Mr. Tightwire romex rough - Page 7 - Electrician Talk - Professional Electrical Contractors Forum
Old 11-27-2011, 10:40 AM   #121
evil bastard
mcclary's electrical's Avatar
Rewards Points: 746
Originally Posted by leland View Post
Islands etc: I leave the loop below,drill and install after the piece is placed.
This part scares me!
"those Airtight IC hihats were made for 8" joist, I got them to fit into 6" framing by slicing 2" off the top of the box. The UL police are going to kick my door in.)
Yeah, that's hack. Halo makes a can that is 5.75"
Old 11-27-2011, 11:24 AM   #122
Rewards Points: 252
Originally Posted by RGH
I like pull chains in an unfinished basement. 1: it gives you options if/when ho finishes basement. 2: they are easy to convert to jbox to alter lighting reqirement in finish project. 3: you don't waste time and $ running sw legs you really don't need or know where they may be wanted in the future layout if it gets finished. I run a 3way top/bot of stairs, then 4/5 pull chain. Easy neat and save 100' wire plus trim outs.
So you do pullchains on a switch? If thats what you're saying, I can understand that and have done the same on occasion. I hate just pullchains with no switch though... might as well not have a light at all.
Arc'n'Spark is offline   Reply With Quote
Old 11-27-2011, 11:45 AM   #123
RGH
RGH's Avatar
Rewards Points: 2,044
No lol 3 way light at bottom of stairs only light on 3 way...rest are p/chained
I rather be fishing......
RGH is offline   Reply With Quote
Old 11-27-2011, 02:25 PM   #124
Electric Al
oldtimer's Avatar
Rewards Points: 2,306
What do you mean by pullchain with no switch?
What does the chain do?
Do you mean keyless lampholder?
Steven Wright
Old 11-27-2011, 02:41 PM   #125
felonious smile.
Shockdoc's Avatar
Rewards Points: 572
But these were CXL and Topaz IC brand , purchased real cheap for $33.00 including trim and bulb. It's just a tin box that got cut down, the inner can remained as is , 5 1/2". I made sure the box top went back on, leaving it off would have been hack.
Old 11-27-2011, 02:48 PM   #126
Rewards Points: 18
I gotta say I like the loop method used by shockdoc. Not so long ago I had to trim out several 12/2 boxes for recepts. By the time I finished, my hands were hurting. It seems the looping method would really save on the hands and make trimming out much easier.
I like the idea and thanks for showing it.
Old 11-27-2011, 03:05 PM   #127
Les Voltage
Originally Posted by Shockdoc View Post
crimping and pigtailing.
Whats to crimp
Old 11-27-2011, 03:11 PM   #128
Bkessler's Avatar
Rewards Points: 2,002
My loops look something like this, usually they are a but bigger.
When ls lunch?
Old 11-27-2011, 03:16 PM   #129
RIP 1959-2015
HARRY304E's Avatar
Rewards Points: 1,344
Originally Posted by Voltech View Post
Whats to crimp
.........http://compare.ebay.com/like/300614874984
Shockdoc (11-28-2011)
Old 11-27-2011, 04:08 PM   #130
Rewards Points: 252
No, I meant pullchain lampholder with no toggle switch wired in series ahead of it. I have done the setup I mentioned (pullchain also controlled by switch) for customers with large unfinished basements before so that lights in frequently used storage areas may be left on at the light and controlled by the switch, leaving the rest off at the light to be turned on with pullchain if/when needed. I said simply having pullchain lampholders is like having no light at all, because til you stumble through the dark to find the first light, do what you need, turn the light off, and stumble back through the dark, you might as well have not had a light at all. RGH apparently remedies this with a switched lighting outlet at the stairs, which he clarified after my previous post.
Old 11-27-2011, 04:14 PM   #131
Electric Al
oldtimer's Avatar
Thanks for the clarification!
I was not sure what you meant.
I have done P.C. lights that way too!
Steven Wright
Old 11-27-2011, 04:29 PM   #132
Rewards Points: 252
Sorry for the confusion. Glad to hear Im not the only one
Old 11-28-2011, 04:16 PM   #133
felonious smile.
Shockdoc's Avatar
Rewards Points: 572
I do the same on almost all minimum code houses. 3 way at stairs covers one light top of stairs and one aside landing, the remaining basement lights are PCs wired to the local 1st fl. ckt. , I 'll even use the PC sometimes as the feed point as well as branching out.
Old 01-31-2015, 02:19 PM   #134
Rewards Points: 825
Originally Posted by user4818 View Post
It would be much faster to use Wagos
What's a wago?
added: nevermind. all over youtube. Seems to be two types though, one with levers, and one like what comes in recessed can j-boxes, where the conductors just push in. the latter seems just as shaky as backstabbing, to me, and I"d like to know the difference. Also, like to know if the lever thing holds up as well. Probably another thread.
mikewillnot is offline   Reply With Quote
Wiring the rough Wired4Life10 Off Topic (Non Trade) 20 11-08-2011 06:03 AM
Rough Monday Powerfull General Electrical Discussion 24 08-08-2011 05:42 PM
1yr from Rough to Trim Cletis General Electrical Discussion 14 04-17-2011 02:19 PM
New home Rough-in dmoyer1 Residential Electrical Forum 3 03-05-2011 10:32 PM
New House rough-in. Hillbilly General Electrical Discussion 41 03-25-2007 09:19 PM
