Need Device to Remove Grounding Noise For Audio Equipment - Electrician Talk - Professional Electrical Contractors Forum
Old 06-08-2012, 12:36 PM   #1
Rewards Points: 192
Default Need Device to Remove Grounding Noise For Audio Equipment
Have a client asking me to remove the background buzzing sound he gets while trying to record music at home.
Ive installed a 75 kva transformer and separate service for a church a while back for this same reason, but wondering if they make something simpler for this type of application.
Waiting to hear back from him about all the equipment he will be running so that I can size whatever equipment I might need.
wow
newspark80 is offline   Reply With Quote
Old 06-08-2012, 01:02 PM   #2
Rewards Points: 1,972
You can fix the problem or install a ONEAC isolation transformer.
I would suggest fixing the problem first.
newspark80 (06-09-2012)
Old 06-08-2012, 07:08 PM   #3
220/221's Avatar
Rewards Points: 4,124
In order to fix them, what problems can cause buzzing like this?
I built a small rehearsal/recording studio in my home and I have the same issue. I have discovered that the kitchen, old school fin style 1000W dimmer makes a terrible buzz so I just leave it off. There is also some slight hum from who knows where.
Could/would a dedicated circuit to the equipment help? The ONEAC thing is freakin pricy
220/221 is online now   Reply With Quote
The Following User Says Thank You to 220/221 For This Useful Post:
Old 06-08-2012, 07:45 PM   #4
Service Call's Avatar
Rewards Points: 32
Dedicated circuit definitely. Old dimmers, old wiring, bad harmonics + high precision electronic equipment spells disaster.
The Following 2 Users Say Thank You to Service Call For This Useful Post:
newspark80 (06-09-2012), TooFarFromFenway (06-08-2012)
Old 06-08-2012, 08:04 PM   #5
Harmonics in a house are minimal at best.
In a residence, first I would check for ground current, then operate every dimmer I have from high to low while listening for hum. I have also heard that some old motors in particular refrigator compressors can cause problems.
In lieu of the ONEAC try an isolation transformer small single phase 240 to 120. GROUND THE SECONDARY.
Old 06-08-2012, 09:31 PM   #6
zap
tates1882's Avatar
Rewards Points: 1,076
Couldn't you put an inline harmonic filter with a dedicated circuit?
tates1882 is online now   Reply With Quote
The Following User Says Thank You to tates1882 For This Useful Post:
Old 06-08-2012, 11:11 PM   #7
Semi-Ret Electrician's Avatar
Rewards Points: 486
You might try walking around with a boom box set to AM tuned off-station. Every bit of EMI or RFI will be heard as you get close to the source.
The Following User Says Thank You to Semi-Ret Electrician For This Useful Post:
Old 06-08-2012, 11:13 PM   #8
Rewards Points: 192
thanks guys. please keep the suggestions coming. I will send out checks at the end of the week...LOL
Seriously thanks!
wow
Old 06-09-2012, 01:21 AM   #9
goose134's Avatar
Also could be something in the equipment. Tube amps and vintage equipment often have bad caps that contribute to a general hum. Some equipment will allow a ground lift that will mitigate the problem, but not solve it.
Maybe find out if the amps or gear has been recapped?
A professional in an amateur world.
The Following User Says Thank You to goose134 For This Useful Post:
Old 06-09-2012, 08:45 AM   #10
Retired Account
Rewards Points: 14,650
some older amps have a polarity switch
but, an old sound man trick is, get everything (instrument amps, pa, soundboard) on the same phase
worth a try im ex-sm ho...
Semi-Ret Electrician (06-09-2012)
Old 06-09-2012, 09:48 AM   #11
Big Daddy
Jamuz's Avatar
Rewards Points: 156
Use shielded cable for the audio stuff.
Jamuz is offline   Reply With Quote
Old 06-09-2012, 02:19 PM   #12
Rewards Points: 268
As I wrote in a thread last December:
The following three papers total about 145 pages, but it's the best information available on wiring audio/video rooms.
The Bill Whitlock of Jensen Transformers Seminar paper
http://www.jensen-transformers.com/an/generic%20seminar.pdf
The Jim Brown of Audio Systems Group white paper
"Power and Grounding for Audio and Audio/Video Systems"
http://www.audiosystemsgroup.com/SurgeXPowerGround.pdf
"Power White Paper" from Middle Atlantic.com
http://www.middleatlantic.com/power.htm
or a different version of the same paper
"The TRUTH" from ExactPower of Middle Atlantic Products
http://www.exactpower.com/elite/wpapers.aspx
Speedskater is offline   Reply With Quote
The Following User Says Thank You to Speedskater For This Useful Post:
Old 06-09-2012, 02:35 PM   #13
Rewards Points: 268
I troubleshoot this kind of problem a lot! So the order of work is:
a] All the equipment needs to be plugged into the same power strip.
b] Only Plain Jane interconnect signal cables. The boutique cables may be wired in strange ways.
c] Look around the home for. Light dimmers, new high efficiency lights and light systems, any new appliances with Switch Mode Power Supplies (SMPS).
d] Getting back to the audio system, start simple and work outward.
Dis-connect everything, then.
Connect the amp or receiver to the speakers and check.
Add one unit at a time and check.
A battery power music source is a handy tool.
Old 06-09-2012, 02:38 PM   #14
Ambassador of Amps
TOOL_5150's Avatar
Rewards Points: 2,354
Before you go rewiring the whole joint, maybe all he needs is a "line level isolator" in the signal path... half the time I come across this situation, thats all it took. Im sure there is some N to G bonding somewhere in the system as well - other than where it should be bonded.
Audio system noise Bulldog1 General Electrical Discussion 27 01-31-2012 12:03 PM
Audio Equipment supplier ElectricBill Structured Wiring 23 06-03-2011 07:36 AM
need of equipment grounding conductor WBJ1240 New Member Introductions 12 04-02-2011 06:02 PM
equipment grounding 1idejim Linework 17 09-11-2010 08:02 PM
Equipment Grounding Bar Screws Conduit Phil General Electrical Discussion 39 05-22-2010 09:54 AM
