Mr Highleg expert buys new AC and ballasts - Electrician Talk - Professional Electrical Contractors Forum
Like Tree19Likes
Old 02-03-2017, 06:11 AM   #1
Southeast Power's Avatar
Rewards Points: 9,264
Default Mr Highleg expert buys new AC and ballasts
We changed a panelboard the other day and I didnt notice one of the breakers was on the high leg.
I custom ordered a 3 phase Delta panelboard with two single phase breakers and two three phase breakers.
They ship them out setup with the high leg on B phase.
I noticed the 100 amp two pole breaker was factory installed on A and B phase. I couldn't easily see how the 150 amp 2 pole breaker was connected, it was late in the afternoon and getting dark.
The entire building had the hi-leg on C phase so, I said screw it, they must have shipped it out wrong, High Leg on C phase, and installed it.
I turned everything back on and we left.
The next morning I get a call.
Small window shaker was not working, 4 strip lights not working.
The 150amp breaker was on the bus with A and C.
Well screw me for not checking.
The bus fingers arrived overnight from Siemens.
We go in this morning to "correct" MY mistake.
Always be on the look out for that High leg folks!
electricguy (02-03-2017)
Old 02-03-2017, 06:48 AM   #2
Retired Account
Rewards Points: 14,650
High legs suck.....~CS~
John Valdes (02-03-2017)
Old 02-03-2017, 08:33 AM   #3
Rewards Points: 578
I'm not understanding what actually happened wrong...?
Old 02-03-2017, 08:38 AM   #4
Retired Account
He changed the H-leg configuration , didn't work out well ~CS~
MechanicalDVR and circuitman1 like this.
Old 02-03-2017, 08:39 AM   #5
Rewards Points: 24,234
High leg on a phase Sunny didn't anticipate and he fried a few things. Notably a window ac and some ballasts.
He should have checked voltage on the breakers before connecting loads.
Sunny's attempt at being humble sharing his blunder.
cl2sparky likes this.
Southeast Power (02-03-2017)
Old 02-03-2017, 08:41 AM   #6
Rewards Points: 578
How is there a high leg issue with a 2-pole breaker?
Old 02-03-2017, 08:42 AM   #7
Hmm?
Old 02-03-2017, 08:44 AM   #8
Rewards Points: 578
Depends on which two phases it's on.
Why?
Southeast Power likes this.
Old 02-03-2017, 08:46 AM   #9
Retired Account
Some 2P's might be a multiwire w/noodle Hax.....~CS~
Old 02-03-2017, 08:48 AM   #10
Why?
My first thought was a brain fart, I changed my mind after.
Old 02-03-2017, 08:48 AM   #11
backstay's Avatar
Rewards Points: 296
I'd say it was feeding a subpanel.
RePhase277 likes this.
Old 02-03-2017, 08:49 AM   #12
Rewards Points: 578
Oh. I see.
When he mentioned only 2 and 3 pole breakers, I figured this was going to be a panel they used for 208V only.
Old 02-03-2017, 08:49 AM   #13
That would be one hell of a MWBC on a 150amp breaker!
Old 02-03-2017, 08:49 AM   #14
Rewards Points: 578
Ok, another good explanation.
Old 02-03-2017, 08:50 AM   #15
Or the only one.
Old 02-03-2017, 08:59 AM   #16
Rewards Points: 1,360
The utility brings the high leg in on C due to how the meters work.
How is a delta panel different than any other 3-phase panel? Literally every 3-phase 250 volt panel I have ever seen was listed for use on a 4-wire delta.
Old 02-03-2017, 09:58 AM   #17
Rewards Points: 352
Tough break, Bro! You ain't the first and won't be the last. Still sucks!
lightman is offline   Reply With Quote
Old 02-03-2017, 01:44 PM   #18
Rewards Points: 114
Thanks for your candor.
When I was new with the company we did an overnight service change that included three panel replacements. Crew A in the daytime labeled conductors and removed three panel. Crew B installed new panels and relapsed everything. I was on crew B but being the new guy I just shut up and did what I was told like a good helper. So I wasn't thinking about it but we just slammed the panels in an wired everything. Hi leg of course fried a bunch stuff. Crew leader A and crew leader B blamed each other, one for not communicating the other for not checking. I figure it was everyone's fault. For over a decade the hi leg subject would come up and start them arguing all over again.
Old 02-03-2017, 01:46 PM   #19
Rewards Points: 185
408.3(e)
EC2253 is offline   Reply With Quote
Old 02-03-2017, 01:56 PM   #20
LawnGuyLandSparky's Avatar
Rewards Points: 172
No high legs in NYC. PHEW! Dodged that bullet...
Multiple fluorescent ballasts failing JLKing General Electrical Discussion 33 04-28-2017 12:20 AM
Magnetic ballasts to Electric Ballasts swap JLane Commercial Electrical Forum 16 01-08-2017 12:30 PM
Multiple Failed Ballasts? LanceBass General Electrical Discussion 29 08-15-2016 08:24 PM
Burning T8s on T12 ballasts. It can work, with caveats shieber General Electrical Discussion 18 06-09-2016 08:47 PM
remote ballasts farmantenna General Electrical Discussion 1 03-10-2016 08:57 PM
