Multi Family Dwelling Unit - Electrician Talk - Professional Electrical Contractors Forum
Like Tree2Likes
  • 2 Post By MikeFL
Old 03-26-2018, 12:49 AM   #1
Rewards Points: 20
Default Multi Family Dwelling Unit
I am looking for some answer reguarding multi family dwelling units. I recently received some prints to bid on for multi family dwelling units. It has 3 units in the building. I know each individual unit needs it’s smoke/carbon detectors. I’m looking on some advice for the fire alarm system for the 3 story building? What’s the best option to go with? And what would i need to install to bring it up to code.
Sparky1744 is offline   Reply With Quote
Old 03-26-2018, 01:10 AM   #2
Rewards Points: 22,711
Fire alarm systems are part of the building code, so although we all get to wire them, it's not our responsibility, it is the GC's. Around my neck of the woods it is required when there is 8 or more family units in one building, so all it would need is bedroom and hallway wired, connected smokes and also one for each floor hooked in the system also. Each unit control from each unit's sub panel, not a global system building wide.
"Can you just imagine how much better the U.S.A. could have been without all the impeachment, Russia, attempted coup falsehood crap?".......ALARMGUY
Old 03-26-2018, 03:26 AM   #3
Rewards Points: 21,898
That do fall into GC ( General Contractor ) to spec it out and it will be covered by both IBC and state codes plus any local code requirement.
That you have to run by the building or fire inspector to get the latest info.
there is no universal answer on this part.
The smoke alarm will be wired in two ways ., Typically indivual interconnected smoke detectors for each unit but for common area like hallway or basement then it have to be interconnected unless noted otherwise per state/local codes.
The fire alarm that is up to the state codes depending on how many units per building and type of construction it is.
Old 03-26-2018, 05:34 AM   #4
Rewards Points: 2,402
In NC you need a license, that is separate from the electrical license, to wire fire alarms. Also are you sure they are required in a 3 unit building
I can't help it if I'm lucky
Old 03-26-2018, 06:09 AM   #5
Retired Account
Rewards Points: 14,650
2nd that^^^
Old 03-26-2018, 06:28 AM   #6
MikeFL's Avatar
Rewards Points: 950
You need to contact the fire marshal in Philly. There's no way anyone on here is going to know what they require locally. Fire Dep'ts are notorious for local amendments.
frenchelectrican and active1 like this.
Michael Gookin, President
GPS Timers
(833) GPS-TIME
Tags
fire alarm, fire alarm design, multi-family, smoke detector
Multi family feedthrough panel question JBrzoz00 Commercial Electrical Forum 1 12-01-2017 10:40 PM
Rodent damage - Multi Unit Home shocksystems General Electrical Discussion 16 10-30-2017 01:07 PM
Neon Sign in Residential Dwelling Unit A6USMC Residential Electrical Forum 20 03-10-2016 02:18 PM
Dwelling unit explained? TechieBecky General Electrical Discussion 11 01-31-2016 08:35 PM
Multi Family Residential Meter Bank Questions TheLivingBubba General Electrical Discussion 7 01-20-2016 09:07 AM
