Mr. Tightwire romex rough - Page 6 - Electrician Talk - Professional Electrical Contractors Forum
Old 11-26-2011, 04:55 PM   #101
Rewards Points: 2,002
Originally Posted by TOOL_5150 View Post
whats a basement?
If I insult you, will you rent a van to come out and beat me up? Then I'll show you what a basement is.
Old 11-26-2011, 05:33 PM   #102
Rewards Points: 154
Originally Posted by Shockdoc View Post
I usually leave that sleeve in to pass right into the cabinets.
That's cool, but LFNMC does not provide mechanical protection per the sited article.
Article 90.1 is offline   Reply With Quote
Old 11-26-2011, 05:34 PM   #103
Ambassador of Amps
TOOL_5150's Avatar
Rewards Points: 2,354
No, ill go check out that rapists/kidnappers basement over in the outskirts of my town. you probably heard of him, he made the news.
Old 11-26-2011, 05:35 PM   #104
BBQ
Salty Member
BBQ's Avatar
In that case I would just remove the LFNMC altogether.
Old 11-26-2011, 05:41 PM   #105
Rewards Points: 198
Yes maybe not, but what exactly is this mechanical protection required for?
Meteorite going to hit the house? Shockdock's sleeve is ******ed. Just stick the romex up thru the wood floor, and if the ****** trades mess it up, backcharge for the repair. Them guys need to have their heads all stove in anyway, such jackass behavior to stomp all over somebody else's work ..... Are they also allowed to bang into anybody's car they choose, just cause the car was in the way when they needed to drive to the job? Kids better stay off the street, cause some real important drywallers are coming thru. Same goes for the woodchucks that forgot to put in all the backing in the kitchen, they get to shoot nails thru any wire that is where they think wood is supposed to go. I refuse to give in to the ****** trades. Make the GC pay until the crap stops.
Libtard logic: It’s okay for people to LOOT in person, but not VOTE in person
Old 11-26-2011, 06:00 PM   #106
You Romex guys have it made. It must be nice to just drill a hole anywhere you want. Thanks for posting some pictures Brings back memories.
Island Electric is offline   Reply With Quote
Old 11-26-2011, 07:02 PM   #107
Bkessler's Avatar
Originally Posted by RGH
Reminded of wiring method oldtimer showed me years ago in tract house job. He would take 4 or 5 pull chain lights and spot'em in basement. Each was 15 amp/cir and that was our start or end point for our lighting and 15 amp loads (bedroom/halls/ect). Sweet trick and I have used it to this day and we wired thru wall and he would yell at me "keep it ta 7 or 8 devices kid". It always worked out and was simple rope method.
That's how i wired houses when i could. Each lighting / outlet homer started on the 2nd floor, hit 5 or 6 dropped down to 1rst floor hit a few then ended as a pull chain, basement gfi, basement smoke ect, that way if a line got cut or missed it could be refed through the basement where the panel was. Cut or missed linea never really happened but it made labeling the panel that much quicker.
When ls lunch?
Old 11-26-2011, 07:14 PM   #108
Retired Account
Rewards Points: 14,650
. I refuse to give in to the ****** trades. .
but by gawd, there's enough of 'em Mac....~CS~
Old 11-26-2011, 07:17 PM   #109
Vintage Sounds's Avatar
Rewards Points: 4,004
Wait, so, it would go from basement panel, to second floor, and eventually back down to the basement again? That seems like a lot of wire although being able to refeed seems handy.
Old 11-27-2011, 12:12 AM   #110
RGH
RGH's Avatar
Rewards Points: 2,044
That was a trick used in most of the post war housing stock I encounter here, but especially common in the 50's and 60's houses.
Nowadays, I consider basement lights on pullchains to be hack work.
So in a 1200sq ft unfinished basement how do you light it?
I rather be fishing......
RGH is offline   Reply With Quote
Old 11-27-2011, 01:05 AM   #111
IET
RobRoy's Avatar
Rewards Points: 1,008
Originally Posted by fondini View Post
I think it looks good,good time spent to.I am going to give this a try
One more thing doc,I drink alone too
I only drink on two occasions... When I'm with someone, and when I'm by myself.
RobRoy is offline   Reply With Quote
Old 11-27-2011, 01:17 AM   #112
RIP 1959-2015
HARRY304E's Avatar
Rewards Points: 1,344
That works .........
Old 11-27-2011, 01:50 AM   #113
RGH
RGH's Avatar
It must be an odd or even date or I dont touch the stuffor be on this forum.....
Old 11-27-2011, 02:07 AM   #114
IET
RobRoy's Avatar
I'll cheers to that
Old 11-27-2011, 10:07 AM   #115
Rewards Points: 252
With keyless lampholders and a switch?
Arc'n'Spark is offline   Reply With Quote
Old 11-27-2011, 10:12 AM   #116
RGH
RGH's Avatar
So if you have say 5 lights in basement area you want all of them to come on at once with that method?
Old 11-27-2011, 10:13 AM   #117
Rewards Points: 2,012
Islands etc: I leave the loop below,drill and install after the piece is placed.
This part scares me!
"those Airtight IC hihats were made for 8" joist, I got them to fit into 6" framing by slicing 2" off the top of the box. The UL police are going to kick my door in.)
Old 11-27-2011, 10:19 AM   #118
Rewards Points: 252
Keyless lampholders and two switches?
Old 11-27-2011, 10:24 AM   #119
Bkessler's Avatar
Yup, all the homeruns were pulled at once through the attic and trickle down to the basement. That way I never had to drill holes across the basement. Three or four is all. It's a big time save if done correctly. This was always done with4 or 5 hard working guys that were all on the same page and could go into a 2800 square foot rough at 6am and leave at 5or6pm with it roughed in 100%.
When ls lunch?
Old 11-27-2011, 10:32 AM   #120
RGH
RGH's Avatar
I like pull chains in an unfinished basement. 1: it gives you options if/when ho finishes basement. 2: they are easy to convert to jbox to alter lighting reqirement in finish project. 3: you don't waste time and $ running sw legs you really don't need or know where they may be wanted in the future layout if it gets finished. I run a 3way top/bot of stairs, then 4/5 pull chain. Easy neat and save 100' wire plus trim outs.
Wiring the rough Wired4Life10 Off Topic (Non Trade) 20 11-08-2011 06:03 AM
Rough Monday Powerfull General Electrical Discussion 24 08-08-2011 05:42 PM
1yr from Rough to Trim Cletis General Electrical Discussion 14 04-17-2011 02:19 PM
New home Rough-in dmoyer1 Residential Electrical Forum 3 03-05-2011 10:32 PM
New House rough-in. Hillbilly General Electrical Discussion 41 03-25-2007 09:19 PM
