Need a custom casing for my project - Electrician Talk - Professional Electrical Contractors Forum
Like Tree3Likes
  • 3 Post By macmikeman
Old 11-10-2016, 01:06 AM   #1
borisdave's Avatar
Rewards Points: 62
Post Need a custom casing for my project
Hi, I need experts advice on the packaging of my new project on Arduino platform. I am a little bit confused about those plastic casing and metallic casing. I found that using metallic/sheet metal/aluminum casings can prevent external interference to the system , but also need proper grounding for such systems.
This project is having 2 Arduino boards
gsm module, Gps module, battery, LCD display.
I am looking for a casing with a minimum form factor so that I can place it on the dashboard of my truck. I had provided some attachments of the modules used in this work. I appreciate any comments on this matter. Forgive me if this post is under the wrong session.
regards
~bor
Need a custom casing for my project-1602-lcd-display-hd44780-control-arduino-supported-03.jpg   Need a custom casing for my project-48912-arduinouno_r3_front.jpg
borisdave is offline   Reply With Quote
Old 11-10-2016, 01:07 AM   #2
borisdave's Avatar
Rewards Points: 62
I am using ribbon wires and single strand wires for interconnection.
Old 11-10-2016, 02:35 AM   #3
Rewards Points: 17,715
B-Nabs, splatz and MikeFL like this.
JOBS GROWTH SOARS
RECORD WORKING
UNEMPLOYMENT 50-YEAR LOW
Drudge Report
Old 11-10-2016, 04:33 AM   #4
Conservitum Americum
LARMGUY's Avatar
Rewards Points: 124
https://www.simcobox.com/News-and-Ar...tic-cases.html
http://www8.basf.us//PLASTICSWEB/dis...01a5e1801499d2
https://www.polycase.com/
Google is your friend
Cowboy words of wisdom.
Old 11-10-2016, 06:34 AM   #5
Southeast Power's Avatar
Rewards Points: 8,620
Didn't have any luck on the Arduino forum?
Ive made a few projects that fit into a T101 timeclock enclosure. They are surprisingly well made, outdoor rated, and lockable.
Old 11-11-2016, 12:50 AM   #6
borisdave's Avatar
Rewards Points: 62
Default all of these are plastic casing
Thank you Larmguy, I checked that PDF guide and sites, all of them are about injection molding and Plastic casing. I am looking for a casing which is durable. I need to fit it on the dashboard of my truck(F 150)
Old 11-11-2016, 01:16 AM   #7
borisdave's Avatar
Rewards Points: 62
http://www.bayviewmetals.com/metal-fabrication/ I found this sheet metal fabricator from Toronto. If I got with such a metallic casing I need to use an external SMA GPS antenna.
Old 11-11-2016, 06:32 AM   #8
Rewards Points: 838
There is probably an alarm can that will work for you, they are made to house a battery and circuit board or boards.
If you insist on a metal box, you will need a short SMA coax jumper and SMA bulkhead connector to mount the antenna externally.
Old 11-11-2016, 09:20 AM   #9
Rewards Points: 2,060
i would use a small lithium pack instead of old acid battery
Old 11-11-2016, 09:21 AM   #10
Rewards Points: 84
just go do digikey, mouser or newark websites, the have different size of housings. you have quit a big battery, can you redesign to use a smaller battery and possible connect it to the 12V supply of your vehicle?
tceek is offline   Reply With Quote
Old 11-18-2016, 01:44 AM   #11
borisdave's Avatar
Rewards Points: 62
Thanks for the suggestion , I will go with acid-acid as it has long backup than a li-ion. I know going with a li-ion can save great space.
hmm, that is also a good option, I think I can do that, a li-ion as a secondary source and 12 V as mains . That is an awesome idea.
I am planning it like this I will try to regulate the input power using LM 7805. Hope that can reduce the size the whole circuit and I need to change the layout of PCB (for power )
Old 11-18-2016, 12:32 PM   #12
use a switching lm7805, you will save a lot of power like this one
with a 12v input a regular 7805 will have about 40% efficiency
this one will have 93%
http://www.digikey.com/product-detai...202-ND/4930586
there are other brand cheaper also
Custom Logo Safety Vest and Hardhats Southeast Power Business, Marketing, and Sales 23 11-20-2016 08:27 PM
How do project contractors evaluate and purchase lighting fixtures? chillasjohnny General Electrical Discussion 16 05-25-2016 02:45 PM
Service call or project? Jason8161 Business, Marketing, and Sales 11 04-10-2016 08:27 PM
Need some help with a project for school zanolazc General Electrical Discussion 3 03-02-2016 12:19 PM
Southern Cali- Ontario Project Niguel Electric Looking To Hire 0 01-14-2016 11:19 PM
