PM   #10
daveEM's Avatar
Rewards Points: 2,382
65 pounds? Not listed?
1/2 redi-rod.
I was actually in your position 20 years or so ago. Stupid fixture won fixture of year at some contest. Dr. paid about 17 grand for it. Weighed maybe a pound but wasn't approved.
I never hung it. Never worked for the contractor again either. Oh well I found other work.
We can get weird stuff approved here for around $400 and we got metric stuff.
I like perfect.
Old 10-21-2018, 09:04 PM   #11
Rewards Points: 254
Welcome to Electrician Talk
Please take a few minutes and fill out your profile.
Old 10-22-2018, 12:33 PM   #12
just the cowboy's Avatar
Rewards Points: 152
12 mm seems like a od size. Most pipe size are 10mm or 15mm, and are not far off of 3/8' & 1/2" standard thread because it is British thread sizes.
Old 10-22-2018, 12:41 PM   #13
MikeFL's Avatar
Rewards Points: 630
Can you cut the ends of the pipe off and rethread it?
Or find another pipe and rework the receiving part of the fixture?
Michael Gookin, President
GPS Timers
(833) GPS-TIME
Old 10-22-2018, 12:50 PM   #14
sbrn33's Avatar
Rewards Points: 3,516
I would hang my fat ass off two 10-32 screws.
macmikeman likes this.
The Following User Says Thank You to sbrn33 For This Useful Post:
macmikeman (10-22-2018)
Old 10-22-2018, 01:53 PM   #15
Rewards Points: 18,295
10/32 machine screws effectively have a sheer strength of 125 lbs. Two added together will provide 250 lbs of load support. Unless Sabrina is more than 250 lbs he has nothing to worry about, and the op doesn't either.
JOBS GROWTH SOARS
RECORD WORKING
UNEMPLOYMENT 50-YEAR LOW
Drudge Report
Old 10-22-2018, 10:50 PM   #16
Understood, but that sh**y
Okey doke depot bracket is literally made of garbage. The rod itself is literally the decor of it all, the hook is part of the lamp pipe. The inside diameter is larger than 3/8” and the OD is 12mm (smaller than 1/2”) so my last ditch effort will be to hold it up with tie wire and hope for the best.
Old 10-22-2018, 11:09 PM   #17
Rewards Points: 26,606
Grainger ?
Imperial to metric bushings gpop Industrial Electrical Forum 17 05-31-2018 11:25 PM
Locking old threads eddy current Site Help and Suggestions 18 11-23-2017 10:14 PM
ignoring individual threads PlugsAndLights Site Help and Suggestions 9 02-14-2017 04:31 PM
Old posts getting revived years after op, and closed dyi threads Obsoletelaw Site Help and Suggestions 22 04-05-2016 10:16 AM
