need 12vac chimes - Electrician Talk - Professional Electrical Contractors Forum
Like Tree8Likes
  • 2 Post By wildleg
  • 4 Post By samgregger
  • 1 Post By JoeSparky
  • 1 Post By splatz
Old 02-06-2018, 08:50 PM   #1
Rewards Points: 554
Default need 12vac chimes
I am looking for a 12 VAC chimes for in a Sunday School room of a church. I am using a buzzer for the main part, but in a small room that would be deafening. I tried a doorbell; it works fine except the janitors need to hold the button long enough to sound the bells, so this doorbell makes a buzzing noise instead of a melodious chime due to the clapper being held too long. What's available in a pleasing chime?
John M. is offline   Reply With Quote
Old 02-06-2018, 10:01 PM   #2
animal lover /rat bastard
wildleg's Avatar
Rewards Points: 1,038
https://www.amazon.com/Train-Horn-Ki.../dp/B00AA1JD0M
splatz and mikedl361 like this.
Old 02-07-2018, 10:27 AM   #3
Sentimental Mental
CTshockhazard's Avatar
Rewards Points: 1,608
Use one of these
to fire anything of your choosing.
Were you born retaŕded or did you pick that up on your own?
Old 02-07-2018, 11:13 AM   #4
Rewards Points: 1,770
You should not have to hold down a doorbell button for a chime to sound. There are many chimes out there and some you can even set to different tunes.
I can't help it if I'm lucky
Old 02-07-2018, 01:14 PM   #5
Rewards Points: 7,603
If you have access to a computer, the possibilities are endless.
Old 02-07-2018, 03:49 PM   #6
Rewards Points: 1,224
The part that's making it hard is the 12VAC requirement. There are lots of doorbells that would do this without any fuss but after googling it doesn't look like there are any that use 12V power. There may be some that will run on 12VAC even though not rated for it.
Old 02-07-2018, 04:56 PM   #7
Rewards Points: 36
Originally Posted by CTshockhazard View Post
Use one of these
Hey CTshockhazard, what's that device you posted. I'm always wanting to learn more and interested.
mikedl361 is offline   Reply With Quote
The Following User Says Thank You to mikedl361 For This Useful Post:
NewElect85 (02-09-2018)
Old 02-07-2018, 06:13 PM   #8
Rewards Points: 1,361
Looks like a RIBU1C from Functional Devices Inc.
Old 02-07-2018, 06:15 PM   #9
Why is it 12vac? Can you upgrade the transformer to a normal doorbell transformer?
Old 02-07-2018, 08:21 PM   #10
Rewards Points: 3,078
How about THIS?
If it's too loud, place some tape inside the bell.
Greg
Old 02-07-2018, 09:12 PM   #11
Rewards Points: 1,953
Just go buy a cheap Nutone chime kit at your wholesaler. Replace the xfmr. Your buzzer will work just fine on 16vac
lighterup likes this.
The Following User Says Thank You to JoeSparky For This Useful Post:
Old 02-07-2018, 10:03 PM   #12
Rewards Points: 36
Do you know what that device is used for?
Old 02-08-2018, 05:31 AM   #13
It's a relay in a box (RIB) - more expensive than a regular ice cube relay and socket but since it's in its own box you don't have to install an enclosure as well to house the relay. You can just attach this to a junction box and install a relay. This one will work with either low voltage or line voltage control so it's versatile.
shocksystems likes this.
Old 02-09-2018, 09:13 AM   #14
Sentimental Mental
Exactly, that's why I suggested the RIB. Love the various inputs it'll take in both AC and DC.
I've used one in a very similar doorbell situation.
Old 02-09-2018, 10:04 AM   #15
Rewards Points: 3,006
Why?
Old 02-10-2018, 09:36 AM   #16
Sentimental Mental
2 separate systems needed to use the same switches and the voltage ratings didn't match up. These, as far as I know, are the only readily available relays with such a wide range of coil voltages in a single unit.
