Milwaukee 2629-20 blade comes off - Electrician Talk - Professional Electrical Contractors Forum
Like Tree6Likes
  • 1 Post By Jlarson
  • 1 Post By MechanicalDVR
  • 2 Post By MechanicalDVR
  • 1 Post By HackWork
Old 05-26-2017, 08:53 PM   #1
Rewards Points: 554
Default Milwaukee 2629-20 blade comes off
I have a milwaukee 2629-20 bandsaw that the blade keeps popping off. I tried a new blade, but it still does it. Any ideas?
John M. is offline   Reply With Quote
Old 05-26-2017, 09:08 PM   #2
Rewards Points: 3,044
How old is it?
Could a wheel bearing be worn?
Old 05-26-2017, 09:14 PM   #3
Rewards Points: 554
Probably five years
Old 05-26-2017, 09:27 PM   #4
Jlarson's Avatar
Rewards Points: 4,074
Worn tires is usually number one.
Old 05-26-2017, 09:42 PM   #5
Yup, time for pulley tires.
Pulley Tire
Part Number: 45-69-0030
John M. (05-27-2017)
Old 05-27-2017, 07:20 AM   #6
Rewards Points: 554
Someone suggested worn bushings? Is that possible?
Old 05-27-2017, 08:53 AM   #7
Rewards Points: 1,292
I'd think you can feel if there is much play on the bearings themselves and it would take quite a bit of wear on the bearings before the blade would slip off. The tires are more likely to be the wear part, it's just friction that makes the blade go around. They might not even be worn, just glazed.
This could turn out badly but I wonder what would happen if you applied a little automotive belt dressing to the tires, might buy you a little time.
Old 05-27-2017, 04:08 PM   #8
Rewards Points: 36
A proper crown on at least one pulley is essential to a stable self- centering operation.
This can be from a crown on the pulley itself or a thick center on the belt, or a combination.
Sent from my XT1585 using Tapatalk
inetdog is offline   Reply With Quote
Old 05-27-2017, 04:50 PM   #9
The tires are less than $3 a piece so after 5 years in service $6 in repair parts is nothing to invest.
frenchelectrican and splatz like this.
Old 05-27-2017, 05:28 PM   #10
Rewards Points: 21,898
Most common is worn tire. the other item is the roller guide that is second most common wear part.
you may have to get one of the construction square to check the wheels to make sure they are line up properly too sometime but not always but the frame can get little bent too if dropped often.
so just check it out after ya pop in the new tires then it should be good to go.
Old 05-27-2017, 08:19 PM   #11
I had a bearing go bad on my Milkw. electric bandsaw very prematurely a while back, that was why I mentioned that first . It was easy to see with just a quick look.
Only time I've had to swap one out.
It is normally just the tires.
frenchelectrican likes this.
Old 06-03-2017, 01:59 PM   #12
Rewards Points: 554
I installed new tires....same thing. Any more ideas?
Old 06-03-2017, 02:05 PM   #13
Rewards Points: 7,631
A new band saw.
Old 06-03-2017, 02:12 PM   #14
Rewards Points: 1,623
Are you putting the blade correctly between the 2 roller bearings? There are 4 of them, 2 on each side of the cutout opening.
THose bearings will fail after time, usually the saw starts making really sloppy cuts when that happens.
Old 06-03-2017, 06:08 PM   #15
Rewards Points: 554
Yep, doing that. Everything seems tight. It bugs me...probably a simple thing, but I'm not finding it.
Old 06-03-2017, 06:24 PM   #16
Jlarson's Avatar
If the tires didn't fix it then worn bearings is the next likely cause.
It didn't take a really hard fall at some point did it?
Old 06-03-2017, 06:37 PM   #17
Rewards Points: 554
Not that I remember, but its happened with my tools.
Harbor Freight Milwaukee Tool Knock Offs active1 Tools, Equipment and New Products 15 04-29-2017 07:46 PM
Milwaukee V28 drill WronGun General Electrical Discussion 17 01-01-2017 12:41 PM
Issue Resolved-I'm not happy with Milwaukee Tools as a company HackWork Tools, Equipment and New Products 60 10-27-2016 07:16 PM
milwaukee 12v power tools HAL9000 Tools, Equipment and New Products 21 09-20-2016 12:45 AM
Converting from DeWalt to Milwaukee TheApprentice_ Tools, Equipment and New Products 32 01-30-2016 04:07 PM
