Motor Controls - Electrician Talk - Professional Electrical Contractors Forum
Old 03-24-2009, 12:12 AM   #1
Default Motor Controls
Hi Sirs, I kindly ask the ff. questions:
1. Standard height of starter panels if any.
2. Minimum time delay for reversing motor rotation.
3. The correct position of OCR or OL Relay for Wye-Delta Starters.
4. Codes for Motor Duties (e.g. AC60, AC3)
joerhenmelo is offline   Reply With Quote
Old 03-24-2009, 12:33 PM   #2
Rewards Points: 1,058
Accessible. No specific rule.
Depends on how the motor is started. Soft Start/Wye delta/ VFD/ Across Line, and what it is driving. Reversing motors while still turning can damage equipment, break motor shafts ect... Generally the motor should be stopped completely. Use a motor brake if required. VFD's allow this type of action under ideal circumstances. If you must reverse a motor while it is still turning you need a brake at minimum and a VFD at maximum or BOTH.
That is a design issue and has no rule. However, usually the contactors are mounted with two side by side and one under the contactor on the left. The far right contactor is usually the one jumped out (wye) operation. European systems do not do it this way, and you will find all kinds of installs.
National Electrical Code, Engineering handbooks ect....
[/quote]
Ps....You may want to get some insight from someone familiar with your location. I doubt your requirements are the same as the US.
controls screwdriver pehelectric Tools, Equipment and New Products 16 09-19-2009 09:56 PM
Some Work I did Last Winter For Johnson Controls Stan Mason Structured Wiring 7 11-09-2008 07:36 PM
Some controls wiring help please dowmace General Electrical Discussion 9 01-27-2008 09:49 AM
Sensors and controls electromanj NEC Code Forum 1 01-26-2008 04:14 PM
Controls Circuits and Exposed Bus in Same Enclosure Adwen General Electrical Discussion 5 01-03-2008 10:51 PM
