Mixing 30K and 40K fixtures - Electrician Talk - Professional Electrical Contractors Forum
Like Tree11Likes
  • 1 Post By Southeast Power
  • 2 Post By 99cents
  • 1 Post By Majewski
  • 3 Post By MechanicalDVR
  • 2 Post By splatz
  • 1 Post By bullheimer
  • 1 Post By Cl906um
Old 04-28-2017, 09:25 PM   #1
Rewards Points: 592
Default Mixing 30K and 40K fixtures
I am putting some LED fixtures in a commercial building. The print calls for 40K Led recessed fixtures with 30K LED recessed lights in the offsets of the room. Will it look right to mix colors like that?
John M. is offline   Reply With Quote
Old 04-28-2017, 10:09 PM   #2
Southeast Power's Avatar
Rewards Points: 9,336
They have different uses. Could be the design. I would install it.
Old 04-28-2017, 10:23 PM   #3
Rewards Points: 3,319
Go by the drawing. If they don't like it, change order. And, yes, the difference is noticeable side by side.
Dash Dingo and Majewski like this.
Old 04-28-2017, 10:30 PM   #4
Big nosed attic troll
Majewski's Avatar
Rewards Points: 2,820
99 is right, if you smell a change order..... ride that baby out!
99cents likes this.
Old 04-28-2017, 10:33 PM   #5
Rewards Points: 24,442
Do what the customer requests and then change it when they don't like it.
bullheimer, Majewski and Cl906um like this.
Old 04-29-2017, 05:59 AM   #6
Rewards Points: 3,082
I'd make 100% sure to submit something to someone in writing pointing out that there are two different light color and that this is not the usual setup, but that you're going to proceed as per the drawing unless otherwise directed. Probably just a single email to the GC.
If your customers listen to you like mine, it's at best 50-50 anyone will even read it let alone do anything about it, but this way there won't be any bitching that you should have caught this - you did catch it.
MechanicalDVR and Signal1 like this.
#HACKLIVESMATTER
Old 04-29-2017, 01:22 PM   #7
Rewards Points: 86
bullheimer is offline   Reply With Quote
Old 04-29-2017, 04:49 PM   #8
One could always just say "I figured it was a design requirement".
Old 04-29-2017, 05:56 PM   #9
Cl906um's Avatar
Rewards Points: 1,206
Dealing with rfi s sucks. To get an answer takes longer than wiring it wrong three times over. I hate the fact that engineering pays so much, but gets so little done. It all looks good on paper. The skilled worker shortage is gonna cut deep fast.
